Fan Blower Resistor...again...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDsnb, May 22, 2020.
  1. May 22, 2020 at 1:11 PM
    TRDsnb
    TRDsnb [OP] New Member
    2014 Silver Tacoma TRD
    Hey all, I’m new here. =)
    I drive a ‘14 Tacoma TRD and not long after I bought it the resistor went out. I was able to replace it a couple months ago myself but it’s stopped working again. I bought the part from Amazon. I feel like I saw OEM stopped making parts when I was researching last time... any suggestions?
  2. May 22, 2020 at 1:12 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    Apparently there’s a revised new version from TOYOTA.
    TRDsnb[OP] likes this.
  3. May 22, 2020 at 1:34 PM
    TRDsnb
    The dealership said it would be about $300 out the door. Does that sound about right?
  4. May 22, 2020 at 3:00 PM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
    Skyway, TRDsnb[OP] and TegoTaco like this.
  5. May 22, 2020 at 6:56 PM
    Big_Red_Taco
    Big_Red_Taco Well-Known Member
    SoCal
    Rad Red '08 DCSB TRD Off Road
    Mostly stock: AP rear plate bumper, CR D-Lights, 4600s
    $300!? They might be replacing the whole darn blower motor, which really isn't necessary. Picked up the below for ~$40. I replaced the original designed resistor once and it failed again within 6 months.
    (My reply from another similar post)
    I replaced mine with the new Toyota design that quietly came out in...2018 or so? The connector was changed with a presumably better, square shaped design. The parts counter gave me a kit that included the new design resistor, new square pigtail, and butt connectors.
    I've had it on for over 8 months and have had zero issues, after replacing just the resistor before and having everything fail again and again.
    Skyway, TRDsnb[OP] and Blockhead like this.
  6. May 22, 2020 at 7:20 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Parts guy trying to either scam you or misheard you
    Blockhead likes this.
  7. May 23, 2020 at 6:38 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Do you have the part number for that kit?
  8. May 23, 2020 at 2:05 PM
    Big_Red_Taco
    SoCal
  9. May 23, 2020 at 3:34 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    How did you diagnosis the resistor? If the fan speed is not working right, it's usually a bad connector. Pin#2 or the blower connector. I bet your 1st resistor is OK. It worked when you put in the replacement because removing and inserting the connector into the resistor created a new contact. Eventually, corrosion built up until it stopped working again.
    Where are the specs to test the resistor.
