Fan Clutch is stuck on good…Any suggestions??
Discussion in '1st Gen. Tacomas (1995-2004)' started by CitizenSnips5, Oct 13, 2021.
  1. Oct 13, 2021 at 3:13 PM
    CitizenSnips5
    CitizenSnips5 [OP] Well-Known Member
    Hi all,
    I’ve finally chased an oil leak down to my oil pump. Removing the Crank Shaft Bolt was a pain but eventually got it. To get it back on and torqued to spec I was trying to make room for the torque wrench by pulling off the fan clutch connected to the water pump pulley…Lo and behold this sucker is also stuck. All 4 nuts are off. No idea what the best method to pull would be without damaging.
    Video for reference:
    Any suggestions?
  2. Oct 13, 2021 at 3:26 PM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    Shoot some Kroil or PB blaster in between the flange and where the bolts anchor into. Get a brass drift and with a hammer tap the flange, It should work its way loose. If it doesn't then keep tapping it towards the front towards the radiator but be careful not to damage anything.
    CitizenSnips5[OP] and Bivouac like this.
  3. Oct 13, 2021 at 5:39 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    What He said!!^^^^
  4. Oct 16, 2021 at 9:54 AM
    trdxtacoma
    trdxtacoma Well-Known Member
    18 Tacoma SR AC
    Same issue with my fan clutch. Every 12mm 12 point box end wrench is stripping the bolts. 6 point wrenches apparently are a speciality tool? Can’t find anywhere in the county and 10 days shipping online. PB blaster has been sitting for well over 24 hours and I’ve been spraying every couple of hours. No luck with even a vise grip fully locked. Still stripped. I think the bolt material is too soft to overcome the torque required to pull it loose.
    just taking it to the damn shop. Not worth all this effort and time to save like $200 in labor.
  5. Oct 16, 2021 at 10:14 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    Flare wrenches might work better depending on how badly they've been rounded. Can get a set cheap from Harbor Freight. I'm not sure if it's possible based on the surrounding components, but if you can put propane torch on those nuts it makes all the difference for stuck fasteners.
  6. Oct 16, 2021 at 10:17 AM
    trdxtacoma
    18 Tacoma SR AC
    Bolts are still somewhat decent shape. Anymore and it’s probably gonna need a water pump. considered flare nut wrenches but nobody has 12mm. They have 11mm and 13mm, just not 12mm anywhere local.
  7. Oct 16, 2021 at 10:19 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  8. Oct 16, 2021 at 10:22 AM
    CrustyTaco
    Todd
    Louisville, KY
    trdxtacoma[QUOTED] likes this.
  9. Oct 16, 2021 at 11:37 AM
    Bivouac
    Pray tell where do you live ??
    You can`t find 6 point wrenches .
    JudoJohn likes this.
  10. Oct 16, 2021 at 2:05 PM
    wesb1023
    wesb1023 Well-Known Member
    Westley
    Eastern NC
    04 Double Cab
    Yeah, penetrating oil and tapping it may help. There is a centering pin in the middle, it’s probably rusted and stuck. You can also try a small chisel between the fan clutch flange and the P/S belt pulley to try to drive the two apart, then turn 180 degrees and do the same thing to walk it off.
  11. Oct 16, 2021 at 2:13 PM
    O'Silver_Taco
    MD
    So far when I tried everything else on my truck....the torch has never failed..its like bacon, everything goes better with bacon....
    However now that I have an automotive cordless impact....almost never have to torch...
    If so remember to have extinguisher handy.....dont take chances.....
