First oil change on my 2021 TRD Sport...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gc9773, Apr 10, 2021.
  1. Apr 10, 2021 at 8:23 PM
    gc9773
    gc9773 [OP] Member
    Garry
    2021 TRD Sport
    Never changed the oil on a cartridge style filter before, and this was my first oil change on my brand new 2021 Tacoma TRD Sport 3.5l...
    Some notes, yes, I know the service manual specs 10,000 miles, but 5,000 seems more prudent, particularly given that the Nissan dealer suggests 5,000 miles for my wife's 2020 Pathfinder even though the service manual suggests 7,500 miles as they consider my locale (Albuquerque, NM) "severe duty".
    I said more 4 letter words than I can remember as I tried to remove the skid plate. This was after nearly rounding off one of the 4 bolts which had apparently been torqued to 200 ft/lbs (sarcasm). I thought I was going to need vise grips to remove it. A 6 point socket vice 12 point saved the day.
    Replacing the filter went smoothly in spite of my lack of familiarity with the system. I found some instructions on the web and the filter even had a sheet in the box discussing the procedure.
    At 4,870 miles, the oil looked dark enough (read: black) that I was happy I made the decision to replace it. I know, not very scientific, and no, I'm not sending a sample to Blackstone, and no, I don't care... The brand of oil and filter manufacturer will not be mentioned here, but suffice it to say, the oil was a high quality synthetic 0W-20 and the filter was from a reputable manufacturer.
    All in all, a learning process for me. I can see why some folks use the spin-on filter adapter and I am now confident in my ability to change my own oil, but they made it much more of an ordeal with the Tacoma, and I found out why I had been dreading it, and for good reason!
  2. Apr 10, 2021 at 8:28 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    I have mine changed every 5k. I trust my local Toyota dealer so I just have them do it lol
  3. Apr 10, 2021 at 8:32 PM
    gc9773
    gc9773 [OP] Member
    Garry
    2021 TRD Sport
    I have the dealer service my Tacoma as well as my wife's vehicle (Nissan), but in this case I was more curious than anything... I'm glad I did it, as at least I have some experience with it now. And for the record, per the manual, it did take 6.2 quarts of oil...
  4. Apr 10, 2021 at 8:39 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
  5. Apr 10, 2021 at 9:20 PM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    I've done oil changes 3 times now on mine.
    I'd say you should upgrade to TRD Pro skid plate, it's a PITA to put it on, but changing oil much easier down the road, just 5mm hex to opening up the panel to access the filter, and drain bolt is exposed and I can fit my hand through it. The entire time the skid plate stayed on.
    I have some mystery minor oil leak with the cartridge system, probably I didn't wipe down thoroughly. That's why I'm going to use spin-on adapter next time so I can clean the spin-on filter properly after the oil change.
    GarlicFarts and bgio67 like this.
  6. Apr 11, 2021 at 12:43 AM
    Xer0 SiN
    Xer0 SiN Well-Known Member
    Hilo, HI
    19 TRD SPORT TACOMA / 21 LIMITED RAV4
    this and that...
    i contemplated removing my skid when i did my oil change last week. this was the second time i changed the oil, the first time with the trd skid equipped. i decided to leave it on; oddly enough it wasnt as hindering as i thought it was gonna be. i could access everything pretty easily. i did buy the motivx oil change essentials with the fumoto valve, so maybe thats why it was "easier", but tbh it was more qol than anything. gratz though on getting that oil change under your belt. always good to learn about the different systems. one thing i liked about the 2nd gens 1gr vs our 2gr was the oil change procedure was wham bam thank you maam compared to the 3rd gens.
  7. Apr 11, 2021 at 5:06 AM
    gc9773
    gc9773 [OP] Member
    Garry
    2021 TRD Sport
    I've been looking at the TRD Pro skid plate, a little pricey but probably pays dividends in blood, sweat, and tears. For the record, I did use the MotivX kit when changing my oil and was happy I purchased it...
