Firestone Air Bags with Lift?
Discussion in 'Suspension' started by greymachine, Jul 5, 2022.
  1. Jul 5, 2022 at 9:28 AM
    greymachine
    greymachine [OP] @taupetacoma
    SoCal
    19 Quicksand TRDOR 4x4 DCSB
    I'm lifted about 3" on Icon RXT leafs at option 3 (about 300 lbs constant bed weight) and want to get some Firestone Ride Rite airbags with Daystar cradles to compensate for the added weight of being loaded up for a trip (about 200 lbs), and my soon-to-arrive steel high clearance rear bumper (around 200 lbs).
    Are the air bags long enough to "engage" at 3" of lift, or will they only add support once the rear sags beyond 3 inches?
  2. Jul 5, 2022 at 11:51 AM
    httuner
    httuner Well-Known Member
    2015 Tacoma TRD-OffroadPckg
    AFe Rebel Catback Exhaust, AFe GT Momentum Air Intake, Method Wheels, Bilstein 5100, Rigid 30" SR2 Light Bar, Rigid 10" SR Light Bar. Lots of Love
    Sumo springs may also be a good answer to this; maintenance free and no worries about air leaks plus you can always add a spacer if you require it.
  3. Jul 7, 2022 at 1:42 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    200 pounds is nothing to worry about. The truck won’t even sweat.
  4. Jul 7, 2022 at 2:10 PM
    greymachine
    SoCal
    Sumos limit articulation off road from what I've heard. I don't want to limit my travel at all.
    As far as the weight effecting ride height, I already get about 1.5-2" of sag just from our camping load of about 200 lbs (maybe a little more). I think with the added weight of my inbound steel HC bumper (yet another 200ish lbs) it'll sag even more.
    I'm just wondering if the Firestone bags will extend to the lifted 3" of height that I'm running now, and keep it there with enough PSI, or if they don't have any effect until the truck sags past the stock ride height.
  5. Jul 7, 2022 at 6:03 PM
    gudujarlson
    Minnesota
    Are you measuring these differences in ride height or just eyeing it?
  6. Jul 11, 2022 at 8:07 PM
    greymachine
    SoCal
    Eyeballing it. I can clearly see that the truck sits noticeably lower when loaded up. When I eventually add the weight of a steel HC bumper out back, it's definitely going to sag more.
    I'd rather not get a stiffer leaf pack as the truck rides so well with the RXTs on option 3 with the constant 300 lb weight, so I'm hoping to find a solution for the occasional heavy load that won't hinder travel or articulation when wheeling.
    So...the specific question I'm asking remains...does anyone know if the Firestone bags will help prevent sag if you're lifted beyond stock height?
  7. Jul 11, 2022 at 8:22 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Sorry man.. you're getting a stiffer ride either way. It may not be very noticeable but the way the ride rite airbags attach to your leaf spring they restrict a couple inches of the center of the spring from moving.
    ..and to answer your first question yes the airbags can raise your 3" lift even higher if you inflate them (enough.) I typically run my airbags at the 5 psi minimum unless towing.
  8. Jul 12, 2022 at 5:52 AM
    greymachine
    SoCal
    Thanks, that's the info I was looking for. I'll pull the trigger on a set soon.
    Gen3TacomaOBX likes this.
  9. Jul 19, 2022 at 2:07 PM
    jakub4
    jakub4 Active Member
    Jakub
    Calgary, AB
    '11 DCLB Sport in fast blue
    ADS shocks, Dakars, Lots of custom electrics, too much money spent
    don't forget to consider daystar cradles, they'll allow the airbags to sit freely on the bottom, so they sort of float on the bottom. Someone made an adapter if you did a u bolt flip as well, but it's fairly easy to make some out of 1x3 tube steel
  10. Jul 19, 2022 at 3:11 PM
    greymachine
    SoCal
    Yep, mentioned that in the 1st post. I wouldn't consider bags otherwise, I use every inch of travel I have. This would've ripped the bags apart if they were attached on both ends:
    eurowner and TVH475 like this.
  11. Jul 19, 2022 at 3:18 PM
    Gen3TacomaOBX
    S
    fwiw I've had the wheels hanging by the bags a bunch and haven't ripped them yet but the little wheelin' I do is slow and controlled. I should get the cradles BUT I really don't want the chatter. :lalala:
  12. Jul 19, 2022 at 3:22 PM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    With airbags, it will ride rough without extra weight, from my experience.
    Cushmaat and Gen3TacomaOBX like this.
  13. Jul 19, 2022 at 3:25 PM
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    OME 3” lift, +660lb springs out back, Daystar cradles and RideRites on there too. No issues. Actually the only problem is you need a little extender on the axle support due to the thicker spring pack…. When the camper is off I run 5# of air and it’s FINE!!!!
  14. Jul 19, 2022 at 5:17 PM
    greymachine
    SoCal
    Great info, thanks!
  15. Oct 9, 2022 at 9:34 AM
    jasontylers
    jasontylers Well-Known Member
    JT
    2016 Tacoma TRD Off Road
    None.
    Exact same setup as me (except they sent me 3" spacers instead of recommending the daystar cradles) Did you need any spacers at the bottom of the bags? I’m noticing my spacers are almost too much lift and don't allow enough compression of the rear for full articulation. Even with the bags at 5psi, the rear sits pretty high. Now I'm wondering if the daystar cradles would have been the answer.
  16. Oct 19, 2022 at 4:58 PM
    kucelkj
    kucelkj Member
    Ken
    Ambridge, PA
    2011 SR5
    ARE cap, bed rug matt, Weather Tech floor mats, Toyota skid plate up front, kick butt flashlight and a 38 snub nose.
    These work well but offer a very rough ride. I have them on my 2011 tacoma.
  17. Oct 20, 2022 at 8:53 AM
    jasontylers
    JT
    None.
    Yea that was my thought. I also change the weight on my truck quite a bit and remove the Four Wheel Camper often. Therefore, I am loving the ability to adjust the air pressure in the Firestone Airbags that I just installed. They are amazing and solved the problem perfectly. Now, the only issue is realizing the fact the sticker on my truck says not to exceed 1,000 lbs with gear and passengers. That means my camper + me is already exceeding that. I hope Toyota means the suspension components and not drivetrain establishing this number. Oh well, the Tundra has barely more payload capacity so...
    SaBiN's Blue Bandit likes this.
  18. Jan 29, 2023 at 9:41 PM
    smol-trux
    smol-trux New Member
    07 longest everything 4x4
    Hey man, what did you use for an extender?
    EDIT: in case anyone reads this, turns out the bolts to attach the mounting plate to the leaf springs are called carriage bolts - I bought some some 3/8" - 16 x 6" (4.5 or 5" would have worked but I could only find 6" at the store)
  19. Feb 7, 2023 at 4:10 PM
    YOTA 4X4
    Bought the extension plates from OK4WD in NJ and welded them on and then a couple coats of spray paint. Gtg.
    smol-trux[QUOTED] likes this.
  20. Apr 12, 2023 at 10:15 AM
    JimBob151
    JimBob151 Member
    2022 MGM OR
    OME 2.5” Medium Rear (600); Decked, Leer
    I have almost exact same suspension. OME 2.5" Lift Medium Load Kit with 600 pound rear springs. For my clarification: You did not use a Firestone lift spacer under the daystar cradle? You did mention an "extender" you bought from OK4WD. Shall I assume this was your "lift spacer"? I figured I may as well ask rather than assuming. Great looking truck btw.
