Falken Wildpeak AT3W Tire Wear
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Killintaco, Oct 30, 2023.
  1. Oct 30, 2023 at 6:33 AM
    Killintaco
    Killintaco [OP] Well-Known Member
    Will
    Tampa, Florida
    2022 Tacoma SR5 Double Cab
    Hey guys, looking to get some info on premature wear for these Falken tires. I have 265/75/r16 and i run them at 35psi. tires have 25,000 miles maybe a little less. Two of the tires are already showing 3/32" on depth. The other two are at 5/32". seems to me that is very fast for the life span of the tires. What's your thoughts? I don't go off road, keep them at the correct pressure and truck goes to Toyota for regular maintenance. Anyone know if Falken would be of any help?
    I don't know much about this subject so any useful information is appreciated. Thanks in advance.
  2. Oct 30, 2023 at 6:35 AM
    Delta09
    Delta09 OSHA Violator
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Sounds like they're not rotating your tires...
    Tocamo likes this.
  3. Oct 30, 2023 at 6:38 AM
    Killintaco
    Will
    Tampa, Florida
    They are every 5000 miles. Taken to the dealer for that. The paper work says they are rotating them.
  4. Oct 30, 2023 at 6:41 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    The stated mile "life span" of most tires is nowhere near what you get out of them. You are already at 25K with usuabe tread left, so not sure what you would expect Falkans to do about it. But then again, what the hell do I know.
  5. Oct 30, 2023 at 6:41 AM
    Dr. Doom Says
    Dr. Doom Says Well-Known Member
    Tampa
    2019 TRD OR
    Who did you get the tires through?
    You might be able to get some warranty replacements, especially if you have dealer documented rotations.
    https://www.falkentire.com/wildpeak/at3w
    55k tread life warranty
  6. Oct 30, 2023 at 6:43 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    That does seem quicker than normal. Did you get the SL rated ones? I had those as well at one point and I felt like they were wearing quick but then I blew one on a dirt road and got rid of them, lol.
    "Falken back both LT and P-metric sizes of the AT3W with a 55,000-mile limited treadwear warranty."
  7. Oct 30, 2023 at 6:48 AM
    Killintaco
    Will
    Tampa, Florida
    I got them from a authorized dealer that i know personally. They seem to have worn quickly.
  8. Oct 30, 2023 at 6:52 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Doesn't always mean they do it. Even though they're all wearing down quickly, it should be more even.
  9. Oct 30, 2023 at 6:52 AM
    Dr. Doom Says
    Tampa
    2019 TRD OR
    I would give them a call and see what they can do for you. 25k and 3/32" is low.
  10. Oct 30, 2023 at 6:54 AM
    Killintaco
    Will
    Tampa, Florida
    True but then they should be held accountable
  11. Oct 30, 2023 at 6:55 AM
    Killintaco
    Will
    Tampa, Florida
    Yeah i called him and he's going to swing by my shop to have a look at them. Yes I agree.
    CasperDBL20 likes this.
  12. Oct 30, 2023 at 7:00 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    SL or LT?
  13. Oct 30, 2023 at 7:06 AM
    Bishop84
    Bishop84 Well-Known Member
    2/32 deviation isn’t massive, they been rotated.
    tire wear warranty is hard to claim, I’m a tech and still couldn’t claim it on a set I had. My alignment was checked yearly.
    Ultimately it’s a soft all terrain, they wear quickly. It’s why I’ve gone to harder e rated all terrains for summer and a dedicated soft set for winter now.
    gdb85, joba27n and Missouriprerunner like this.
  14. Oct 30, 2023 at 7:07 AM
    clownkillerloaf
    clownkillerloaf Well-Known Member
    Logan
    2018 TRD Sport 4X4 DCSB
    damn man :( big sad...
    Thats way too fast to have to replace. I've had this set of ridge grapps on for 60k miles, probly got another 30k till I hit the wear bars, but I doubt I'll take them that far. Good luck, I'd definitely want them replaced.
  15. Oct 30, 2023 at 7:21 AM
    Killintaco
    Will
    Tampa, Florida
    They are SL. Had the tires put on January of 2022!
  16. Oct 30, 2023 at 7:23 AM
    Killintaco
    Will
    Tampa, Florida
    Yeah I'm sure I'm SOL but damn it just seems so quick. mounted them in January of 2022!
  17. Oct 30, 2023 at 7:24 AM
    Killintaco
    Will
    Tampa, Florida
    Definitely unfortunate, 25k and mount in January of 2022. Just see way to fast, especially having the rotation and proper pressure.
  18. Oct 30, 2023 at 7:25 AM
    BLtheP
    Plano, TX
    This isn't necessarily why the tires wore out so early, but they should have been aired up to 27 psi, not 35. That might have made a difference.
  19. Oct 30, 2023 at 7:29 AM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    I'd imagine that they can be prorated being they worn out prior to the milage warranty. Contact your tire shop on it
  20. Oct 30, 2023 at 7:32 AM
    Killintaco
    Will
    Tampa, Florida
    I agree!