    SLeeper512 and bgio67 like this.
  8. Apr 11, 2021 at 5:16 AM
    muskratX22
    muskratX22 Well-Known Member
    Dave
    Illinois
    I only have a little over 10,000 miles on my Tacoma. I have mine changed @ 5,000 miles. The dealership did both changes. At 5,000 miles I paid and they were cheaper than the in-and-out oil change garages.
    SLeeper512 likes this.
  9. Apr 11, 2021 at 5:22 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Good deal, getting your hands dirty while learning about your new truck, no dealership BS involved, win win.
    Junkhead likes this.
  10. Apr 11, 2021 at 5:23 AM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    If Toyota would have put the cartridge housing on top of the engine; like everyone else, then worrying about moving the skid plate wouldn't be an issue.
    zoo truck, SLeeper512, Qwack and 3 others like this.
  11. Apr 11, 2021 at 6:09 AM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    There's definitely easier vehicles out there for changing oil, but the Tacoma isn't really that bad. After my first, now it only takes about 30 minutes or less.
    I had ordered an aluminum filter housing but cancelled the order after reading of quite a few negative issues on it.
    I would recommend changing oil at 5,000 miles as opposed to 10,000. I have changed every 5000 miles in my '96 2.7 4x4 and it's now has 414,000 trouble-free miles on it without ever having an engine cover removed.
  12. Apr 11, 2021 at 7:16 AM
    ugawino
    ugawino Well-Known Member
    Bill
    Paola, KS
    2021 TRD Off-Road, Silver Sky Metallic
    Mods? We don't need no stinking mods.
    Wow! What a pain. I like Subaru's set-up better with the oil filter easily accessible just by popping the hood.
    I think it'll be worth it to pay Jiffy Lube $50 to do oil changes rather than go through what I just saw on a couple of YouTube videos.
  13. Apr 11, 2021 at 7:22 AM
    SR5TacoMike
    SR5TacoMike Well-Known Member
    2020 Tacoma SR5 V6 4X2 Metallic Grey Crew Cab Short Bed
    same here, did my first oil change at 5K, I plan to take the time to do it myself even though the dealer offers free maintenance for 2 years.
    OZ TRD and Kev250R like this.
  14. Apr 11, 2021 at 8:25 AM
    DaBigDogg
    DaBigDogg "Say when..."
    Jay
    Mid-Suffolk, LINY
    '22 MGM DCLB TRD OR
    That's what I had on my GTI. You'd have thunk that was one of the purposes of changing to the cartridge versus the spin on lol.
  15. Apr 11, 2021 at 8:28 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    ...and another one. Just change your oil dude. Don't care if you change it every 100 miles or every 50K miles. You do you and I do what Toyota engineers tell me to do.
  16. Apr 11, 2021 at 8:38 AM
    Chaosh1
    Chaosh1 Well-Known Member
    2021 Tacoma TRD Pro
    Nope, never ever use those types of places your asking for problems. Besides, it's time I teach my 4 year old daughter how to change the oil.
    auskip07 and 06trdtaco like this.
  17. Apr 11, 2021 at 8:45 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Put a little anti-seize on the skid plate bolts, that'll keep the threads happy over multiple times removing/installing
    I dont use anti-seize on everything, but its good for things that will be removed over and over throughout the life of the vehicle like lugnuts, skids, etc. Be gentle and don't over cook the bolts, snug is fine..
    Congrats on the new truck
    RustyGreen likes this.
  18. Apr 11, 2021 at 8:47 AM
    ugawino
    Bill
    Paola, KS
    Maybe I've just been lucky. But after 35 years or so of using drive-thru oil change places, I've never had a problem.
    But I do think it's cool that you're teaching your daughter some auto maintenance skills. Good job, dad!
  19. Apr 11, 2021 at 9:04 AM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    Such as??
    jimmerheck and nightcrawler like this.
  20. Apr 11, 2021 at 9:15 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Red? o_O
    Holling likes this.
