firestik "fire ring" coax cable?
Discussion in 'Technical Chat' started by DreDog, Dec 13, 2011.
  1. Dec 13, 2011 at 10:45 PM
    DreDog
    DreDog [OP] Well-Known Member
    Andrew
  2. Dec 13, 2011 at 11:37 PM
    superwhite10
    superwhite10 Well-Known Member
    Garner, NC
    im using it with no issues. been on for about 9 months. i know of a couple other members on here using it with no issues as well
  3. Dec 13, 2011 at 11:48 PM
    DreDog
    Andrew
    do you have the one you have to solder together? or the one with the FME connector?
  4. Dec 13, 2011 at 11:55 PM
    superwhite10
    Garner, NC
    uhh wasnt aware there were 2 different ones. only thing i had to solder was the coax to the plug that goes to the cb
  5. Dec 13, 2011 at 11:59 PM
    DreDog
    Andrew
    thats what im kind of nervous about. does it all come in the package? the connector and stuff
  6. Dec 14, 2011 at 2:25 AM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    Everything in package. The crimp on ring terminal makes running the coax easy as there is no obstructive connection. You crimp on the terminal at the end.
  7. Dec 22, 2011 at 10:53 PM
    DreDog
    Andrew
    How did you ground yours?
    Does it have to be grounded?
  8. Dec 22, 2011 at 10:53 PM
    DreDog
    Andrew
    Can I ground to the stud?
  9. Dec 23, 2011 at 6:13 AM
    Rellik01
    Craig
    Windermere, Florida
    I have the "no ground plane" cable so grounding is not an issue. mine is mounted to my aluminum toolbox, works fine.
