Fahren Scourge H11 LED in 2022 SR5
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PolakTaco, Aug 25, 2022.
  1. Aug 25, 2022 at 8:23 PM
    PolakTaco
    PolakTaco [OP] Well-Known Member
    FL
    2022 Tacoma SR5 4x4 V6
    Hey, just joined today and posted a welcome thread little earlier.
    I have a brand new 2022 SR5 with Projector Headlights. Found a Fahren Scourge H11 LED kit in my garage that's intended as a spare for my wife's Jeep.
    Amazon website claims it will not fit my Tacoma for some reason.
    Should I be worried about anything like wiring, etc... before I make an attempt to install it?
    Link to the exact kit I have at home:
    https://www.amazon.com/gp/product/B09BVJJK71?ie=UTF8&th=1
    I tried using search function but didn't really find anything helpful for this particular LED kit.
  2. Aug 25, 2022 at 9:06 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Takes a literal minute to disconnect one of the OEM bulbs. See if the connectors fit and if it fits in the housing. Amazon says that bulb will fit my 2017...no idea whats different on a 2022 but like I said, only takes a sec to go out and check!
    If it has LED bulbs (OEM) already then it will not fit as I'm pretty sure they aren't modifiable.
    PolakTaco[OP] likes this.
  3. Aug 28, 2022 at 6:15 PM
    PolakTaco
    FL
    It had regular H11 Osram bulbs in projector lens headlights. I swapped it out with the Fahren LEDs and it works fine so far.
    My only concern is with potential wiring long term as I'm assuming LED requires much more power.
  4. Aug 28, 2022 at 6:25 PM
    chstaco
    chstaco Well-Known Member
    SC
    2020 Tacoma
  5. Aug 28, 2022 at 7:14 PM
    PolakTaco
    FL
  6. Aug 28, 2022 at 8:51 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Tons of info in there, the gist of it is that most, if not all, LED bulb replacements are a downgrade despite 'appearing' to the driver to be an upgrade. OEM LED housing is the best option for upgrading. Open your wallet to the tune of ~$1200 though.
  7. Aug 28, 2022 at 9:07 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    No worries about damaging wiring- leds use much less power to produce more light. That’s true for any and ALL LED bulbs. However, other comments about you potentially reducing headlight output is true- that linked thread is a great read and explains it better than I could ever hope to.
    shakerhood likes this.
