Favorite Brake Bleeding Method?
Discussion in '1st Gen. Tacomas (1995-2004)' started by pontoon, Mar 15, 2019.
  1. Mar 15, 2019 at 3:24 PM
    pontoon
    pontoon [OP] Well-Known Member
    2000 Tacoma SR5 TRD V6 3.4 5MT
    Hey all, I've got a 4x4 that I'm going to swap out the brake hoses on. I've bled the brakes before doing a method that many people are nervous about doing. Here's what I do:
    1) Fill up the brake reservoir.
    2) Loosen a bleeder nut and attach a hose.
    3) Pump the brake enough to get the fluid flowing.
    4) Top off the brake reservoir.
    5) Repeat 3 and 4 until fluid is clean and free of bubbles.
    Repeat 1-5 for each brake caliper.
    I don't actually know how to bleed the rear brakes but I assume there's a bleeder back there too.
    Some people are concerned this method will lead to air being sucked into the caliper. In my experience the hose will have fluid all along it such that air can't get sucked in. It does back up a tiny bit but not enough to bring air in.
    Is this OK? If not, I've considered a power bleeder of some sort but prefer fewer large tools if I can avoid it. I don't have an air compressor or a place to hook one up (live in an apartment). Any tips would be appreciated!
    I know a helper with a similar procedure is best, but I try to avoid dragging someone (e.g. gf) out there to help on this one.
  2. Mar 15, 2019 at 3:30 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
  3. Mar 15, 2019 at 3:35 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    This ^ and add this as well you will thank me the Motive one leaks like crazy https://www.amazon.com/gp/product/B07JPJSBKW/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
  4. Mar 15, 2019 at 3:37 PM
    jbrandt
    Justin
  5. Mar 15, 2019 at 3:59 PM
    JLee
    Jerry
    Benicia, CA
    We just bled a clutch today with this one and not a drop dripped out.
    jbrandt[QUOTED] likes this.
  6. Mar 23, 2019 at 9:48 PM
    All Rice
    All Rice Well-Known Member
    Aloha State
    Speed bleeders here. I have them on all my cars.
  7. Mar 24, 2019 at 1:28 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    As long as your hose off the bleeder valve is always in fluid it should work.
    The thing is with just one person no way to tell if the hose might be sucking in air but looks good when you crawl under to tighten the valve .
    Never tried the speed bleeders as brake bleeding is not a weekly project most of the time
  8. Mar 24, 2019 at 2:31 AM
    tony2018
    tony2018 Well-Known Member
  9. Mar 24, 2019 at 3:51 AM
    cazinpa
    cazinpa Well-Known Member
    Andy
    Lancaster, PA
    '96 Tacoma
    A few tweaks
    I second the speed bleeders.
  10. Mar 24, 2019 at 8:21 AM
    Tacomaman63
    Tacomaman63 Well-Known Member
    Stan
    2004 tacoma TRD 4x4
    step bars grille guard
  11. Mar 24, 2019 at 9:50 AM
    pontoon
    That's the same as I do. I guess I'll stick with it.
    All this talk about bleeding brakes... Maybe I'll wait another year :)
    jerrodh1980 likes this.
  12. Mar 24, 2019 at 10:04 AM
    BrownMike
    BrownMike Well-Known Member
    San Diego
    1999 Taco 4x4
    Long Travel, 5 Spd, Supercharged 3.4
    Speed bleeders for the win! Start at the farthest (rear, opposite master) crack/push/close then move to the next. And of course, always check the resi to make sure its topped off. Whole thing take 30 min max with speed bleeders.
  13. Mar 24, 2019 at 10:15 AM
    Taco!
    Taco! Well-Known Member
    98Xcab4WD
    I have a Motive bottle that I use for pressure only (I don't put fluid in the bottle). The problem is the universal cap doesn't really work. Somebody on Amazon posted their solution by making a custom fitting out of PVC pipe and a rubber collar that fits around the neck of the master cylinder, and then connects to the Motive hose. You can see a picture on Amazon by reading the user comments if you look for the product: "Motive Products 1101 Master adapter". The reviewer left his comment on 4-29-17 with picture. FYI, I tried to construct the same item as in the picture but had a problem finding a rubber collar that would fit on the neck of the master cylinder. However the $50 solution posted here seems a little pricey but might be worth it if you want to use the Motive.
  14. Mar 24, 2019 at 10:36 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I’ve used my Motive bleeder countless times on my 1st gens, my current 2nd gen, abs my wife’s integra. All using the chain that comes with it. I’ve never had it leak once. It makes bleeding brakes so easy. Especially with the magnet catch container connected to the caliper/wheel cylinder.
  15. Mar 24, 2019 at 12:06 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I can see in a place that is dry and never sees winter speed bleeders might be the way to go
    taking them off to clean every use would get old
    Here bleeding brakes in my case means new bleeders almost every time
