Fender Trimming! So many people, so little info.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BohlaaH, Nov 19, 2015.
  1. Nov 19, 2015 at 12:02 PM
    BohlaaH
    BohlaaH [OP] Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    Do any of you guys running trimmed fenders have a tutorial on how to do so? I have googled and searched to find only one video which is pretty mediocre. I took it into my own hands this summer to trim my fenders a bit at the heel of the front fender to get some turn radius back. After using a BFH, dremel, grinder, etc. nothing is fixed. Also, I have cut the cab mounts, and am looking into relocating those as well. I am on the edge of even buying glass cause I don't want to do a sketchy cut on my fenders. Thanks. This is what I want it to look like after the cut, these guys did a really nice job.
    raco.the.taco likes this.
  2. Nov 19, 2015 at 12:09 PM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    What's up dude. So basically what I did was I cut my sheet metal fenders underneath with a grinder cuz they get covered back up anyways and they didn't need to be super precise (even though I tried to be super precise) and then I cut my plastic fenders with a dremel for precision. I just zip tied mine back to the truck and they've held up great. Although they do sell the little clips pretty cheap if you break a lot of them during removal and don't want to use zip ties. Someone else recently asked about cutting they're fenders and I gave them a quick step by step of what I did.
    1. Remove plastic splash guards inside of fenders
    2. Remove plastic fenders
    3. Make sure to put low tack painters tape from the bottom edge of the plastic fender to 3 or 4 inches up.
    4. Use a cheap drawing compass, adjust the compass to 2.5 inches (or how ever much fender you decide you'd like to cut off), take stationary end and run it along the bottom part of the plastic fender while the lead end marks the line to cut all the way along the plastic fender. (you can then trace with sharpie to see better)
    5. I used a dremel with a small cutoff wheel to cut the line on the plastic fender.
    6. Use low tack painters tape to tape the sheet metal fender from the bottom of the fender to 3 or 4 inches up.
    7. Use the drawing compass and repeat the same steps on the sheet metal as you did on the plastic fender.
    8. On the bottom right side, middle, and bottom left of the sheet metal part of the fender I scored the line with a grinder so that I could bend back little tabs so that I could screw or bolt in new plastic sheeting for splash guards. It's optional for you if you'd like. Pictured below.
    9. Cut out sheet metal line with a grinder.
    10. I bought plastic car door edge trim to put on the plastic fenders to make them look nice.
    11. Put back on the plastic fenders (I broke a lot of the clips so I used zip ties)
    When doing the rear you will have to remove a couple brackets that help brace the bedsides and tweak them to be able to adjust to the new cut fenders
    I don't think I left anything out. But just in case I left anything out you can totally refer to Slimwood Shady's 09 Access Single Cab Build starting on page 39. Let me know if that helps.
  3. Nov 19, 2015 at 12:09 PM
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    This write up is on my build. Page 14 towards the bottom
    This is how my cut fenders look
  4. Nov 19, 2015 at 12:23 PM
    BohlaaH
    ALEX
    2015 TRD Sport DCLB
    I was creeping you earlier today... :anonymous: lol deadly write up! cant believe I didn't think to use the "old" edge for a stencil of the new!! Only thing is, the car door edge thing, where does this go? Also, I have gotten clips from body shops before! they have buckets of dose tings. Ps, beaut truck. Mine is getting there...
  5. Nov 19, 2015 at 1:08 PM
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    Haha right on bro! Thanks I'm glad it helps you. Sometimes we overlook the most simple things haha. Once you cut the fenders it will go on the edge of the plastic flare like so
    Nice, scoop some of those clips up cuz you're likely to break some during removal.
    Thanks man I really appreciate it. Love working on my truck! From what I can see in your profile pic, you got a sweet truck yourself! Let me know if you have any other questions and I'd be happy to help
  6. Nov 19, 2015 at 11:56 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Just a heads up I would not cut the fenders with a grinder....too hard to get a rounded line. I bough a jig saw at HF for $15-20 and it cut like butter and comes out straight, lines are as straight as what you mark ;-). Use metal blades for fenders and fine wood blades for the flares. Also, cut the fenders 1/2 more than the flares otherwise you'll see both cuts.
    It's one of those things you just have to nut up and do.
    llibrm, justtito, dborrer and 3 others like this.
  7. Nov 20, 2015 at 12:46 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I'd start by dumping the flairs before they fall off on a trail somewhere, then get some sheetmetal snips or even a good box cutter & whittle away on the plastic...
  8. Nov 20, 2015 at 1:04 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    If he's running 35's snipping some plastic won't do it LOL
  9. Nov 20, 2015 at 1:27 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    In that case just pull off fenders & bedsides...sooner or later they'll get ate up ...:D
    JKU3000 likes this.
  10. Nov 24, 2015 at 8:28 PM
    BohlaaH
    ALEX
    2015 TRD Sport DCLB
    I will post some after pictures hopefully the coming weekend. But up is right. Thanks mopwho, great write up.
  11. Nov 24, 2015 at 8:53 PM
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    :thumbsup:
  12. Sep 1, 2019 at 4:48 PM
    AppleJax
    AppleJax Active Member
    That’s a great looking setup, what size tires are you running?
    Shmellmopwho[QUOTED] likes this.
  13. Sep 1, 2019 at 5:10 PM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    I used a jig saw and a high tech piece of wood and a sharpie to mark where to cut my fenders and flares. It's all in my build. Next up is fire wall tubbing, cause I need more room for activities
    JKU3000 and Corny Taco like this.
  14. Sep 2, 2019 at 7:32 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Exactly what I did. The high tech wood was clutch! Ha but really jigsaw and a good sheet metal blade and cuts like butter.
    30233E11-A119-4FF1-AD98-78B08C2B1313.jpg F216BBD9-7700-4A93-827E-7E4393C7C398.jpg
  15. Sep 2, 2019 at 7:43 PM
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    Thanks man. I appreciate it. Truck looks a bit different now. Running 35’s
  16. Sep 2, 2019 at 8:37 PM
    TYetti
    Mat
    They key was the zip ties holding the fender flares on 4 years and many trails later and they're still going strong
  17. Sep 2, 2019 at 10:16 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Definitely jig saw for both fenders and flairs.
    mistermanny likes this.
  18. Sep 2, 2019 at 10:43 PM
    nudavinci64
    Robert
    I went dremel on the flares. Melts it a bit for a nice finish. Jig saw for sure. I ended up having my bed cut for my HC and they used a grinder and felt it was not as clean as the jig saw.
    Alexely999[QUOTED] likes this.
  19. Sep 3, 2019 at 6:54 AM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Yeah when I first started cutting my fenders I grabbed a grinder and hated how it was going so I switched to jigsaw. Oh and make sure it’s a new blade would be good advice lol. Otherwise the blade will grab/bind and almost pull the fenders off the truck!
    JKU3000 and nudavinci64[QUOTED] like this.
  20. Sep 3, 2019 at 6:57 AM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
