Fix for bent control arm mounts?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Nov 25, 2020.
  1. Nov 25, 2020 at 10:07 PM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    FL
    aka "the pocket"
    if it's bent and messing up alignment,
    is the only way to fix it by replacing with JD Fabrication Lower Arm Pivots?
  2. Nov 26, 2020 at 2:28 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    If you're going to put that kind of work and cost into it, I'd check with a body shop that has a frame machine. Maybe they could straighten it for you.
    I have one like that, that I tried getting a seized control bushing out of with the Wheeler's press. I don't remember what it's called but it's a sturdy c-clamp type press. I was really wrenching on it and bent the front one on the passenger side. My alignment is fine and it doesn't give me any trouble.
    I tried beating it back with a BFH, but that steel is tough.
    I'd check with a body shop first, at least for an estimate.
  3. Nov 26, 2020 at 1:01 PM
    TacoTuesday1
    FL
    yeah it is tough
    it'd probably at least require MAP gas torch heat and dropping down the control arm out of the way, so that when heating the metal to soften it (maybe up to red hot) to beat it with a hammer or air hammer, that the heat doesn't toast the bushing. (They're tearing now anyway)
    The hard part is gaining access. It's in such a tight spot that there isn't much room to swing a hammer or air hammer.
    Honestly if bent back into shape, the alignment could probably be fine. It would just look ugly underneath.
    I guess I'll ask to find out. I was worried they'd charge a lot,
    and at that point, might as well pay the same price to get the Pivot Kit that results in a bunch of upgrades at the same time
    For example if faced with "return to stock repair" for $200, or "upgrade in 3 ways" for $200, the upgrade option is always better
  4. Nov 26, 2020 at 2:20 PM
    winkel
    Corydon, IN
    True, but with shipping, you'll be in for $1,000, then you will need to find someone to disassemble the LCA's from the truck, cut off the old mounts, grind smooth and position and weld the new unit into place.
    You'll be in for $1,500 before you're done.
    If this is the route you want to go, rock on, I think it would actually be pretty cool.
    I'm curious to know what a frame tweak on this would cost. Please let us know what you find.
  5. Nov 26, 2020 at 2:43 PM
    TacoTuesday1
    FL
    DIY is free
    bhigbee and Tacomasprime05 like this.
  6. Nov 26, 2020 at 3:24 PM
    winkel
    Corydon, IN
    Well that's good. That should save you quite a bit.
  7. Nov 26, 2020 at 3:28 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    if you heat up high strength steel to a point where you make it malleable its going to make it brittle once it cools. There for turning hss into not so high strength. Ide be cautious of doing that.
  8. Nov 26, 2020 at 3:29 PM
    TacoTuesday1
    FL
    true
  9. Nov 26, 2020 at 4:39 PM
    Taco'09
    Taco'09 Well-Known Member
    IDK OP, that does not look too bad to me.
    With the arms off those mounts are pretty flimsy as it is. I might be tempted to just bent it back slightly using a large C-clamp and then finally by bolting the LCA in place with the cam bolt.
    FWIW I had the same thing happen, only much worse after hitting a bottomless sink hole in the pavement. I just took the arm off and mig brazed in a small internal cross-pieces similar to the OEM one used on the rear mount by using my crummy cheap-o 140 amp mig welder, a rented bottle of argon, and silicone-bronze wire. Why mig brazing? To keep heat lower and for known strength. It worked great on mine, seems to be strong, has been that way for a long time and I do off road.
    Here are a few links about he process:
    https://www.mig-welding.co.uk/brazing.htm
    https://rts.i-car.com/collision-repair-news/mig-brazing-what-is-it-why-should-i-use-it.html
    https://www.millerwelds.com/resources/article-library/silicon-bronze-mig-brazing-basics
    Marc70 likes this.
  10. Dec 20, 2020 at 6:40 PM
    Tacomasprime05
    Tacomasprime05 Well-Known Member
    Evan
    Charlotte
    Blue trd sport 05
    Led light conversion Kn air filter Total chaos uca King coilovers Cab mount chop Headlight hydrodip housing Grill craft/ Bay Area metal fab grill Light bar in hood scoop Weld on spindle gusset SOS concepts sliders Soft topper Bluetooth radio conversion
    If it’s any consolation, I’ve trashed my LCA mounts too. I ordered the jd fab lower mounts and am working on the prep work now prior to finding a weekend to rip my truck apart.
    bhigbee likes this.
  11. Dec 20, 2020 at 7:22 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    I rebuilt my LCA mounts using Dirt Designs pre bent gusset kit. Everyone of my mounts were cracked/separating
  12. Dec 20, 2020 at 8:14 PM
    Tacomasprime05
    Evan
    Charlotte
    Blue trd sport 05
    Yeah I would of gone with a less invasive option like this, though the alignment bolt holes were rounded out and there was no hope of restoring factory bolt holes. Solid job though!
  13. Dec 20, 2020 at 9:23 PM
    TacoTuesday1
    FL
    Been looking at doing this as well. Would probably DIY and buy a Hobart 210MVP.
    After hearing quotes of 17+hr @100/hr from fab shops, seems like a ripoff.
    Doesn't take 10 hours to loosen a few bolts and drop a control arm.
    Didn't know this product even existed. I wonder how to get it. All I see is their FB page with pictures but no website with products catalog
    looks like a parts kit that could even be made at home
    unless it requires bending which may cost too much to buy a bender
    vs just buying plasma cutter
  14. Dec 20, 2020 at 9:30 PM
    MonkeyProof
    SoCal- SGV
    You need to email or call the dude
    There's two offerings of the kit, pre bent or straight.
