Fitting a 305/50R20?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Braxtaco, Nov 9, 2018.
  1. Nov 9, 2018 at 9:50 AM
    Braxtaco
    Braxtaco [OP] New Member
    2009 Toyota Tacoma PreRunner
    I am fixing to purchase a Supreme Suspensions 3 in front and 2 rear block lift. I was wondering if a 305 50r20 with -24 offset has a lot of trimming. If it has a lot of trimming what size tire with 20 in rim should I go with?
    Also,
    Include y’all mpg with 3 in lift and 20in rims.
    Thanks
  2. Nov 9, 2018 at 9:57 AM
    Clearwater Bill
    Billy
    Largo Florida
    Tire calculator to figure your gearing impacts.
    Is this build for a pavement princess?
    tcBob likes this.
  3. Nov 9, 2018 at 9:59 AM
    Braxtaco
    90% it is on pavement
  4. Nov 9, 2018 at 10:16 AM
    96carboard
    96carboard Well-Known Member
    Wow, I saw that 305 and immediately thought of tractor tires... but turns out that the 50% sidewall profile still keeps it moderately short, at only 32 inch diameter.
    On the back, you could throw them straight on no lift no trimming, and call it a day.
    I can't really say much about the front though, because wide+offset can amplify clearance problems.
    I think that people go up to 265/75R16 with factory rims and no trimming. Compared to those, your difference is mainly width+offset, as you're adding 1.5 inch to the tread width. But you're going up 3 inches in the front, so my gut tells me that maybe you can get by without trimming, or just a little bit of plastic.
    EDIT: Do you know what the truck will *look* like with 3" lift and only marginally bigger wheels?
  5. Nov 9, 2018 at 2:11 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Don't have a lift, but I do have that size in the rear. I don't remember the offset, but I have 50mm spacers anyway. Just to make things look stanced or something. 275/55/20 in the front.
    Fuel economy on the highway if I stick to the speed limit and always gently accelerate is around 20mpg. Fuel economy in the city with a mix of driving is probably 12mpg. Fuel economy when I want to feel like I'm racing, is asymptotically approaching 0mpg.
  6. Nov 9, 2018 at 5:38 PM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    What is the width of the wheel, that makes a big difference? I just put on 17x8.5 -10 with 305/65 tires and with the mud flaps removed and fender flares trimmed, it doesn't rub in daily driving. But your -24 offset will put the wheel out a bit farther unless it's something narrow like 7.5 or less. Here's mine with 17x8.5 -10 offset with 305's.If I had -15 or more, I'm sure it would rub pretty bad. I also have a 3" lift though.
