First gen steering wheel clunk FIX
Discussion in '1st Gen. Tacomas (1995-2004)' started by rab89, Aug 2, 2010.
  1. Apr 18, 2017 at 3:15 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Good point, but I think that's why it's a tack weld and not a bead weld mod - same with a roll pin - it won't hold up under a huge impact as far as I know?
  2. Apr 18, 2017 at 5:44 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Roll pin is made to sheer if necessary. Compare the amount of steel used in a weld compared to a roll pin thickness.
    Tim7902 and Dalandser like this.
  3. Apr 18, 2017 at 9:03 AM
    Tim7902
    Tim7902 Well-Known Member
    Tim
    Maryville, TN
    2001 tacoma doublecab
    I put a roll pin in mine like some others have stated. I do have access to a welder and can weld but don't trust a spot weld. I'd hate to have a steering wheel pushed through my chest in a crash. Lol
  4. Apr 18, 2017 at 8:03 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    You said you used existing holes for the roll pin, where did you get the roll pin from? What size? Do you just hammer it into the hole?
  5. Apr 18, 2017 at 8:20 PM
    LearningToFly
    LearningToFly Well-Known Member
    Northeast Alabama
    2004 Double Cab
    I was more concerned about my mental health listening to that rattle.
    cruiserguy likes this.
  6. Apr 18, 2017 at 8:38 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Home depot it was 1/8 inch if i remeber correctly. It was just a touch bigger then original holes.20170301_125718.jpg
    Notice the two dots on the flat part of shaft. One already has my roll pin in it. I had to drill it out just a little bit. I used an drill bit the same size as roll pin. Almost positive it was 1/8 inch. I had to grind the excess off after i installed it.
  7. Apr 18, 2017 at 9:57 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    I just used two 1/4" self tapping screws, slightly off-set and 180° from each other. Worked great, one of the first mods I've done on my truck.
  8. Apr 19, 2017 at 10:06 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    ThunderOne likes this.
  9. Apr 19, 2017 at 10:14 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    does the column still need to come out to access this or can you get to it while still in? any pic of where it's at? :)
  10. Apr 19, 2017 at 10:21 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    Read this first for inspiration then go to the beginning.
  11. Apr 19, 2017 at 2:17 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Have to pull shaft out. Read post link above.
    Note post #43 in that link.
  12. Apr 19, 2017 at 9:25 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    yeah, I read the post. this is on the "to-do" list when I get time and space.
  13. Apr 19, 2017 at 9:27 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    and as I stated in another thread, the entire engine would literally have to come through the firewall before the steering column would compress. unless you got hit driver's side fender, but even then the undercarriage would get pushed in
  14. Apr 19, 2017 at 11:30 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    It's usually not the column being pushed toward you
    It's the driver pushing the column away with there chest and air bag explosion force.
    It's design is like a crumple zone to absorb impact force.
  15. Apr 20, 2017 at 6:54 AM
    #35
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Well I certainly don't think my body would create 1 ton of force (enough to break said roll pin) in an impact before I turn into a gooey mess.
  16. Apr 20, 2017 at 6:55 AM
    #36
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    What kind of self tapping screws? How long were they? Where'd you get them?
  17. Apr 20, 2017 at 7:44 AM
    #37
    mechanicjon
    Jon
    Scottsdale Arizona
    It takes 1090lbs of force for a double shear of a carbon steel 1/8 roll pin. From all my research the home depot roll pins are even softer. Thus lowering the force needed for a double shear.
  18. Apr 20, 2017 at 8:25 AM
    #38
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    someone needs to see how much force it takes for the shaft to crumple without anything extra done to it. I bet it's still a lot.
  19. Apr 20, 2017 at 8:38 AM
    #39
    mechanicjon
    Jon
    Scottsdale Arizona
    I vould probably find out what GMs shaft is rated at. I'll post my findings later
    99SuperTaco4x4 likes this.
  20. Apr 20, 2017 at 10:15 AM
    #40
    License2Ill
    Ian
    It's been so long I honestly couldn't tell you. But if I were to guess, they were 1/4"X 1/2" Phillips pan head. And bought at an Ace Hardware or True Value.
