Fan and inverter
Discussion in 'Outdoors' started by Cnasianfire, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Apr 25, 2019 at 10:23 AM
    Cnasianfire
    Cnasianfire [OP] Well-Known Member
    Charles
    Wilmington, NC
    2015 Tacoma TRD off road DCSB
    BFG KO2 285/75/16 ~2" lift (5100s and block)
    Has anyone ever ran a box fan on an inverter overnight? I wasn't sure if the truck battery would last that long. The fan is 100 watts.
    Also, the inverter is a modified sine inverter, not true sine. Would that hurt the fan over the long hall?
    Wife said that she isn't going camping without a fan during the summer.
  2. Apr 25, 2019 at 10:32 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I know I can run an electric blanket on low off an inverter all night. I bet you could run your fan no problem.
    Pretty easy test. Do the experiment in your driveway to see if it does work. Please report results.
  3. Apr 25, 2019 at 10:33 AM
    Cnasianfire
    Charles
    Wilmington, NC
    Yeah, but I don't want to run my battery all the way down either. That isn't good for the battery
  4. Apr 25, 2019 at 10:35 AM
    koditten
    Kirk
    Central Michigan
    Then get a deep cycle batter to dedicate for your camping? If you are taking a fan and inverter, the battery isn't gonna be that big of a deal.
    I hear you, I want to be somewhat comfortable and get a decent nights sleep.
  5. Apr 25, 2019 at 10:39 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    100w * 10 hours = 1000 Wh
    1000Wh / .85 efficiency = 1176 Wh
    1176 Wh / 12V = 98 Ah
    I think a group 24 battery is like 100Ah.
    If my lunch math is right, you might want to bring jumper cables.
  6. Apr 25, 2019 at 10:42 AM
    Cnasianfire
    Charles
    Wilmington, NC
    So I have 165 reserve on my battery. The equates to 68.75 amp hours. If my fan takes 100 watts, I am not sure how to convert that into hours it will last.
  7. May 3, 2019 at 10:17 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
  8. May 6, 2019 at 6:10 AM
    Cnasianfire
    Charles
    Wilmington, NC
    Thats awesome and would be enough for me, but unfortunately, it isn't enough wind for her
  9. May 6, 2019 at 2:32 PM
    huachuca
    huachuca Well-Known Member
    Al
    Tarboro, NC
    2012 4WD DC w/TRD offroad
    I wouldn't risk draining my starting battery by trying to power an inverter for an extended period. Plus, if stock, the battery in your truck isn't a deep cycle and its life will be significantly reduced by repeated deep discharges.
    Most inverters have a built in safety feature that will trigger an audible alarm when the battery voltage drops low enough to damage something. If you have a second vehicle or some other source for a battery (lawn mower?), rob that temporarily to prove the concept. Then, if this is something you plan to do a lot of, go buy a deep cycle marine battery ($150+/-) and a decent smart battery charger (You should have one of these anyway). Power your inverter off this battery and then recharge it the next day from with the charger hooked to the 110 outlet in the Tacoma as you drive around.
    Fantastic Fan is a big player in the RV market and makes a standalone 12V fan for around $100 that is large enough to be an option and this would be more efficient than the box fan and 110 inverter.
  10. May 13, 2019 at 5:48 AM
    huachuca
    Al
    Tarboro, NC
  11. May 13, 2019 at 5:58 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    I would not run an electric motor device on a modified sine wave inverter. The square wave form will burn up the AC motor. Get a big PC fan on Ebay....
    Electric blankets (and other inductive loads) don't really care what the AC wave form is. Electronic devices like radios, TVs, laptops usually all have ac-dc power supplies built into them, so they too are usually immune to wave shape.
Thread Status:
