Firestone say need to replace my rackandpinion
Discussion in '1st Gen. Tacomas (1995-2004)' started by taco03Trd, Jan 1, 2017.
  1. Jan 1, 2017 at 6:58 PM
    taco03Trd
    taco03Trd [OP] 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    So took my truck to firestone to recheck alignment and this was the answer from the service guy . Can't get to specs till i replace my rackandpinion and inner and outer tie rods . Any ideas where to buy a rackandpinion . Or should i check first before spending all this cash. How do i know if my rackandpinion is bad ?? Any help will be a preciated TW members .
  2. Jan 1, 2017 at 8:12 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    first, firestone regularly lies and replaces perfectly good parts to charge high bills because that's the ONLY way the mechanics get paid there.
    there is a "chance" they are being honest but I highly doubt it since they are telling you that you need the entire front end replaced since all it has is the rack and tie rods to it
    go somewhere else and I can almost 100% guarantee you that all it needs to get fixed and aligned is one tie rod or something and its fixed out the door for under $200
  3. Jan 1, 2017 at 8:20 PM
    taco03Trd
    Carlos
    Riverside ca
    Yea aim pretty good with my truck condition. Got an alignment done here a month ago but the truck pulls right so i took it back . And this was the answer. So aim going to check it tomorrow tied rods .
  4. Jan 1, 2017 at 8:26 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Your rack has inner and outer tie rod connectors. Firestone is assuming the rack is bad, not knowing the inner connectors are needed replaced.
    Pull the accordian boots back and you will see the inner tie rod connectors.
    I doubt the rack is bad.
    About a $150 to change all the tie rod connectors. $600 for a new rack.
    Check things closely before throwing money.
  5. Jan 1, 2017 at 8:31 PM
    taco03Trd
    Carlos
    Riverside ca
    Thanks koditten ill do all the work my self so no need for a machanic. But firestone say the rackandpinion was liking too thats why need to be replaced but i think it works fine . Would check the inner boots tomorrow .
  6. Jan 1, 2017 at 10:52 PM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    It might just be the bushings that mount the rack grab the rack and see if it moves easily
  7. Jan 1, 2017 at 11:01 PM
    taco03Trd
    Carlos
    Riverside ca
    Ill check them too . I know firestone just wants to make money but aim not stupid i know about this rids a bit more them they think ..
  8. Jan 2, 2017 at 1:12 AM
    pofarm
    pofarm Well-Known Member
    Greg
    SW MO
    1996 Taco
    Firestone sucks. They told me I needed a center link kit for a car I once had. I told them I would take care of it. I went to get the parts and was told there was no such thing. The center link is solid steel and didn't wear. Bottom line, they were going to charge me for parts and labor and do nothing...
  9. Jan 2, 2017 at 1:53 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Well do you need to keep adding Fluid to the Power Steering like once a week or more often??
    Big puddle under the truck??
    Under carriage coated with fluid from said leak.
    It is a shame shops try to sell things that are just fine
    File IFR likes this.
  10. Jan 2, 2017 at 4:29 AM
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    When I lived in CA, the Firestone I went to was awesome. Hooked me up all of the time.
    Moved here, and tried them out. At first, they were cool. Then after their remodel of the shop, they were trying to get me for a bunch of services that I didn't need. So I stopped going.
    Now, I stick to two local shops that are owned and ran by honest and hard working guys.
  11. Jan 2, 2017 at 7:54 AM
    taco03Trd
    Carlos
    Riverside ca
    Nop i dont need to add power steering fluid at all works fine to me . I do have a small engine oil leek but that is it . Yea this shop suck big time . They try to ripped the wrong guy off lol ..
    File IFR and keakar like this.
  12. Jan 2, 2017 at 8:21 AM
    AKTacoParty
    AKTacoParty Well-Known Member
    Jake
    Astoria, OR
    2013 DCLB
    885s, Dakars, Bilsteins, Allpro Sliders, Archive Garage Hammer Hangers, Wheelers Ubolt flip, super bumps, RCI front skid
    ^^^^This, I saw it everyday when I worked there.
    keakar[QUOTED] likes this.
  13. Jan 4, 2017 at 11:13 AM
    taco03Trd
    Carlos
    Riverside ca
    20170103_112322.jpg 20170103_112334.jpg update TW so i check my rackandpinion yesterday and only thing that i found was tie rods ends open . No leeks from rackandpinion or play on it. Firestone just try to robbed me.
    So should i change my inner tie rods too ??
    Thanks for the input
  14. Jan 4, 2017 at 11:14 AM
    taco03Trd
    Carlos
    Riverside ca
  15. Jan 4, 2017 at 11:22 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Not as sure about tie rod ends, but I often believe that things like that should always be replaced in pairs, like radiator hoses and the like. If one is worn out, the other isn't far behind...just check them all very closely, and if in doubt, replace. Better to be safe then sorry!
  16. Jan 4, 2017 at 11:27 AM
    taco03Trd
    Carlos
    Riverside ca
    Thanks was thinking of chaging both side i wasn't sure on the inner ones. I think there are good still.
  17. Jan 4, 2017 at 11:36 AM
    Roadeater
    Roadeater Well-Known Member
    Kennesaw, Ga
    2004 Black Tacoma Prerunner TRD V6
    How many miles on your truck?
    Not trying to make u spend more money, but if you already there, would be good to replace ball joints (both) before alignment. If they are still original ,it would be a good idea to replace them all together.
    Check steering rack bushing too.
  18. Jan 4, 2017 at 11:37 AM
    chaosrob
    chaosrob Well-Known Member
    I'm the same, when I replace the tie rods I replace the BJ's as well, all OEM.
  19. Jan 4, 2017 at 11:42 AM
    DeltaSteve
    DeltaSteve Social Critic
    FW,TX near TCU
    '09 White TRD access
    KING 2.0" PERFORMANCE SERIES REMOTE RESERVOIR COILOVER SHOCK W COILOVERS, TC UCA, OME DAKAR SPRINGS, RELENTLESS PLATE R BUMPER and MORE :)
    My only experience with Firestone was BAD....VERY BAD. If you do need advice I'd check around for a couple Tacoma World experienced mechanics and buy them lunch.
  20. Jan 4, 2017 at 11:45 AM
    Roadeater
    Kennesaw, Ga
    Firestone and PepBoys are the worst out there. PepBoys wanted to charge me 400.00 to cleanup my rodeo EGR valve. It took me 30 minutes to do it myself.
