Factory window tint % - HELP
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rogue_12, Nov 8, 2022.
  1. Nov 8, 2022 at 12:18 PM
    Rogue_12
    Rogue_12 [OP] Active Member
    Hello everyone,
    I just picked up a 2023 SR5 and wanted to know what the factory window tint percentage is on the back windows? I plan on tinting the two front widows and want it to match the back.
    Thanks for the input and help!
  2. Nov 8, 2022 at 12:19 PM
    Tacospike
    Two Trucks
    I just went to the tint shop and had them match as close they could
    Chew and Rogue_12[OP] like this.
  3. Nov 8, 2022 at 12:24 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    20% on the fronts seems to match the rears pretty well.
    BJK1280 and SeaDweller3T like this.
  4. Nov 8, 2022 at 12:38 PM
    Rogue_12
    Thank you! also love your wheel and tire set up!
    MrChoda and tonered[QUOTED] like this.
  5. Nov 8, 2022 at 12:42 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    Thank you! The wheels finally happened about 1mo ago. So much happier. Haha!
  6. Nov 8, 2022 at 12:53 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    The rear privacy glass is about 26%.
    That's not very dark and CIR tint has great clarity, so I had my guy throw 20% all over all the glass with 70% on the full shield. Looks great and there's a color shift to the rear so cops won't give you trouble even with the front darker than legal here.
  7. Nov 8, 2022 at 2:39 PM
    099 Well-Known Member
    2022 White Tacoma Double Cab SR5
    I went with 20% on the front and that matched the back good enough for me.
  8. Nov 8, 2022 at 2:43 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Just have the tint shop use their meter to see what % it rings out to and they can try to match it.
  9. Nov 8, 2022 at 2:53 PM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    20% or 35% will work fine. I had 35% on the front windows on mine and it wasn't obvious that the rears were a little darker.
  10. Nov 8, 2022 at 3:00 PM
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    Rear windows are 20% dye I believe
  11. Nov 8, 2022 at 3:17 PM
    Integerdy
    Integerdy Aspiring "SR5 Pro"
    Eric
    So-Lame, Oregon
    21 SR5 Silver Sky DCSB
    I also did 20% on the fronts to match the rears
  12. Nov 8, 2022 at 3:59 PM
    nighthawk custom
    nighthawk custom Well-Known Member
    Kentucky
    2022 dcsb SR5 4x4
    My tint shop put on 20%.
  13. Nov 8, 2022 at 6:16 PM
    tneynop
    tneynop Well-Known Member
    Charlie
    Levittown, PA (Bucks County, SE Pa.)
    '22 SR5 V6 DCSB 4x4 - Barcelona red, black w/red int
    Peragon tonneau, Vertex Offroad faux leather seat covers, Tufskinz interior dress up, Diode Dynamics stealth light bar, NFab nerf/steps
    I pretty much did what most folks here have done, I told my local tint shop to match the rear windows on my '22 and they did it without even thinking about it. Very easy!
