First Gen Tacoma Brake Pads
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacofan248, Nov 4, 2022.
  1. Nov 4, 2022 at 11:15 AM
    tacofan248
    tacofan248 [OP] Well-Known Member
    Went to get tires rotated at Les Schwab, they told me my front brake pads were at 2MM. Going to change very soon.
    How long will these last before I damage rotors if I order brake pads online and wait on them to ship and deliver?
    Also which Akebono brake pads will fit front? There’s many different ones. Will ACT799 part number fit?
    Thanks
  2. Nov 4, 2022 at 11:43 AM
    Clearwater Bill
    Billy
    Largo Florida
    Depends on how much braking you do. Aren't your squealers already protesting?
    Since you don't give us the year/model of your truck, kinda leaves folks in the guessing mode doesn't it?
    Bivouac likes this.
  3. Nov 4, 2022 at 11:44 AM
    02hilux
    Planet: EARTH
  4. Nov 4, 2022 at 11:46 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
  5. Nov 4, 2022 at 11:48 AM
    tacofan248
    2002 Taco 2.7 PreRunner
  6. Nov 4, 2022 at 11:48 AM
    tacofan248
  7. Nov 4, 2022 at 11:48 AM
    tacofan248
  8. Nov 4, 2022 at 11:49 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I don't know- but I can confirm the 436 fit my 6 lug.
  9. Nov 4, 2022 at 11:50 AM
    tacofan248
    Where did you order from?
  10. Nov 4, 2022 at 11:57 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
  11. Nov 4, 2022 at 11:59 AM
    tacofan248
    Thank you! And this was for the front right?
  12. Nov 4, 2022 at 12:11 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    yup- these trucks have brake drums and shoes in the rear, as opposed to capilers, rotors, and pads in the front.
  13. Nov 4, 2022 at 1:07 PM
    tacofan248
    How often do rotors and calipers and drums and shoes need to be replaced? Should I handle rear job too?
  14. Nov 4, 2022 at 1:23 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Like most things, it depends. Depending on how you drive, and where you drive, the fronts can last 30k or they can last 60-80k. I lived in the mountains for a long time, and I would just replace the front brakes once a year- commuting up and down the hill every day did the brakes in way faster than where I live in SD now. In general, the back brakes wear far less than the front and are much less prone to warping. So it's not uncommon to get 100k outta the back. Folks who don't use their parking brake probably get a lot more o_O (setting the parking brake adjusts the rear shoes). The shoes are still a DIY project, but they do require some special tools (spring compressor and tensioner).
  15. Nov 4, 2022 at 1:55 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Some people once a year others never in 5 years.
    It never hurts to check your rear brakes
  16. Nov 4, 2022 at 10:32 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    They're not the same but they will both fit 6 lugs. The difference is the orientation of the wear indicators/squealers. ACT436 is listed for 01-04 & ACT799 is listed for 95.5-00.
    I run 799 simply cause they cost less than 436. I've used 436 before (and the same style from other brands) & noticed no difference between the Akebonos.
    436 includes the top ones, 799 all 4 are the bottom style.
    Area51Runner likes this.
  17. Nov 5, 2022 at 3:21 AM
    Bivouac
    Is the pad compound the same in both part numbers?
    The only difference being the slight hardware difference.
  18. Nov 5, 2022 at 8:59 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    No idea but I assume they are. Both listed as ceramic, I've had compared them side by side & the compound looks the same.
  19. Nov 5, 2022 at 10:34 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
  20. Feb 15, 2023 at 1:29 PM
    Kepo
    Kepo Member
    Keefe
    02 Tacoma
    I am also in need of pads. Had work done the other day, and had them look the truck over so I can prioritize what needs to be done, and they said my pads were at 3mm. I am having a hard time figuring out which ones I need. They didn't say anything about the rotors and I think they look good. How do I tell for sure?
    The truck is a 02 Tacoma 4-door 4WD. No crazy upgrades, just a toolbox and Toyo open country M/t's 265/75r16 (which were on when I bought the truck). 6 lugs if that matters.
    I'm thinking I can just swap pads and not have to do rotors at this time. does anyone have a link to the correct pads?
    many of the posts I see on here are just telling people to do the Tundra upgrade however I will not be doing that at the moment so I just need good reliable pads that will not break the bank.
    Thank you!
