Fisher Snow Plow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TOMRR, Jan 24, 2014.
  1. Jan 24, 2014 at 8:10 AM
    TOMRR
    TOMRR [OP] Well-Known Member
    Tom
    Mass
    2016 TRD OFFROAD, DCSB, AUTO, BLAZING BLUE, PREMIUM JBL TECT.
    Stock TRD OFF ROAD DCSB AUTO JBL TECT. Bed Mat Heated and turn signal mirrors Wet Okole Front Seat Covers Prodigy Brake Controler Front Skid Plate Power Wagon Badge Tint Driver and Pessenger door windows Inchannel window vents
    Thinking about having a Fisher Snow Plow installed on my 2011 DCB TRD Auto Trans, 4x4Tacoma . The local dealer has a set up in stock, Will only use for my own light work. Should the truck with stock front suspension be ok??
  2. Jan 24, 2014 at 12:02 PM
    ReBeLToY0
    ReBeLToY0 Well-Known Member
    Jersey
    TRD Sport DCSB SOLD:(
    1/FOG light mod 2/ deflapped front 3/ plasti dipped matte black rims 3/ weather tech guards 4/ remove TRD Sport stickers and tailgate badges 5/ weather tech floor mats 6/tonneau covered bed 7/ nfab step bars 8/flowmaster 40series
    I think you should be ok but check out wheeler off-road for timbres they just showed them to me and they could help stabilize the extra weight, I'm sure upgrading suspension would help but it's not required
  3. Jan 24, 2014 at 12:45 PM
    TOMRR
    Tom
    Mass
    Thanks for the reply, The place that installs them told me that most of the wt comes off when you unhook there is only bracket on the truck
  4. Jan 24, 2014 at 3:30 PM
    Fire Taco Fighter
    Fire Taco Fighter Well-Known Member
    trd
    what plow are we talking here? fisher what? homesteader?
  5. Jan 24, 2014 at 5:26 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    While some snow plows are harder on the truck than others (weight, size, and usage time being the problems) no snow plow is good for them. The OME suspensions are not designed for snow plows so they will add to quicker failures.
  6. Jan 24, 2014 at 7:59 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The plow my dad has on his truck is like that. 2 minute removal and the brackets that remain are minimal. He made a frame from a furniture dolly so he can wheel the plow and frame in place, attach and detach it quickly and easily. As mentioned above, plowing does add more stress to the front end components and no plow is 'good' for the truck but, if you're careful, don't go barreling into banks, use an appropriate sized plow for the truck and don't push more than the truck should, the truck will hold up just fine.
