fan clutch noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by t28toya, Sep 15, 2012.
  1. Sep 15, 2012 at 11:51 AM
    t28toya
    t28toya [OP] New Member
    RIVERSIDE/INLAND EMPIRE,CA
    lowered on 18s
    lowered,system,cold air,exhaust ,k&n,tint ,
    My fan clutch was making a hyper accelerated wind sound so i replaced the clutch on my fan but it still has that fan sound :mad:
  2. Dec 23, 2012 at 9:27 PM
    jimalan1989
    jimalan1989 Member
    Jimmy
    Columbus, MS
    2011 4x4 Double Cab Long Bed SR5
    NONE
    every toyota truck i have ever come across has a lot of fan clutch noise. specailly when you first start them.
  3. Dec 23, 2012 at 9:29 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    serious thread?
  4. Dec 23, 2012 at 11:48 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Normal
    Normal
    I mean serious...:D
  5. Dec 23, 2012 at 11:51 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    The way you check yur fan clutch is an easy one, with motor off, grasp one of the fan blades & spin it, if theres a little yet smooth resistance, its fine, if you can't freely spin it or its frozen , its done...
  6. Dec 24, 2012 at 9:02 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Tie dental floss from the fan to the frame. If the floss breaks, after startup, the fan is fine... Along with the previous poster's comment: locked up constantly= bad clutch.
    The noise is from the clutch being engaged upon startup. This is normal, as stated before. The clutch is locked until the silicone inside warms up, or reaches it's engage temp.
  7. Dec 24, 2012 at 10:49 AM
    Tool Pants
    Tool Pants Active Member
    San Jose
    2001 Xtra Cab 2.4L 2wd
    Interesting because I also notice the loud fan when I start when it is cold. Goes away after about 15 seconds. I figured it had to do with the clutch locking up the fan.
    I had a 1988 22R with the same fan clutch and it did not do this. Maybe because it was so old.
  8. Dec 24, 2012 at 11:58 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Mine is noisy as well. I had the dealership look at it while I had it there and they said the fan clutch has a little "play" in it but I don't know what they are talking about as I checked it and it was fine, no play and just noisy.
  9. Jan 15, 2013 at 6:01 PM
    Mtn Tacoma
    Mtn Tacoma Dude
    Craig
    MI
    13 MGM AC OR
    My truck is making that same noise (I would have called it a squish squish when I depress the clutch only for the 1st time when it's cold); I haven't tried the floss test thing but if the fan is locked or too loose, is the fan the only thing that needs replaced?
  10. Jan 15, 2013 at 6:13 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
  11. Jan 16, 2013 at 4:01 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    The clutch is the part you replace, if the fan isn't falling apart.
  12. Jan 16, 2013 at 6:23 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    when I first got my truck I was amazed to see (well, hear) how quiet the thing was. Come to find out the fan clutch was toast, and after installing a new one the loud fan sound was apparent.
    Just normal for these trucks.
  13. Jul 22, 2019 at 2:45 PM
    KegFixer
    KegFixer New Member
    2001 Tacoma Ext Cab 4x4
    My 1996 alsways made noise at startup and then you could hear it wind down after a short Time. New 2001 with a different engine is noisy 100% of the time. Normal?
