first gen motor mounts, auto trans mount questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by snufkin, Jun 12, 2023.
  1. Jun 12, 2023 at 1:00 PM
    snufkin
    snufkin [OP] Member
    john
    1999 Tacoma SR5 4WD extended cab
    hey all, newer member, first time posting, thanks in advance for any and all advice!
    so, i have a '99 SR5 3.4L extended cab 4x4 automatic trans with 299K that i've slowly been doing a lot of the necessary maintenance on. making good progress. super fun, really love this little truck
    it's acting like the motor mounts are worn so starting to research the job
    interested in knowing a good choice for aftermarket mounts (OEM are like a hundred apiece)
    what brand(s) and part #s do y'all recommend?
    same with the trans mount (like 160 at the dealership yikes), which i'm planning to replace really just because it's probably 24 years old
    best,
    -John
  2. Jun 12, 2023 at 1:01 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome To TW John...
  3. Jun 14, 2023 at 5:16 AM
    snufkin
    snufkin [OP] Member
    john
    bump, anyone? Bueller? *crickets*
  4. Jun 14, 2023 at 5:55 AM
    AuDigger
    AuDigger Well-Known Member
    1995.5 Evergreen Pearl 5-lug Extracab
    Bought my Anchor ones from Rock Auto. Seemed to be made okay. Rock Auto also has Beck-Arnley ones for a little more money. These should last me awhile for as much as the truck is driven (5K a year). I was at 180K when I changed mine on my 1995.5. The Trans mount was shot, the motor mounts weren't too bad. Mine are a lot easier to change than yours since I have a 2.4L five lug - a lot less in the way the way and more room to work on the front ones. So, if they don't last long, it's a couple hour job in the garage.
  5. Jun 14, 2023 at 4:56 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    I would advocate saving up to buy the OEM ones. Presumably the ones you have installed now are OEM, and the truck has made it ~300k with them. Hard to argue that $360 for another 300k miles ain't worth it. Even if the funds aren't there now, then I'd drive it on blown out mounts until they are. About a month ago replaced my trucks original motor mounts at ~285k miles with OEM replacements, but used an aftermarket trans mount (only because OEM trans mounts for the Xtra cab MTs with the V6 have been discontinued, and are unavailable everywhere). Low and behold and my transmission is clunking a month later and the RockAuto trans mount looks to be the culprit already.
    Madjik_Man and snufkin[OP] like this.
  6. Jun 19, 2023 at 2:39 PM
    snufkin
    snufkin [OP] Member
    john
    thanks for the advice! i went ahead and ordered OEM parts online from a Toyota dealership in VA, and the prices were significantly lower, just under $275 shipped for the 3 mounts. they even double check against the VIN before sending
  7. Jun 19, 2023 at 4:40 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  8. Jun 20, 2023 at 11:27 AM
    snufkin
    snufkin [OP] Member
    john
  9. Jun 20, 2023 at 11:42 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Have you checked 4x inovations transmission mount for the 5 speed.
    I have one for about 100,000 miles no issues much better then OEM easy to service if you ever need.
  10. Jun 20, 2023 at 12:29 PM
    Red_03Taco
    Jerad
    I have not, but I will now. Thank you for that information. Was pretty bummed when I had to settle, or rather thought I had to settle for a chincy RockAuto mount.
    Bivouac[QUOTED] likes this.
  11. Jun 20, 2023 at 1:51 PM
    O'Silver_Taco
    MD
    Yeah I think that exact same motor mount is used in volvos and/or Subaru's
  12. Jun 20, 2023 at 7:07 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Yep, same, anchor trans mount just came in today. Seem decently well built for 30 bucks
  13. Jun 22, 2023 at 6:46 AM
    snufkin
    snufkin [OP] Member
    john
    p.s. if somebody could point me to a thread on here, or video, that lays out the motor mount job for the 3.4 in detail i'd appreciate it
  14. Jun 22, 2023 at 8:31 AM
    O'Silver_Taco
    MD
