Fan Clutch Failing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TireFire, Nov 25, 2019.
  1. Nov 25, 2019 at 4:53 PM
    TireFire
    TireFire [OP] Superunknown Member
    Olympic Peninsula
    I have the 4.0L V6. I’m not sure what’s going on with my fan clutch. There appears to be no difference in resistance between a dead cold and a hot engine. I can spin the fan by hand very easily but if I try to give it spin it will not freewheel (think like a bike tire in the air) but will stop after less than a quarter turn. Is it going bad?
    Looking online I see 2 part numbers for similarly priced fan clutches that fit my truck:
    16210-0P010; and
    16210-31020
    What is the difference??
  2. Nov 25, 2019 at 5:18 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Are you overheating?
  3. Nov 25, 2019 at 6:46 PM
    TireFire
    Olympic Peninsula
    No
  4. Nov 25, 2019 at 8:35 PM
    TireFire
    Olympic Peninsula
    But I have sluggish AC and just because not overheating doesn’t mean it’s not bad. It’s cold here in Washington also.
  5. Nov 26, 2019 at 8:42 AM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    Do you get the characteristic "fan roar" on cold start-up that dies down within a number of seconds after start?
    cruxofthebisquit and 12TRDTacoma like this.
  6. Nov 26, 2019 at 10:23 AM
    TireFire
    Olympic Peninsula
    Yeah
    12TRDTacoma likes this.
  7. Nov 26, 2019 at 10:30 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If the roar goes away after a few seconds of start up then I would not worry about it @hx989
    Everything sounds okay at the moment. The hard to turn blades are only one way of inspecting things but are not an ultimate tell all of the fan clutch operation and condition.
  8. Nov 26, 2019 at 11:08 AM
    TireFire
    Olympic Peninsula
    Thanks, do you know what’s up with the two different part numbers?
  9. Nov 26, 2019 at 11:16 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If I was to take a wild guess one is for 2TR and the other is for 1GR.
    JC15Taco likes this.
  10. Nov 26, 2019 at 11:17 AM
    JC15Taco
    Jeff
    SK, Canada
    '15 TRD DCLB
    I'd say everything is good with the fan. Make sure it has no play and it's not leaking any oil.
    Can't help with the two different part numbers.
  11. Nov 26, 2019 at 11:20 AM
    rnish
    Tacoma 2nd gen
    No part number on your fan assembly?
  12. Nov 26, 2019 at 11:57 AM
    TireFire
    Olympic Peninsula
    Not swapping fan, and I can’t see it on the clutch without takin shit apart. Don’t want the truck down for too long, it’s too cold to ride my Moto
  13. Nov 26, 2019 at 12:09 PM
    TireFire
    Olympic Peninsula
    No, there are 2 for each
    12TRDTacoma[QUOTED] likes this.
  14. Nov 26, 2019 at 12:13 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
  15. Nov 26, 2019 at 12:16 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I've seen guys grab them. Nice party trick but I just couldn't do it.
    Mine roars all the time. It's been changed and worked better a while then did it again. Oh well, better than freewheelin'.
    12TRDTacoma and JC15Taco like this.
  16. Nov 26, 2019 at 12:16 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Not gonna lie that looks like a shit idea. Especially in the Taco engine bay where room is limited. If you jumped your hand is either going into the belt, or further into the fan
    TireFire[OP] likes this.
  17. Nov 26, 2019 at 12:47 PM
    TireFire
    Olympic Peninsula
    Thanks! That’s probably the one I would get because Aisin supplies Toyota and I don’t care to pay triple for the red and white box. My truck has the tow package and came with the pink clutch shaft. However, it’s got 200k miles on it and as I understand it they don’t fail abruptly but gradually. Also, to be 100% fair I don’t know if I’m on what verge of overheating due to the huge flat spot in the dummy gauge on the dash.
    When I enter my VIN it still tells me both part numbers fit...
    Did you just change the oil levels to get it to engage more? Didn’t know these things can be adjusted aside from that.
  18. Nov 26, 2019 at 1:35 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Change oil viscosities i believe. Heavier oil will engage it more and move more air, but it will also eat up HP and hurt performance if it's too heavy
    whatstcp and SR-71A like this.
  19. Nov 26, 2019 at 10:29 PM
    anthony250f
    Anthony
    San Diego, CA
    Ive used different thickness oil, different quantities, and messed with the coil a bit too
