Fix For Squeaking Noise from Polyurethane Control Arm Bushings
Discussion in '1st Gen. Tacomas (1995-2004)' started by mechanicjon, Mar 29, 2020.
  1. Mar 29, 2020 at 9:37 PM
    mechanicjon
    mechanicjon [OP] They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    A common complaint about polyurethane front control arm bushings is they develop a squeaking noise. The grease gets dried out or washed away over time. So I decided to see if there was a way to make them greasable. Here's what I came up with. I know the red grease is not the correct grease. It was used for proof of concept before buying a tube of prothane or similar silicone grease. https://www.amazon.com/polyurethane-bushing-grease/s?k=polyurethane+bushing+grease
    An Energy Suspension lower control arm bushing is what I started with.
    I used a 1/2" bolt and nut with 2 coned washers and spun it in my drill press. Using a file a made a shallow groove right in the center of the bushing. It's only about 1/16" deep.
    Here's a easy way to make a cone washer to hold bushing centered.
    After cutting the grove on the outside.I used a 1/16" drill bit and drilled holes that lined up with the internal grooves in bushing.
    Then lined up the groove on lower control arm for location of grease zerk.
    Drilled and taped hole for grease zerk. I choose the top of the control bushing for grease zerk. It will require a 90 degree grease zerk to be able to grease it. But it will be protected from rock damage.
    Assembled everything and used a C-clamp to squeeze it together as if it was installed. End result was successful the bushing was greased all the way around.
  2. Mar 29, 2020 at 9:37 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Installed the greasable lower control arms 3 weeks ago. They grease like they're supposed to.
  3. Mar 30, 2020 at 8:14 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Nice proof of concept :thumbsup:
    GQ7227 likes this.
  4. Apr 14, 2020 at 7:03 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Sub for long term results.
  5. Apr 14, 2020 at 7:08 AM
    scocar
    scocar hypotenoper
    Nice. Most refreshing post I've seen in a long time.
    VE7OSR and Running Board Man like this.
  6. Apr 14, 2020 at 8:32 PM
    Running Board Man
    Running Board Man Well-Known Member
    You sir are a real g.
