First Brake Flush pressure brake bleeder?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ron197, Dec 6, 2019.
  1. Dec 7, 2019 at 7:59 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Oh yeah, okay well I could see the moisture that eventually builds on the lines mayne migrating slowly over time making its way to the highest point, the reservoir. The shocking thing I remember reading from one these young dudes on here about the brake fluid is that it turns green as it ages and leeches out some chemical or something from the brake lines that turns the fluid green or something like that.
    And I'll bet the fluid is relatively stationary in the lines. Otherwise we'd be able to Bleed the air like coolant or power steering, a thought that just crossed my mind
    I changed the oil on the taco and remembered to turkey blaster out the power steering reservoir. And added new Valvoline ATF from Schucks or whatever. I kid you not the steering wheel turns easier. Crazy. I should remember to do this every oil change as much as a pain as our steering racks are to mess with
  2. Dec 7, 2019 at 8:09 AM
    ajmogen
    ajmogen Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
    cruiserguy likes this.
  3. Dec 7, 2019 at 9:41 AM
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
  4. Dec 8, 2019 at 5:26 AM
    ron197
    ron197 [OP] Active Member
    what about the reverse? A Vacuum Brake Bleeder the ones that hook up to a air compressor to create suction.
  5. Dec 9, 2019 at 9:42 AM
    omarq
    omarq Well-Known Member
    o
    1999 Tacoma Extracab
    17" wheel
    I rented the brake bleeder vacuum kit from Advance Auto... it sucked. I eventually did the straw in a jar of fluid method. Worked like a champ.
    CS_AR likes this.
  6. Dec 9, 2019 at 11:45 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    No, it's not the end of the world if you get air in the lines. The world will go on without you...
    Kiloyard and cruiserguy like this.
