Firestone lifetime alignment 1/1/20 only
Discussion in 'Deals & Coupons' started by Nu2taco, Jan 1, 2020.
  1. Jan 1, 2020 at 8:17 AM
    Nu2taco
    Nu2taco [OP] Well-Known Member
    J
    San Diego, CA
    2018 DCTRDOR4X4 AT
  2. Jan 1, 2020 at 8:54 AM
    Nu2taco
    J
    San Diego, CA
    2018 DCTRDOR4X4 AT
    Just bought it $119.79.. will schedule for the alignment another time
  3. Jan 1, 2020 at 8:58 AM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
  4. Jan 1, 2020 at 9:11 AM
    Ghostdrifter88
    Ghostdrifter88 Well-Known Member
    Henry
    Bay Area, CA
    2017 white OR DCLB
    Just called my local firestone and they wont do a lifetime alignment deal if the suspension has been modified. anyone else have this issue?
  5. Jan 1, 2020 at 9:15 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I got a lifetime one through Firestone a few years ago with my suspension modified no problem.
    I never use it anymore though because Firestone sucks at aligning vehicles with aftermarket setups. They just want to plug in the stock numbers and send you on your way.
    I haven't used the lifetime package in over a year, instead I go to a local 4x4 shop that does them and pay $125 each time. Firestone has never done a good job with my truck
  6. Jan 1, 2020 at 9:16 AM
    Ghostdrifter88
    Henry
    Bay Area, CA
    2017 white OR DCLB
    Dam too bad. I just called 3 different locations and they all said the same. Lifetime alignment for $120 is just a great deal!
    whatstcp[QUOTED] likes this.
  7. Jan 1, 2020 at 9:20 AM
    tcjacado
    tcjacado Well-Known Member
    20200101_092119.jpg stock set ups only.
    whatstcp likes this.
  8. Jan 1, 2020 at 9:29 AM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Try NTB. They worked with my modified truck.
    Our Firestone’s in St Louis are picky per location.
  9. Jan 1, 2020 at 10:00 AM
    Nu2taco
    J
    San Diego, CA
    2018 DCTRDOR4X4 AT
    I brought mine in and they got info on the truck didnt say anything about the truck being lifted 2” with 33” tires. Lets see if they say anything when I go for my appointment.
  10. Jan 1, 2020 at 1:16 PM
    GasPowered
    GasPowered Well-Known Member
    OK
    2016 DCSB TRD OR 4x4 SSM
    Are you having it aligned to factory specs, or "lifted" specs most people on here recommend?
    I bought a "lifetime" alignment from Firestone a couple of years ago before I "lifted" my truck (1.5"). I went in a few weeks ago to get an alignment and had to argue with them about aligning to the specs I wanted. They didn't want to do it at all. They will only do it to "factory specs".
    Make sure you check that the store will align your truck the way you want before you buy the lifetime alignment.
    Cheers
  11. Jan 1, 2020 at 9:30 PM
    Nu2taco
    J
    San Diego, CA
    2018 DCTRDOR4X4 AT
    Ok. I guess I don’t know any better. Can you post the lifted specs? Did they give you a refund if they didnt want to do an alignment the way you want it?
  12. Jan 1, 2020 at 9:51 PM
    GasPowered
    OK
    What I've read on here, and what my installer reiterated as well:
    Toe: as close to 0° as possible
    Camber: as close to 0° as possible
    Caster: as close to 3.5° +/-. 5°
    Note: you will need aftermarket UCA's to get caster as high as listed above.
    No refund. I'll see if I can transfer the "lifetime alignment" to my wife's car. If not, it's a $150 lesson learned... I guess.
    Cheers
    Nu2taco[QUOTED][OP] likes this.
  13. Jan 2, 2020 at 6:12 AM
    taco_boy
    taco_boy Antiplastidipper
    California/Land of the Fee
    2018 Tacoma TRD On Road MT
    Noob Taco owner
    Firestone techs are trash. I had my lifetime alignment refunded. They basically do a "toe and go" adjustment on all vehicles for a quick turn. Not recommended unless you're stock for life.
  14. Jan 2, 2020 at 9:12 AM
    eon_blue
    Azusa, CA
    I figured I'd keep mine just in case I wanted or needed a quick toe and go...like recently after I replaced my tie rods. Figure I just needed a toe and go alignment, not a full $125 one from the good place I go to.
    Firestone even managed to screw up the toe 'n go ...gave my truck back with the steering wheel more crooked than it was after I replaced my own tie rods.
  15. Jan 2, 2020 at 9:13 AM
    Bullnettles
    Bullnettles Well-Known Member
    Jared
    Houston
    2017 OR DCSB
    I was told keep it less than 1 per 6 months and they don't care.
    whatstcp[QUOTED] and tcjacado like this.
  16. Jan 2, 2020 at 9:17 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I have Pro suspension on my Sport. I have the Firestone life time alignment. What they told me is they “can only do what is in the computer.” So I tell them to do a Pro alignment.
  17. Jan 2, 2020 at 9:48 AM
    5678ta
    5678ta Well-Known Member
    Hogan
    Henderson, NV
    '18 ECLB Colorado ZR2
    That's a great deal. Or was a great deal.
    I've been in with two trucks probably 10 times now and have only been satisfied 2 or 3 times. Toe is always set off center so she pulls. I now go in only for the caster and camber printout, then readjust toe myself. I can usually get it straight in 3 tries.
  18. Jan 2, 2020 at 10:42 AM
    tacomarin
    tacomarin ig: @travelswithchubbs
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack VO Drifter LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Brute force front bumper BAMF HC Dual swing out 285/75r17 BFG KO2 Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
    Depends on the store. My local one is awesome. I always ask to talk to the techs when I ask for custom settings. They always do exactly what I want, even to the point of me hanging out in the shop with them while they dial it in. I've got SPC's and ADS coilovers and have never had any grief from them. Hopefully they don't get new techs any time soon because the ones they have now are excellent.
    The only issue I've had with Firestone is that they apparently have a policy that they can't put used tires on. I was swapping my tires from my old wheels to new ones and they said they couldn't do it. It makes no sense to me, especially since this is their policy even in places where people often have winter and summer tires.
  19. Jan 2, 2020 at 3:43 PM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    I had the same experience with my Firestone. Paid for the lifetime but it seemed to always veer to the right or come out of spec soon after getting it aligned so now o take it elsewhere to have it done right and I’m actually happier even though I am paying for the alignment every time. At least it gets done right.
    as far as the “modified” concern goes, Firestone was fine with it but said the lifetime is good as long as I don’t make any other suspension changes AFTER getting the alignment done. So if I got a Lifetime alignment without aftermarket UCAs, but then installed them later, I’d have to pay the full cost again.
    eon_blue[QUOTED] likes this.
  20. Jan 2, 2020 at 4:10 PM
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    my issue. I tried the life time twice. They didn’t get my alignment correct one time on either car, and each one was in there multiple times
    BeLance89 and eon_blue[QUOTED] like this.
