Fiberglass Fender Painting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jdkeller, Jul 23, 2011.
  1. Jul 23, 2011 at 12:41 PM
    jdkeller
    jdkeller [OP] How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    I want to finally paint my front fenders silver to match my truck. Who has done it? I will be using a paint sprayer. Where is the best place to get the paint? How much do I need to do the 2 front fenders? A quart? Also, do I have to prime, then silver, then clear? How many coats of each. I've sprayed houses before but never car parts. Thanks for the help.
  2. Jul 23, 2011 at 4:23 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Mine were painted for free under a TSB for our trucks...:cool:
  3. Jul 23, 2011 at 4:34 PM
    rcfreak201
    rcfreak201 Well-Known Member
    subd, since i want to re-do mine as well, OP what fenders did you get?
  4. Jul 23, 2011 at 5:18 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    All pro. Match my width perfect with the spindles and wheel spacers. I need a front bumper now. Lol
  5. Jul 23, 2011 at 8:35 PM
    sun
    sun Well-Known Member
    Memphis
    2011 PreRunner
    Pioneer avic-z130bt with axxess aswc and rear cam mod, audiovox 10 flip down monitor, Pyle pl76d headrest monitors, kicker cvr tens wired down to one ohm with hifonics Brutus 1200.1, Clazzio seat covers, 20% tint on front windows, polished factory exhaust, peragon retractable bed cover, pop n lock tailgate handle with dei actuators for automatic lock, viper 5901 alarm remote start with viper smart start, hid bixenon 4500k headlights with 4500k fog lights, led map license plate lights and dome lights
    you can probably go to a automotive paint shop and get all the material you need there. i usually use dupont but there are plenty of brands out there. for just the flares you would probably only need 1/2 a pint since with the reducer it will total to be one 1 pint this is if your brand of paint is a 1:1 ratio. yes you do need to scuff then primer and then wet sand that with some 400grit for a smoother finish, and then 2 coats of base and 2-3 coats of clear. shouldnt be 2 hard a few of my friends painted houses b4 and became really good automotive painters
  6. Jul 23, 2011 at 8:41 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Thanks man. And do I wet sand after all coats of primer and after all coats of silver? Or just the primer?
  7. Jul 23, 2011 at 9:50 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    The more you sand, the better it comes oout normally
  8. Jul 24, 2011 at 1:10 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Ok. I'll keep that in mind.
  9. Jul 24, 2011 at 3:39 AM
    sun
    Memphis
    2011 PreRunner
    Just wet sand the primer most base color have a certain amt of time it needs 2 b clear coats for beter adhension....u don't wanna wet sand that unless u have run...and just curious op what kinda of equipment r u gonna use 2 lay the paint down
  10. Jul 24, 2011 at 8:42 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    My stepdad has a sprayer and and my neighbor has one too. Not sure what model. Haven't looked. But I'm not going for perfection. just want it to be a little better than a spray can. But if it looks perfect then hey, i won't complain. Lol
  11. Jul 24, 2011 at 9:16 AM
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
    Make a small booth inside your garage if you can. Using plastic sheets and lay the fenders down nice or hang them for paint.
    The more you prep, sand, and secure the paint booth. The better it will come out. I mean, Steve (Bajamoon) Rattle canned his and they came out ok. It was nice but not perfect. If you do all the other stuff with a spray gun. It will come out much better.
    God Speed my White Brotha. . . .Don't let the fenders come out like your DUNLOP Shirt.
  12. Jul 24, 2011 at 9:23 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Thanks Ray. Garage is a no go. Too much stuff in there. Lol
  13. Jul 24, 2011 at 9:26 AM
    RAD
    Rad
    LAX & LOGAN
    ^ Hang strings outside on the side of your home. Make it into a box. Then hang the plastic sheets to form a Booth. Then tape the edges of each sheet. That will make a pretty decent booth.
    YOu want to keep dust and small particles off the paint while it dries. ​
  14. Jul 24, 2011 at 9:58 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Ok. Ill give it a shot. Seems like a lot of work for some all poo fenders.
  15. Jul 24, 2011 at 10:04 AM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    Usually the wetsanding removes all or almost every all the imperfections.
    Good luck
  16. Jul 24, 2011 at 10:08 AM
    KevMc
    KevMc Well-Known Member
    Kevin
    West Columbia, SC
    06 TRD Sport DC LB
    Satoshi with Hella 500FF's Readylift N-Fab Rear Runner w/ Westin lights TRD Seat Covers
    You'll get lots of opinions but what I do with 'glass is sand with 180 using a flexible block, the I always use an epoxy primer to seal 'glass stuff, then prime with a 2K urethane primer. When that dries wetsand (using a block)with 400 then 600 since it's a metallic. Sometimes I will shoot another coat of reduced epoxy as a sealer under metallics to fill any tiny sand scratches as they can show, but as long as you dont sand through the primer back down to the gelcoat you probably won't need to. Might as well get a pint of basecoat, you'll probably want to spray something else later. Get the right reducer for whatever the temp is. Don't just use laquer thinner.
    With silver be careful to not let the metallic mottle or tiger stripe. Criss cross your first two coats then fog on the last in a random pattern, not too wet. That will help it from getting blotchy.
    Three coats of clear will give you plenty of room to fix boo-boos like runs and trash.
    If you don't want to spend a bunch of $ PPG Omni line is inexpensive and easy to use. MBC basecoat and their Production Clear is very easy to spray and buffs out nice if you want to go that far. Good luck.
  17. Jul 24, 2011 at 10:18 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Thanks for all the info. I'll definitely be referencing your post. Lol
  18. Jul 24, 2011 at 4:30 PM
    sun
    Memphis
    2011 PreRunner
    if you gonna use a house spray gun it may not work out since automotive paint is thinner than house paint. another thing about the guns is that most of todays house paint is latex while automotive paint is enamel, urethane, etc etc the chemicals may tear up the gaskets in the house spray gun...and the tips on the house spray guns are a bigger nozzle size than most automotive spray guns fyi it may work out for ya but just wanna give you the heads up...
  19. Jul 24, 2011 at 7:06 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    I'm not using a house sprayer. I have an automotive one. I just haven't used it before.
