favorite wax
Discussion in 'Detailing' started by muskratX22, Aug 19, 2020.
  1. Aug 23, 2020 at 9:47 AM
    #61
    gorram
    gorram Well-Known Member
    2016 Limited
    303 didn't last that long for me when I used it on the exterior, but you can always keep topping it I guess. It's hard to know how good the UV protection is on any of this stuff, just because it doesn't bead or have the look that it's there doesn't mean it's not still protecting. PNS probably would protect longer but maybe 303 does better in the short run. Usually a good rain or two and 303 seems to be gone. Definitely good for interior but like the exterior there are no end to good products available to use on any surface.
    More so than paint since you have more options to enhance or clean up paint I'd recommend something that was a trim coating instead. Many detailing brands have them, something like Carpro DLUX for example. Particularly if you're going to be using Solution Finish. Let the SF dry and see if you need to go further with another application if needed or splotchy. When you're fully dry (24-48 hours) and no residue wipes up then apply a trim coating. Carpro DLUX for example can be used on metal too, high temp safe so great option for wheels too.
    ardrummer292[QUOTED] likes this.
  2. Aug 23, 2020 at 10:02 AM
    #62
    ardrummer292
    ardrummer292 500k or bust
    Austin
    Virginia Beach, VA
    2015 DCLB V6 A/T 4x4 1D6
    Overbuilt daily driver
    I figured there were specialty trim coatings out there, but I’m not keen on accumulating a pile of different specialized sprays when one will do the job adequately. All my maintenance stuff is kept in my toolbox, so space is at a premium. If I can get away with using PNS on all my exterior stuff, great. If I have to get a specialty coating just for trim, that’s fine too; I just need to determine what other fluid will be removed to make space.
  3. Aug 23, 2020 at 10:20 AM
    #63
    gorram
    2016 Limited
    The Trim coatings usually come in a small 30ml vial which is more than enough for two cars even with multiple coats. Though once opened it needs to be used up.
    From CarPro: *This coatings shelf life expectancy is approximately 12-14 months unopened, and 6 months or less once opened.*
    ace96 likes this.
  4. Aug 23, 2020 at 10:29 AM
    #64
    BABAR
    BABAR Well-Known Member
    PNW
    '22 4runner ORP
    This is what I've been using lately too. Love it so far.
  5. Aug 23, 2020 at 10:29 AM
    #65
    ardrummer292
    Austin
    Virginia Beach, VA
    I guess this is my actual question: is PNS just a sub-optimal choice for trim, or will it outright not work at all? I place a higher premium on maintaining mechanical function of the vehicle, so all this exterior coating stuff is more of an afterthought.
  6. Aug 23, 2020 at 11:04 AM
    #66
    gorram
    2016 Limited
    There is always a better product to the point of having a whole arsenal of products. Products just meant to prep to apply other products, products to top other products, just depends on how deep down the rabbit hole you want to go. I can't speak to how your experience will turn out other than to recommend at least as far as trim goes to use a more durable product for it. Just look around at other vehicles and notice how awful the trim can get even in a few short years. The paint on the other hand will fair well if you just wash it and use some kind of spray wax/sealant/coating. All products still need to be cleaned after and either topped up or cleaned and reapplied at some point in time. I was just saying that something like 303 could last you two weeks, DLUX should last you many months. I'm sure PNS will fair somewhere in between but vary from user to user. Keep the truck in a garage and 303 will hold up well for example.
    I don't see any loss in you giving PNS a try to see if you like it, got to start somewhere.
  7. Aug 23, 2020 at 1:24 PM
    #67
    Gus
    Gus Well-Known Member
    Wayne, Pa.
    2020 Access Cab SR Utility Package Barcelona Red
    Rear sliding window, intermittent wiper switch, center console tray, glove box organizer shelf, WeatherTech front mats and mud flaps, 3D MaxSpider behind-the-front-seats mat, bed lights, MESO climate control rings, XPEL tailgate protection, Desertdoesit.com seat jackers, RAV4 radio knobs, glove box letters.
