First Aid/Med Kits
Discussion in 'General Tacoma Talk' started by sflegends, Apr 15, 2025.
  1. Apr 15, 2025 at 7:43 PM
    sflegends
    sflegends [OP] Active Member
    Colorado
    2012 Gray Tacoma Access 5 lug 2wd
    What is your setup? What kind of kit do you have? Where do you keep it?
    I’ve got an old fanny pack stuffed with some bandaids and gauze strapped to the rear of the passenger headrest. I’m wondering what other things people are doing out there.
  2. Apr 16, 2025 at 6:14 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    I've migrated to keeping tactical trauma kits in my vehicles because if I'm reaching for any first aid kit, it means things have gone horribly wrong, and I need to keep myself together enough to get to the nearest hospital.
    And for me, a dainty AAA-approved pack of small bandages and aspirin won't ever cut it--i can and have toughed those situations out. But if I need immediate medical attention, it generally means a deep cut...
    Sprig and sflegends[OP] like this.
  3. Apr 17, 2025 at 11:54 AM
    sflegends
    Colorado
    Great point. If you need it, it's likely you really need it.
    Are you building your own or buying one of the pre-assembled ones?
  4. Apr 17, 2025 at 7:14 PM
    02hilux
    Planet: EARTH
    Stop the bleeding & trauma kit
    Some 5x9 & 4x4
    Padded aluminum splint
    Triangular bandage
    sflegends[OP] likes this.
  5. Apr 17, 2025 at 7:20 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Trauma kit with bandages for controlled bleeding, including quick clot
    Large bandages (multi-purpose) for makeshift slings, splint wraps, etc
    Sam splint
    And the knowledge on how to use it all
    (Stop the bleeding before restoring breathing - body can go a bit longer without oxygen, as one can bleed out fast before breathing needs to be restored)
    02hilux, sflegends[OP] and soundman98 like this.
  6. Apr 17, 2025 at 7:42 PM
    soundman98
    NW Indiana
    I get the preassembled ones from a local prepper/weapon store. They all have expiration dates, and I haven't had a predefined specific need for any of them, so I don't see a reason to spend a lot of time preparing for unique situations by creating my own version
    sflegends[QUOTED][OP] likes this.
  7. Apr 17, 2025 at 8:08 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    I like the Rhino Rescue stuff sold on Amazon. Have equipped 2 vehicles with the Trauma kit, Burn kit and an Israeli style bandage.
  8. Apr 17, 2025 at 9:52 PM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    No, I am not a prepper but I can see a use for all of this when not near a town or ranger station.
    Cost is nominal unless otherwise indicated. About $150 total, packed in an old bike-rack side-bag.
    (1) CAT certified tourniquet ($20)
    (2) Israeli bandages ($20)
    Poncho
    Zipties
    Sunblock
    Icy hot cream
    (2) Glucose gel
    Neosporin
    (30) "wound closures" (thin tape strips across long slices that help until you can stitch it up)
    Emergency blanket
    Aqua tabs for water cleaning
    Nair ... in AZ cactus can leave thousands of tiny spike in skin ... do not ask me how I know :anonymous:
    1 multi-use splint ($20)
    Hydrocortizone
    Trauma pack with triangle bandage and blood-clotting gauze ($30)
    (5) Transparent waterproof dressing
    Burn gel
    Arm "shower shield" ... latex-free sleeve that covers hand and forearm in case you have hand/arm injury ... leftover from use last year ($12)
    Finger sleeves (braces)
    Self-adhesive wrapping ... sticky/stretchy so cloth tape not needed to hold it on
    White cotton tape for other uses
    Salver alginate patch
    2x3 non-stick pads
    2x2 non-stick pads
    2x5 big pads
    Lidocane patches for muscle ache
    Allegra-D
    Sport hydration mini-squeeze bags
    Stomach remedy ... that pink stuff I cannot recall the name of in small tablets
    New Skin bottle
    A pre-fabbed first-aid kit with several other bandaids/pads/etc.
  9. Apr 17, 2025 at 10:31 PM
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
    Israeli bandages are a good mullti use item. They are basically an ace bandage with a gauze pad and a pressure applicator. If you are in need of the ace bandage or gauze pad you can disassemble it for them. Make sure to get enough of them so that you have 1 to open up to play with. Like most things they are useless without training.
    As far as gauze goes the vacuum packed z fold packs or rolls take up a tenth of the space of a regular roll and are super handy.
    Quikclot and tourniquets are really last resort items. All the little quikclot crystal have to be removed before a wound can be closed which can sometimes be problematic. Tourniquets are also dangerous if used improperly. A sharpie should always be stored with one.
    SAM splints are great and have instructions printed on them.
    Duct tape is super useful for all sorts of injuries. Strips make a decent butterfly bandage. They can hold dressings on, secure or build a splint, etc.... It does go bad after a while in the heat of a truck though.
