Firestone said they cannot align my truck because its modified
Discussion in '3rd Gen. Tacomas (2016-2023)' started by My3rdgen, Dec 31, 2017.
  1. Dec 31, 2017 at 1:46 PM
    My3rdgen
    My3rdgen [OP] New Member
    Hello.
    Have a 2016 SR. Had a standard low end SR suspension.
    Had national chain 4wheelparts put Fox 2.0 with coil over up front and fox shocks in back to level and larger KO2 tires 265 70 R17. That's all. 4wheelparts installed and aligned with zero issues, great job.
    Was going to take advantage of Firestone's special they have on lifetime alignment.
    Firestone said that being truck was modified from stock they could not do it and probably did not have proper spanner wrenches.
    I have read here that people go to Firestone all the time. I have seen Fox 2.5 on dealer lots.
    What's the deal ?
  2. Dec 31, 2017 at 1:50 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    It depends on the Firestone. They are managed differently from location to location.
    I had a lift on my F250 and they allowed me to purchase and use my lifetime alignment. They promised to do the same on my Tacoma but I also promised them I'd be putting in new UCAs to make their lives easier too.
    It takes a lot longer to align a modified truck plus sometimes depending on the set up they won't be able to align it. So make sense not all will honor a lifetime alignment.
  3. Dec 31, 2017 at 1:52 PM
    NM Lance
    NM Lance Well-Known Member
    If the tech know what he is doing, he can align anything (within reason). If they are already making excuses, forget them and find someone who will do it with making a fuss.
  4. Dec 31, 2017 at 1:53 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    No problem here 5100 all round front set at 1.75.
    Where you located.?
    TXpro4X4 likes this.
  5. Dec 31, 2017 at 1:54 PM
    PackCon
    Connor
    Does the 1.75 give you a level or does your front end stick up higher?
  6. Dec 31, 2017 at 1:55 PM
    Atomic
    Atomic Master Cylinder
    New Mexico
    13 TRD Sport Double Cab Long Bed
    They're giving you BS. Mine's lifted with 6112/5160 Bilsteins, SPC UCAs, and new rear leaf springs. About a 2-3/4" lift all around. I got the Firestone Lifetime alignment.
    mcharfauros, jeff b and PackCon like this.
  7. Dec 31, 2017 at 1:55 PM
    Tiedie
    David
    WFOY
    Level. 275/65/16 rims
  8. Dec 31, 2017 at 1:57 PM
    Clearwater Bill
    Billy
    Largo Florida
    Spanner wrenches? As in to adjust the spring perches/shocks? That would be nuts.
    I don't do alignments, but I can't envison anything under there that needs a spanner, just less they are just using an old school name to dazzle customers with.
    I appreciate the 'deal' of lifetime alignments, but I find they are not worth it. The exception being that you know enough to find a tech at one of those stores who actually knows what he's doing, and is willing to take the time to do it right.
    I gave up on that, and just started using an independent shop. It's the one all the local truck mod stores send their messes to to get fixed. ;)
    I think the counter guy you talked to was blowing smoke up your skirt because he saw you as a potential 'frequent customer' (and a money loser) or he was just an ignoramus.
    scottalot likes this.
  9. Dec 31, 2017 at 1:57 PM
    PackCon
    Connor
    What cab/bed configuration? Taco Lean?
  10. Dec 31, 2017 at 1:59 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    X2
  11. Dec 31, 2017 at 2:00 PM
    Tiedie
    David
    WFOY
  12. Dec 31, 2017 at 2:03 PM
    Tiedie
    David
    WFOY
    No Taco lean Access cab long bed 4x4 and level
    PackCon[QUOTED] likes this.
  13. Dec 31, 2017 at 2:10 PM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Its not that they cant, they just dont want to. Find some where else to get alignments
    Atomic likes this.
  14. Dec 31, 2017 at 2:36 PM
    Victory
    Victory Well-Known Member
    St. Pete, FL
    2016 White Tacoma TRD Off Road
    They may not be able to get it within specs without adjustable Upper Control Arms such as the SPC units @Atomic has.
    I had the same issue with my old 4Runner when I first lifted it, to get the geometry right they need to adjust the UCA.
    The mention of spanner wrenches may have been because they could have to option of adjusting the coilovers lower to bring your angles back into spec, of course that would defeat the purpose of the coilovers.
    If you don’t have aftermarket adjustable UCAs you will most likely need them in order to bring your alignment back to spec. If you do have them and they still can’t align it, then they either don’t want to work on a lifted truck or aren’t competent enough to.
    My3rdgen[OP] likes this.
  15. Dec 31, 2017 at 2:45 PM
    modifiedtaco
    modifiedtaco Well-Known Member
    Alex
    2016 Magnetic Gray Tacoma Limited
    Tuff Country 3 inch spacer kit with aal Tuff Counrty 1/4" spacer on LF (for taco lean) Bilstein 5160 rear shocks Bilstein 5100 adj front struts (removed tuff country front spacers) set to 0 lift OME 886 coil springs Front sway bar relocation bracket N-Fab Rock Rails 17x9 -12 Fuel Beast wheels Toyo AT2 285/70/17 tires Led light conversion on all interior lights Morimoto 35w HID kit 5500k OE all weather floor mats OE Tonneau cover OE Door Sill Protectors Bed Mat De badged all factory emblems matte black vinyl tailgate letter and Tacoma emblem on door silver vinyl insert on glove box and door sill protectors OME Carrier Bearing Drop Insain Fab cab mount chop plates Weathtech Rain guards
    my best guess is that management at that location does not want to align modified cars.. They see a lifted truck which means that odds are you will continue to modify and if so then more alignments will be required then the average joe. life time warranty may not be worth it for them. aligning your vehicle is not different than aligning any other Tacoma.. as others have said if you don't have uca's then they may not be able to get caster within specs but that's on you not them.. they simply don't want you as a customer.. as others have said find another shop.
  16. Dec 31, 2017 at 4:02 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Technically, they are correct...
    Per the service manual, the first step in alignment is checking tires and ride height against factory spec.
    Factory alignment specs are based of these specs.
    The best they can do, is align to factory spec and see what happens with tire wear and steering.
    For example, if you have a wheel/tire that adds a lot of positive scrub, it might require more toe-in and zero to negative camber.
    Basically they are telling you they don't do custom alignments; only factory spec alignments.
  17. Dec 31, 2017 at 4:34 PM
    not0ny
    not0ny Well-Known Member
    2017 MGM TRD SPORT DCSB 4X4
    Bilstein 6112/5160 JBA UCA
    I gave up on firestone. they only corrected the toe on my truck the first few times. The last time I took my truck there they lowered the caster more and caused me to rub AND they flattened my stock alignment cam tabs. I'm getting TC alignment gussets welded on soon now. Hard to find a competent technician, I have given up on them and go to a shop that specializes in only alignments.
  18. Dec 31, 2017 at 4:39 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I can't really blame them. No way would I give a lifetime Warrentty to a person that I know is going require adjustments often. The aftermarket lift just made them more fearful of spending time and money they will never see again.
  19. Dec 31, 2017 at 5:02 PM
    Fortunt1
    Fortunt1 Well-Known Member
    Thomas
    Iowa
    16' SRT Charger...purple
    It’s definitely dependent on that store. I had my old Saabaru slammed and one would do it but the other wouldn’t.
  20. Dec 31, 2017 at 8:20 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    How often do you guys with lifetime alignment do it?