    Used Collinite again today after first trying it 4 weeks ago. Washed the truck 2 times since and the wax held up good as far as beading. Also tried Mother's Speed Spray wax and that kind of compares to Turtle Wax Ice spray. Here's a pic of my tailgate after Collinite...can you spot my reflection?!
    TOMRR likes this.
  8. Aug 23, 2020 at 3:29 PM
    #68
    Kabanstva
    Kabanstva Well-Known Member
    Col 845 was always my go to back in 2010-2012 when waxes were still the thing to use. Ceramic and Hydr02 (for maintenance) since I stopped using wax, so much easier and more effective.
    However, of all the waxes I've used, 845 seems to be the easiest to apply and cheap. Menzerna Powerlock would be my second choice, equally as easy to apply (with a machine).
    ace96 likes this.
  9. Aug 23, 2020 at 8:11 PM
    #69
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    I always liked 845. Another favorite is Wolfgang Fuzion. I bought the small container and it would last forever it seemed. Felt like the wax melted as you applied to the pad.
    Kabanstva[QUOTED] likes this.
  10. Aug 24, 2020 at 8:03 AM
    #70
    S550ilver
    S550ilver Well-Known Member
    Bartlett, TN
    2019 Tacoma Double Cab TRD Off-Road
    ICON Stage 5 Lift, 18x9 Fuel Shok, Nitto Ridge Grappler 285/65/18 tires
    Shine Supply Cherry Silica Wax, mix in a couple sprays of Shine Supply Clutch...And apply. A Great Combo!!!!!!
    ace96 likes this.
  11. Aug 24, 2020 at 11:59 AM
    #71
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Just to be clear - since I like both products - Collonite 845 is a true wax. Jescar Power Lock is a synthetic sealant. Having used both, the Power Lock goes on and comes off easier - and lasts at least twice as long. And yes, coatings last much longer than either of the above.
    ace96 likes this.
  12. Aug 25, 2020 at 7:31 AM
    #72
    AMarkham40
    AMarkham40 Well-Known Member
    Roanoke, Virginia
    2014 MGM DCSB TRD O/R
    once a year after every wash (excellent UV protection. I use it on everything: paint, plastic & rubber) every couple months for an extra pop
  13. Aug 27, 2020 at 10:45 AM
    #73
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
  14. Aug 27, 2020 at 10:50 AM
    #74
    CusterFan
    If I ever am blessed again to live in the country I'll get my truck Line-X'ed. You cannot keep one looking shiny like my asphalt queen driving on gravel & dirt roads. I would not even try.
  15. Aug 27, 2020 at 11:03 AM
    #75
    CusterFan
    ace96 likes this.
  16. Aug 29, 2020 at 9:42 PM
    #76
    Tamagotchee
    Tamagotchee Well-Known Member
    SWVA
    2019 TRD Off Road Tacoma
    This. It’s the only wax I will use. I’ve tried others, but they never compare.
  17. Aug 30, 2020 at 7:58 PM
    #77
    CusterFan
    If I had a inside parking spot I would use Carnauba wax on my truck. They say if your truck/car sets outside in the sun, like mine does all day, the sun will melt the carnauba wax right off the paint.
  18. Apr 17, 2021 at 7:58 AM
    #78
    BRBNNEAT
    BRBNNEAT Well-Known Member
    Madison, WI
    2021 TRD Offroad-6 speed
    Griots 3-1 Cermanic
    Any of the Collinites
    Megs Ultimate fast finish
  19. Apr 27, 2021 at 8:45 PM
    #79
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    Turtle Wax Flex is my go to now. I used Turtle Wax Ice for years but this new product is fantastic. I use the paste for the base and the spray for upkeep.
  20. Jun 13, 2021 at 8:58 AM
    #80
    alove0750
    alove0750 Well-Known Member
    Adam
    Concord, NC
    2015 DCSB 4x4
    Icon coilovers, shocks and springs SPC Upper Control Arms SCS Ray 10’s w/ 265/70R17 BFG KO2’s Leer 100XR shell
    I applied Chemical Guys Hydro Slick, after using there VSS Scratch and Swirl Remover. My dad and brother have been using it for a few months and had great results with it. Very easy to use and the truck looks like new.