    Little spray cans of sterile saline solution wound wash can be handy for cleaning out wounds when away from running water.
    Soap and water is the best wound cleaning method the majority of the time but if cleanliness is an issue neosporin/triple antibiotic ointment is handy. Dont use it if not warranted though.
    Hydrogen peroxide generally does more harm than good but is called for for animal bites, puncture wounds or someplace like the gulf coast where there is flesh eating bacteria in the water.
    Carry plenty of ibuprofen and some tylenol. They can be taken together to deal with serious pain.
    5% lidocaine ointment is great for all sorts of pain and irritation. Good for bug bites, muscle aches, numbing skin before removing splinters, etc. Over the counter it is only licensed to be sold as hemmeroid relief so it will be labeled as such.
  10. Apr 17, 2025 at 10:38 PM
    Mach
    A good pair of tweezers is a must. The ones that came with your first aid kit are useless. At least go into the beauty section at the drug store and get a decent bame brand pair with a good sharp ground point where the ends actually meet.
    I also carry a baggie of diabetic lancets. They are designed to prick your finger to get a drop of blood but are great for digging out splinters and are sterile.
  11. Apr 18, 2025 at 7:14 AM
    RichochetRabbit
    Spray saline, duct tape, real tweezers, 5% lidocane I will verify or fix.
    Tourniquet is to save lives, not limbs, but may be useful.
    I will more likely run into someone who knows how to use these and just wishes they were on-hand instead of me bumbling the ones needing training. But "I wish I had it" is something I hope to avoid.
  12. Apr 18, 2025 at 4:42 PM
    Yoda's TRD
    Yoda's TRD Well-Known Member
    David
    Haslett, MI
    2025 TRD Sport Hybrid
    I have the one the dealership gave me
  13. Apr 18, 2025 at 4:53 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Here. Pack can be ripped free with a minimal tug.
    Basic trauma plus tourniquets, chest seal, knife, bandaids, aspirin, burn cream, and moleskin.
    All the things a basic camper needs.
  14. Apr 20, 2025 at 7:59 AM
    NoCoTacoMan
    NoCoTacoMan Well-Known Member
    Brian
    Northern Colorado
    2010 TRD Sport V6 4WD Ext Cab Long Bed
    Stockish
    Great topic! Way too many people don't think to have even the basic first aid supplies with them. And even more don't know how to use them.
    One thing I would add to your first aid kits is some Benadryl for mild/moderate allergic reactions in the field. (Treating anaphylaxis in the field is a whole different story/topic.)
  15. Apr 20, 2025 at 8:27 AM
    Yoda's TRD
    David
    Haslett, MI
    I agree
    I used to carry band aids in my wallet for my kids up to the time they were knee high
    there was some magic to be able to put a Transformer band aid on a sidewalk scuffed knee to make it “all better “
  16. Apr 21, 2025 at 1:51 PM
    kcult
    kcult Active Member
    ChesCo, SC
    Cobalt Blue 95.5 Xtra cab 4x4 3.4L Taco
    A friend gifted me this one but I had to leave it in the garage for a few months to air out because I guess he smokes in his house and his truck.
  17. Apr 21, 2025 at 8:17 PM
    sflegends
    Colorado
    @NoCoTacoMan -- we're neighbors. Not sure what neck of the woods you're in but I could change my username to FoCoTacoman and we could form a posse :D
    Thanks to all who have contributed. In addition to the smattering of bandaids and bandages I already had, I also added meds, gloves, a SAM splint, an Israeli bandage, saline spray, a vented chest seal (guns abound out here), duct tape, and some z-fold gauze. I packed it all into an old med-kit fanny pack I had from back in college when I was on the CERT.
    As for placement, while I like the passenger kickboard placement best a la @Rock Lobster, my beloved felt like that was encroaching on her space, so I put some hook and loop onto the bag and stashed it between the rear jump seats.
    Rock Lobster likes this.
  18. Apr 21, 2025 at 8:19 PM
    TRD_Ferguson
    TRD_Ferguson Active Member
    Dalton
    2023 White Tacoma TRD Off-Road
  19. Apr 21, 2025 at 8:29 PM
    KSB
    KSB Member
    Paco
    2nd Gen Double Cab Long Boi
    Surprised more people havent recommended the MyMedic kits. That's what I was looking at getting. Plus you can use your HSA/FSA money on them.
  20. Apr 21, 2025 at 8:47 PM
    RichochetRabbit
    Interesting point about HSA $$. I selected a plan through work with $500 HSA (incremental through the year). And I probably could have used it last year when building my kit. A bit late to do it now ... would have to throw away a perfectly useful medical kit. Though I may add the larger would closures in post #18.
    All this for something you hope you never need anytime.
