Falken wildpeak at3w 265/75r16 tire pressure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drakeb252, Jan 14, 2023.
  1. Jan 14, 2023 at 10:45 AM
    drakeb252
    drakeb252 [OP] Well-Known Member
    2014 Grey tacoma TRD
    2 inch Rough Country leveling kit
    I’ve recently installed some falken wildpeak at3w 265/75r16 on my 14 tacoma and i’ve been running 35 psi in them but i’m not sure if that’s a good psi. They came from the tire shop with 40 psi but that seemed to high for me just wondering if anyone else has the same tire and what their running to wear evenly.
  2. Jan 14, 2023 at 12:35 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Are they LT tires or standard load tires? If SL the number on the sticker on the door jamb is a good place to start. It is around 29-30 PSI. The number printed on the tire, (somewhere around 45 PSI) is for hauling max loads. I like to split the difference and run around 35 PSI in my tires. The ride will be a little firmer, but if you ever need to haul something you don't have to air up beforehand unless you're going to load it near max.
    You'll get a lot of conflicting information if you're using light truck tires, especially E rated tires. But on a Tacoma I used the same 35 PSI when I have had E rated tires on it. The number stamped on the tire is 80 PSI, but that is only when installed on a 3/4 or 1 ton truck and when you're loaded over 10,000 lbs GVW. That's about double what a Tacoma is rated for.
    Some guys claim you need 50 PSI. But all the guys I know driving 3/4 ton trucks only air up to 50-55 PSI and that is with a truck that weighs 7000 lbs empty vs a Tacoma that is only rated for about 5500 lbs max when loaded. They will air up above 50 PSI when hauling heavy loads.
    I've always gotten 45,000-50,000 miles out of my tires at that PSI regardless of E rated or SL rated.
  3. Jan 14, 2023 at 6:10 PM
    TacoTuesday1
    FL
    I inflate them to what the door says to.
    Underinflation is worse MPG, outer edge wear
    Overinflation causes harsher ride, center treat wear
  4. Jan 14, 2023 at 6:15 PM
    stocko taco
    stocko taco Well-Known Member
    Az
    19 Nissan Armada
    Honda Accord OBS Chevy
    Contact falken customer service they will provide you with the tire pressure information. If not use the search bar for chalk method.
    TacoTin0350 likes this.
  5. Jan 14, 2023 at 7:24 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I have that exact same tire in the SL (light duty) and have about 1,000 miles on them. I run 32 in the front and 30 in the rear. Based on the wear I'm seeing, I could even drop that another one or two PSI, but it rides great at that pressure and I am trying to balance wear with less rolling resistance.
  6. Jan 15, 2023 at 12:59 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    The 75 series come in 2 load/speed ratings:
    116T is SL max inflation 51
    123S is E1 max inflation 80
    I run the 70 series 112T in SL max 51 and run 35 psi all around and wear is even.
    You need to decide if you want long/even wear or a softer ride. Depends on your load (skid plates, tools, shell, etc).
    drakeb252[OP] likes this.
  7. Jan 15, 2023 at 1:34 AM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    Depends on a whole load of factors. Suspension set up. Weight. Alignment. etc.
    Best bet is to due to chalk test, look at your contact patch, decide how soft you want to ride, how much tire you want to wear. There are general guidelines, but best bet is to do the test yourself.
    Of course just putting it at 30-35 and forgetting about it will probably be fine too.
    winkel likes this.
  8. Jan 15, 2023 at 1:36 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    CHALK METHOD.
    I'll look for a link
  9. Jan 15, 2023 at 1:39 AM
    FishaRnekEd
    New Orleans, LA
  10. Jan 15, 2023 at 3:09 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    I put 37 PSI all around. They are all wearing nicely. Not too harsh of a ride.
    Plus, that idiot light doesn't come on as often. :)
  11. Jan 15, 2023 at 11:57 AM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    100% use to own a 2005 F350, the recommended rear pressure was like 80lbs, that thing was a lumber wagon,unless the bed was full, or i had a trailer on it. 50lbs wasn't bad at all with no load.
  12. Jan 15, 2023 at 12:07 PM
    drakeb252
    Mine are 116T.
  13. Jan 15, 2023 at 12:09 PM
    drakeb252
    I’ll try and contact them.
  14. Jan 15, 2023 at 12:11 PM
    drakeb252
    Yeah their 116T rated i’ve been running 35psi on rear and front
  15. Jan 15, 2023 at 12:16 PM
    drakeb252
    The only reason i don’t air to what the door says is because mine are a different size than the stock tires my door has (265/7016r and mine are 265/7516r
  16. Jan 15, 2023 at 12:45 PM
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    This is a very handy converter: LT tires actually need more pressure to carry the same load as P-rated tires for the same size... and if you change tire sizes as well as tire type, you want to do the conversion.
    Examples: my wife's 2019 Sport came with P265/65R17 at 29 psi (per the door jamb) and she's running LT 265/75R16 now. To get the same load carrying capacity she needs to run at 37psi.
    My 2022 TRDOR came with 265/70R16 (note the lack of the "P" up front) at 30 psi and is now running LT235/85R16. To get the same capacity...need to go to 42 psi.
  17. Jan 15, 2023 at 1:29 PM
    drakeb252
    Thanks for the info! I’ll check out the website and see
  18. Jan 15, 2023 at 3:23 PM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    I have those tires. 35 lbs all around. They may lose a pound or two every couple months but good tires.
  19. Jan 15, 2023 at 4:07 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    I have those tires in that size. 35psi. Offroad I lower to 20psi.
  20. Jan 15, 2023 at 5:52 PM
    drakeb252
    i think 35 is fine in most tires anyway (if there close to the stock size)
