fishtailing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by flinthills, May 11, 2021.
  1. May 11, 2021 at 6:06 AM
    flinthills
    flinthills [OP] Member
    I have a 2020 offroad, DBLCB, short bed. The truck does have a snugtop topper, but for the first couple thousand miles, it did not, and that is when I first noticed the fish tailing. On washboards at low speeds, bumps on pavement at low and moderated speeds. Thought when the topper was added, the weight would settle the back end. My son has a 19' offroad DBLCB, no topper, and does not have this problem. Both trucks are bone stock. Anyone else have this problema?
  2. May 11, 2021 at 6:14 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Check tire pressures, just a few pounds can make a huge difference in unloaded pickups. Many shops prefer to fill them based on what they think rather than what they measure.
    Kev250R, 4×4×4, eurowner and 6 others like this.
  3. May 11, 2021 at 6:18 AM
    Mopar Mussel
    Mopar Mussel Well-Known Member
    Jurgis
    2018 TRD Sport, 2006 SAAB 9-5 Aero
    Check the tire pressure. Last time my truck was at the dealership, they had all 4 tires overfilled and the truck was noticeably more skittish over rough ground.
    RedWings44 likes this.
  4. May 11, 2021 at 6:20 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    This.
    The dealership ALWAYS overinflates my tires. Often times it'll be to 35 or 40 psi when recommended cold PSI is 30 according to my door sticker.
    Mopar Mussel[QUOTED] likes this.
  5. May 11, 2021 at 6:27 AM
    flinthills
    They are at 30.
  6. May 11, 2021 at 6:29 AM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    Could be your rear shocks. They could be bad, or the valving on the stock shocks isn't up to the added weight. In either case they would be compressing harder/faster, but not able to rebound quickly enough. Which would cause a loss of traction/fishtailing coming off bumps.
    Skydvrr likes this.
  7. May 11, 2021 at 6:30 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Also. It's a pickup truck, which already has a horrendous weight balance and is geared a little more for torque and the front engine rear wheel drive layout, then Toyota goes and uses a fiber reinforced composite bed to further lighten the rear end.
    The weight balance is absolutely garbage, through a little more weight in the rear and up high were it can get a tad of leverage over the suspension and you have a recipe for the ass wanting to lead the nose.
    If you turn all the nannies off and keep your foot in it (when in doubt throttle out) it can be quite fun.
    Kev250R, Grindstone and Skydvrr like this.
  8. May 11, 2021 at 6:30 AM
    DeeKay20
    DeeKay20 Well-Known Member
    Danny
    Columbia MO
    2020 Tacoma DCSB TRD OR 6MT
    Dobinsons 2" lift, 33s....other stuff
    Sounds pretty normal for a pickup.
    Every truck I've owned hopped around a bit on washboard and rough roads... Hell my Superduty with 4000lbs of tools and stuff in the back will still get squirrely on some of these oil field roads.
  9. May 11, 2021 at 6:36 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Have you driven your son’s truck on the same stretch of road for comparison or did you just ask him if he had experienced the same thing? This sort of thing can be very subjective.
    Key-Rei likes this.
  10. May 11, 2021 at 6:37 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Every truck does that on washboard to some extent. Weight does help but physics say that a solid rear axle and washboard road will cause the rear end to lose traction. Every truck I have ever had would do it at speed. If your truck does it... slow down. Or... speed up and have fun. Your call.
    GillyLink, cosmicfires and Skydvrr like this.
  11. May 11, 2021 at 6:39 AM
    flinthills
    I own several 1 ton trucks for work, and nothing is a squirrely as this thing! Yes, I have taken my son's truck on the same roads to compare, his does great?
  12. May 11, 2021 at 6:46 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I don't know what else to say. Give me any unloaded truck with live rear axle and I can find a speed to make it happen. Much harder to do with independent rear suspension but possible. What happens is tires go slightly airborne for an instant. It is what it is.
    Skydvrr and Key-Rei like this.
  13. May 11, 2021 at 6:50 AM
    flinthills
    Figured I would just check to see if anyone else is noticing a more than typical fishtailing like I am. Thanks for the help. I will just keep telling everyone to hang on.
    hiPSI likes this.
  14. May 11, 2021 at 8:22 AM
    gudujarlson
    Minnesota
    Same shocks, same springs, same wheelbase, approximate same weight, approximate same age, same tires(?), same tire pressure(?). . I don’t have an explanation for you.
  15. May 11, 2021 at 11:30 AM
    DeeKay20
    Danny
    Columbia MO
    What's the mileage difference between your sons truck and yours?
  16. May 11, 2021 at 12:04 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Like said, tire pressure. These trucks are sensitive to the tire pressure, and it sounds like the op's are over inflated.
  17. May 11, 2021 at 12:07 PM
    Grindstone
    Grindstone Requires Adult Supervision
    My '13 Sport did this, unless it was laden. My 20 Pro did it to a much lesser extent, and practically non-existent now with ~300lbs of overland crap bolted on.
  18. May 11, 2021 at 12:08 PM
    microsnook
    microsnook Well-Known Member
    '20 TRD OR MGM MT
    THis. 40PSI youll be bouncing everywhere. I ahve my load E KO2s at 30psi
  19. May 11, 2021 at 12:49 PM
    zoo truck
    None
    My 2020 was very stiff till broken in. I had to carry at least that much weight for around 5k miles till the suspension felt a lot better. Found out later during my 1st service. Dealers service manager said these trucks need at least 5k miles for the suspension to settle in and ride better.
  20. May 11, 2021 at 12:54 PM
    barcelona7568
    barcelona7568 Well-Known Member
    CO
    16 DCLB, Stock
    Have you driven a 3rd gen?
    DeeKay20, Mopar Mussel and Skydvrr like this.
