Fishtailing All the Time..
Discussion in '1st Gen. Tacomas (1995-2004)' started by G59, Nov 23, 2019.
  1. Nov 23, 2019 at 8:49 PM
    G59
    G59 [OP] Stock af
    Torres
    SoCal
    03’ Long Travel DC
    I have an 03 Tacoma with an LT kit up front and 1.5" spacers (rims don't clear calipers, just temporary), and 33" tires. Rear suspension is just deaver j59s with some 5100s. (Another heavy spare 33" under the bed plus a tow hitch under the bumper too)
    I've been noticing a lot lately that whenever I am coming into a turn (esp when there's a bump or pothole) that my rear end wants to get away from me and it jumps up and fishtails so much its scary sometimes. I just want to know why its doing this.
    I also started noticing this shortly after I installed my LT kit too..
  2. Nov 23, 2019 at 8:51 PM
    magneticwhite88
    magneticwhite88 Well-Known Member
    Brandon
    OC, CA
    15' MGM Trd Off-Road
    Maybe the increase in body roll + you might be taking turns a little more hot without realizing... Tire tread is good I suppose?
  3. Nov 23, 2019 at 8:53 PM
    G59
    G59 [OP] Stock af
    Torres
    SoCal
    03’ Long Travel DC
    Its possible, not going to lie, I'll have to double check what speed im coming in at. And yes the tire tread has about 70% life still left :notsure:
  4. Nov 23, 2019 at 8:55 PM
    magneticwhite88
    Brandon
    OC, CA
    When I lived in Texas it rained all the time and I loved street drifting lol, easy on the tires
    Amchuge and G59[QUOTED][OP] like this.
  5. Nov 23, 2019 at 9:00 PM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Sounds like the rear shocks are toast.
  6. Nov 23, 2019 at 9:03 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I noticed with LT on that the rear tires will swing out more now VS the fronts loosing grip and pushing when it was stock width and with a sway bar. Especially in wet conditions.
    LT changes the entire handling characteristic of the truck (isn’t that why we bought that 4-digit price tag metal in the first place ?), so you gotta account for that. I take corners slower now.
    edit:
    You could try moving the spacers to the rear when you get new wheels; increasing the track width out back will make it more stable as well.
    G59[OP] likes this.
  7. Nov 23, 2019 at 9:10 PM
    13loody
    13loody Member
    2001 Base 2.4L Regular Cab RWD Auto
    Do repairs count?
    My truck is stock height with blown shocks, and it was fishtailing too. My temporary solution is to throw 2 80lb. bags of sand in the bed closest to the tailgate. When wet, it soaks up water (weighing more) and gives me more traction. I haven't fishtailed since. I plan on changing my shocks this spring.
    G59[OP] likes this.
  8. Nov 23, 2019 at 9:12 PM
    G59
    G59 [OP] Stock af
    Torres
    SoCal
    03’ Long Travel DC
    Theyre pretty new actually, only about 2k miles??
  9. Nov 23, 2019 at 9:15 PM
    G59
    G59 [OP] Stock af
    Torres
    SoCal
    03’ Long Travel DC
    You make a really good point, never thought of it that way. And that's exactly what my plan is one I get new wheels. I'm hoping itll help just a little.
  10. Nov 23, 2019 at 9:17 PM
    G59
    G59 [OP] Stock af
    Torres
    SoCal
    03’ Long Travel DC
    I put my spare under the bed and have a heavy tow hitch in the rear that I thought would help the situation a little lol didn't make a difference really
  11. Nov 24, 2019 at 8:35 AM
    ryans4x4
    ryans4x4 Well-Known Member
    1998 Tacoma ECSB 5VZ 5MT
    Maybe add an anti wrap bar to your rear axle?
  12. Nov 24, 2019 at 8:54 AM
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Make sure your 5100s are installed upright. The interwebs will say they are monotube and orientation doesn't matter but Fu*k those blue hair suspension arm chair worriers, the billies are binary. If installed upside down they make your suspension want to buck.
    Compliance can help with grip. When I would auto x the is300 I would go soft on the rear coilovers (flex with edfc) and stuff up front to give more grip to the rear otherwise it was very oversteer happy. You have a very complaint front and stiffer rear plus the truck weight bias, it's just going to be the way it is unless you go way softer in the rear suspension.
    G59[OP] and cruiserguy like this.
  13. Nov 24, 2019 at 9:05 AM
    LukeCC
    LukeCC Well-Known Member
    Luke
    Southern California (East County)
    2002 LT DCSB
    I have practically the same situation.
    LT up front. J59/1500 rear. But I have my spacers in back to even things up a bit as @Sterling_vH111 suggested. My steering rack bushings are smoked and my rear shocks are probably just as well. It’s wild at freeway speeds. Super sketchy. Replacing bushings this week and probably gunna slap some fox 2.0s in for a bit til I can do something more permanent in the rear. Have you had the long travel installed for a while before you started fishtailing or did it start happening after you installed the kit?
  14. Nov 24, 2019 at 9:29 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    You had me at 'auto x the is300':D:cool: you got some pics of that bad boy? My dream 'go fast' car to build one day
  15. Nov 24, 2019 at 9:48 AM
    G59
    G59 [OP] Stock af
    Torres
    SoCal
    03’ Long Travel DC
    Yeah that's what I plan on doing once I get new wheels, just move the spacers to the rear. Honestly I noticed it happening right after I put the kit on. My deavers have maybe 1.5k miles on them and all the suspension is in good shape bushings and all. I'm thinking it's just because the front is so much wider than the back it might be causing this issue but I'm just not sure.. Wanted to get a couple other people's input
  16. Nov 24, 2019 at 9:50 AM
    G59
    G59 [OP] Stock af
    Torres
    SoCal
    03’ Long Travel DC
    Yeah theyre definitely installed upright lol I'll have to look into softening up the rear suspension. That might be what it needs because it does feel pretty stiff when it fishtails
  17. Nov 24, 2019 at 9:56 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Could your rear e-locker be accidentally engaged? I'm not having any fishtail problems with BIL 5100s.
    This video was made was made with some low cost Nexen tires.
    https://youtu.be/uHNvlpbv9HE
  18. Nov 24, 2019 at 10:43 AM
    btu44
    btu44 Well-Known Member
    Long Beach area, Ca
    04 Tacoma Double Cab, 4WD, TRD Off-Road
    SC with 7th injector. ICON 2.5 shocks and coil overs, SPC UCA, EMU Dakar rear springs. FrontRunner bed rack. ICOM IC7100 amateur transceiver
    Sounds to me you need more rebound dampening in the rear. Higher rate springs than stock need more rebound dampening to control over extension after bumps.
    When I installed ICON 2.0 with Dakar springs on my Taco I had the same issue you are describing. After I had the shocks revalved for 20% more rebound the problem complete went away.
    I had Bilstein 5125 #33-230344 on a 89 Toyota 4WD Pickup and they worked very well. These shocks had 360 rebound/80 compression valving. If you know the part# of your 5100 you could look up there valving specs. IMO if your shocks have lighter dampening than 360/80, finding a solution with more rebound would be my try at a fix.
  19. Nov 24, 2019 at 4:26 PM
    G59
    G59 [OP] Stock af
    Torres
    SoCal
    03’ Long Travel DC
    Def not axle wrap haha I tried it already
  20. Nov 24, 2019 at 4:27 PM
    G59
    G59 [OP] Stock af
    Torres
    SoCal
    03’ Long Travel DC
    That's promising. I'll have to look into that! But do you know if 5100s can even be revalved?
