Favorite UCA?
Discussion in 'Suspension' started by Danduffy123, Aug 4, 2021.
  1. Aug 4, 2021 at 9:58 AM
    Danduffy123
    Danduffy123 [OP] Active Member
    Dan
    Hudson Valley, NY
    2016 Toyota Tacoma TRD Sport
    Hey guys and gals, lifting my 3rd Gen Tacoma. Going to grab a set of UCA but which is your favorite?
    I’m running icons on everything else, should I just stick with the icon tubulars? Keep everything uniform or is there one you prefer? Let me know! All pics are appreciated
  2. Aug 4, 2021 at 1:37 PM
    OldFashioned
    OldFashioned Member
    Luke
    2020 Tacoma TRD Pro
    drizzoh and Danduffy123[OP] like this.
  3. Aug 4, 2021 at 1:47 PM
    Danduffy123
    Dan
    Hudson Valley, NY
  4. Aug 4, 2021 at 9:03 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Spcs. Balljoints which are nice instead of uniballs, and they have all the adjustment you'll need. Helps to push the ifs forward to clear the cab with bigger tires.
    71tattooguy and Bishop84 like this.
  5. Aug 5, 2021 at 7:39 AM
    TVH475
    TVH475 Well-Known Member
    Montrose CO
    I like my spc's for the adjustability
    71tattooguy likes this.
  6. Aug 5, 2021 at 3:43 PM
    JDPNW
    JDPNW Well-Known Member
    S. Oregon
    2021 DCSB TRD OR Cement KDMax-Pro
    Eibach 2.0,SPC UCA,ECGS,ATS 4/1 rear leaf,5.29
    I have a set of JBA's and now after my second trip to the alignment shop the owner of the shop suggested I had gotten SPC's. There is nothing wrong with the JBA's and the reason for the shop visits was because of a few mishaps with unseen obstacles that cause the alignment to go out of whack. He explained the SPC's have much more adjustability options and whether I've started bending stuff or not I'm getting close to tolerance max on my camber. I had to have my JBA's replaced due to powder coat imperfections and the staff was super to talk to and deal with....and the pop of that red....
    EDIT: Also verify your current wheel/tire combo if going with the JBA's...there are restrictions.
    I'd say either will prolly do the job.
    Fedup13 likes this.
  7. Aug 6, 2021 at 4:48 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    I vote spc
  8. Aug 6, 2021 at 6:10 PM
    Mallrat60
    Mallrat60 Not all of us in CA are libs.
    Nor-Cal, Sacramento area
    2015 Dbl cab L/B 4X4
    ADS 2.5 #700 springs, RCI metal fab full skids, JBS UCA, OME rear leaves, Fab Fours front, and rear bumpers, BAMF Rock Sliders and other stuff
    You can't beat JBA. I just installed the HD's with ADS 2.5's and love them. I love that you can grease them. and they are sealed
    crashngiggles likes this.
  9. Aug 6, 2021 at 7:29 PM
    Summers_Kytaco_19
    Summers_Kytaco_19 “I did that in 2wd” rdpoe
    Steven
    Independence, KY
    19 trd OR tacoma
    I’m install JBAs tomorrow. For the price point, they’re impossible to beat. Great quality, great customer service! Definitely recommend
  10. Aug 7, 2021 at 1:31 PM
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    I was looking into both of those options since I live in the midwest and don't want to deal with uniball joints and salty roads. I'm curious how much the 2022 TRD Pro UCA's will be once they hit the parts departments as well.
    Also curious, whats the deal with the washers under the ball joint in one of the pictures?
  11. Aug 7, 2021 at 1:35 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    I’m wonder if the the 2022 UCA’s are SPC’s. They kind of look like it.
  12. Aug 7, 2021 at 9:09 PM
    brwntms
    brwntms Well-Known Member
    I use total chaos uca with emf ball joint. It’s completely seals and regreasable. It doesn’t pit like a typical uniball through rough condition.
  13. Aug 7, 2021 at 9:17 PM
    taco_rhyno
    taco_rhyno Well-Known Member
    06 DC 4x4 Sport
    I have JBA high caster. They have been on 3 years now with no issues. Easy to keep greased. Had my truck aligned yesterday while in getting a wheel stud replaced. 4 degrees of caster!
  14. Aug 8, 2021 at 8:15 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    SPC’s over here :thumbsup:
  15. Aug 8, 2021 at 8:23 AM
    NorNev
    NorNev Phone? Call someone who gives a shit.
    Dave
    39° 31′ 6″ N, 119° 59′ 19″ W
    KDMAX Tuned 17 2•2X2•2 Hood Scoop
    A Few
    Jba going on four years strong.
  16. Aug 8, 2021 at 1:32 PM
    TacoFergie
    Iowa
    To me it looks very similar to the Icon Billet UCAs except for the bushing area since they don't have the heim joints and the TRD ones use rubber bushings. Probably for longevity and drivability reasons. Unless they are going be made by Fox (and yet to be released), which is most likely since the truck is using Fox suspension. Also another difference is the the TRD ones have the ball joint at a slight angle, whereas the Icons do not. I haven't been able to find any info on the TRD UCA's at all. My guess is they won't be cheap through Toyota, but I'm very curious how much they will be.
  17. Aug 8, 2021 at 5:39 PM
    ohcaltexscar
    ohcaltexscar Out of Huckleberry Licorice…
    Chas
    El Paso, Texas
    2005 DCLB SR5 Prerunner
    IM4x4 2.5" NitroGas - Coopers
    Ironman 4x4 makes a mean ProForged UCA. Little expensive but lightweight and tough!
    4FE3E258-FA02-4CC4-A3AC-009884C980DF.jpg A2B722BE-97BA-406D-997C-C768FB07645C.jpg
  18. Aug 9, 2021 at 6:27 AM
    TacoFergie
    Iowa
    Those are some nice looking UCA's!! They are pricey at $800, but lower than most aluminum UCA's I've seen.
    Does anyone have experience with Rough Country Aluminum UCA's? I'm not an RC fan at all! But for $270 I don't think they can be beat for price. I know it says ONLY 3.5" lifts, but I don't see the issue using them on 2.5"-3" lifts. I don't think that the alignment specs would be specific enough to ONLY be used with 3.5" lifts. I'm also curious what ball joint is used when replacement is needed. It is nice that they are sealed ball joints for people who have winter weather concerns and they have rubber bushings like OEM that will remain quiet. Many pluses, especially considering the price. I have never been a fan of RC which makes me leery, but this may slightly turn me around on some of their parts, not all though.
    https://www.roughcountry.com/toyota...74201.html?find=2015-toyota-tacoma-4wd-738360
    ohcaltexscar[QUOTED] likes this.
  19. Aug 9, 2021 at 8:29 AM
    JDPNW
    S. Oregon
    Hey hey,
    Regarding the stacked washers,
    https://www.tacomaworld.com/threads...3rd-gen-today.399305/page-10070#post-25598439
    The difference in the pictures is that my first set had the JBA boots and the replacements I received had the short Toyota boots.
    TacoFergie[QUOTED] likes this.
  20. Aug 9, 2021 at 8:46 AM
    ohcaltexscar
    Chas
    El Paso, Texas
    Ehhhhhh alright, what's the catch? 270$ makes me think there's a catch involved.
    Maybe that's me being leery too huh? :rofl:
    They look nice, I'd like to know if anyone has experience with them as well!
