Favorite/Preferred LSD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eodrunner, Oct 3, 2011.
  1. Oct 3, 2011 at 1:23 AM
    eodrunner
    eodrunner [OP] Well-Known Member
    Jerron
    Guam
    10 PreRunner
    2 JL 10W3, Infinity reference series speakers all around, infinity 1600a and 475a amps, Pioneer Avicenna-z140bh
    I've been thinking, looking, forgetting about, remembering, looking, and thinking again about getting an LSD for my 2011 Tacoma prerunner. Who here has an LSD in theirs? I know a bunch of you do. I guess I got two questions for anyone willing to respond. What is your preferred brand/type of LSD and why'd you chose it? Also, did you do a gear change when you did the LSD? Thanks for anyone who responds.
  2. Oct 3, 2011 at 4:07 AM
    Jimsc
    Jimsc Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    Your already have a LSD? The are standard equipment on all prerunners.
  3. Oct 3, 2011 at 6:05 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    LSD is only standard on TRD Sport models. TRD Off-Road models have the locker. SR5 packages have an open diff.
  4. Oct 3, 2011 at 6:17 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    The electronic LSD comes standard with your Prerunner. I can testify to how well it owrks on slippery (or sand) boat ramps and muddy trails in my 4x2.
  5. Oct 3, 2011 at 7:43 AM
    walter
    walter Well-Known Member
    Inyo Face, Ca
    chicks dig the longbed
    4x4,fox co's,fox rear,265/75/16
  6. Oct 3, 2011 at 7:46 AM
    RogueLeader
    RogueLeader Well-Known Member
    Rod
    Las Vegas, NV
    2011 Tacoma Double Cab SR5 TRD
    My Off-Road has LSD as well as the locker. I can turn it off, but unless I do so, or go into 4 lo, it is always available.
  7. Oct 3, 2011 at 9:25 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Only on 2005-2008 Sport TRDs
    Now (2009+) all Tacomas have TRAC and AUTO LSD in 2WD.
    TRAC is a limited slip with engine output regulation (and brakes a spinning tire).
    AUTO LSD is a stronger limited slip without the engine regulation.
    The 4WD Tacomas ('09+) also have TRAC in H4, but it is the same as AUTO LSD because TRAC in 4WD has no engine regulation.
  8. Oct 3, 2011 at 9:27 AM
    David K
    All models and trim levels of the Tacoma receive as standard equipment Toyota's Star Safety System, which includes anti-lock brakes (ABS), Electronic Brake-force Distribution (EBD), Brake Assist, Vehicle Stability Control (VSC) and Traction Control (TC). An Automatic Limited-Slip Differential (Auto-LSD), which uses brake intervention in place of a mechanical-type limited-slip to help reduce wheel-spin, is standard on all Tacoma models with the exception of those fitted with TRD Off-Road packages, like our test model; those will have a separate locking differential.
  9. Oct 4, 2011 at 1:50 AM
    eodrunner
    Jerron
    Guam
    10 PreRunner
    Yeah, I know i have the auto LSD. It sucks. I hate that thing. It's really not worth much in my opinion. Put a brake wheel LSD (auto LSD) against a true LSD (Mechanical) and the mechanical proves ahead of the game every time.
    I wasn't sure if there were many out there who upgraded to a true LSD. It kind of sounds like most haven't. I just want power from both wheels, not a reduction in power to one.
    Ah well, I'll keep looking.
  10. Oct 4, 2011 at 2:40 AM
    mountaincanoe
    mountaincanoe Active Member
    Colin
    Fredericton, NB Canada
    05 Tacoma 4X4 Access Cab
    Skyjacker Platinum Coil Over, 3 inch soft ride rear leaf pack, Nitro rear shocks, KN 63 series intake, Centerforce II Clutch, Vision X Lights, Pro Comp 7089, Dick Cepek 285/7516 Mud Country,4.88 Yukon, Detroit TrueTrac, ARB Front Locker, All Pro IFS skid, ARB on board air, All Pro Sliders, Allpro Apex front bumper,
    I installed a Detroit TrueTrac in the rear of my 05. Works great and was a good improvement over stock. I would highly recommend but not sure how it will work with your stock traction control system.
    It did not affect my gas mileage and does require a gear setup. So it would be a good time to re-gear.
    Works great in the snow here in Canada and also in loose sand and mud. Draw back is if your stuck and buried only one wheel will spin. (It is not a locker) That just means you have to get more traction to that tire. I use an old jacket and put that under the tire. Usually drive right out. To me it works better than all that traction control stuff that comes stock as there is no buttons to push, it is automatic and very strong. Here is a link: Check it out!
    http://www.eaton.com/Eaton/Products...utomotiveAftermarket/Differentials/PCT_221471
    Hope that helps!
  11. Oct 4, 2011 at 3:17 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Blotter.
    Then Microdot.
  12. Oct 4, 2011 at 6:50 AM
    pinktaco808
    pinktaco808 Hot Steppa
    i thought you was talking about something else at first lol. Than I was like ok
  13. Oct 4, 2011 at 8:39 AM
    David K
    AUTO LSD indeed works as a limited slip... (transfers power from spinning wheel to traction wheel). It sounds like you are seeking a locking differential (power to both tires even when one has less traction)?
  14. Oct 5, 2011 at 1:35 AM
    eodrunner
    Jerron
    Guam
    10 PreRunner
    Yeah the thread was definitely not about "That" LSD. haha.
    I want something that isn't open. I just don't like having one tire spinning, pushing, having all the power. I would like to have more traction on the day to day grind, that will also benefit me in the dirt and hard sand. Where i life the roads suck and if I'm on any kind of incline after it rains it takes forever to go anywhere the roads are so porous. My one leger just sits there and spins even when VERY minimal throttle is given. It just bugs me enough that I want something different. I suppose it's a good thing I don't spend much time anywhere near home.
  15. Oct 5, 2011 at 1:51 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    I dont know if your detroit trutrac is different from mine but when one of my tires start to spin it kicks the power over to the one that has traction.
  16. Oct 5, 2011 at 1:52 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    Detroit TruTrac is what I installed in mine-It works great
  17. Oct 5, 2011 at 6:51 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Sadly this is something majority can not grasp...
    Factory LSD out of the 05-08 TRD sport does that. Its set to "speed up" slow wheel instead of slowing down the fast wheel.
    But Toyota no longer sells trucks with it so its eother buy new one from Toyota and install yourself or get one from parts truck.
    Your other choice is Truetrac which is actually very good limited slip.
  18. Oct 5, 2011 at 12:58 PM
    mountaincanoe
    Colin
    Mine is the same, but when your stuck and not moving forward the traction turns to tire that has less traction. Therefore not a locker. I am saying stuck and on ice or buried in sand/mud it will revert to one tire fire.
    The Detroit Truetrac is great because it is streetable with no full time locker related issues and will give you great traction in snow, rain slick roads, sand and mud.
    It is a true mechanical LSD and is very strong. I have been using mine for just over one year or 25 thousand km and have no issues. It is a great improvement over stock.
  19. Oct 7, 2011 at 12:54 AM
    eodrunner
    Jerron
    Guam
    10 PreRunner
    I really appreciate everyone giving me their testimonials and preferences. It helps quit a bit. I think I'm going to go ahead and get the detroit truetrac as soon as I get back.
