Factory tint front door window glass?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Backinblack03, Nov 23, 2021.
  1. Nov 23, 2021 at 2:30 PM
    Backinblack03
    Backinblack03 [OP] Well-Known Member
    Brian
    VT
    2003 Xtra cab 4x4 2.7/5spd
    ABS sucks.
    Is there a factory option for a tinted front door glass? Something that will match the rear/back without applying tint...
  2. Nov 23, 2021 at 3:11 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
  3. Nov 23, 2021 at 3:15 PM
    MGMDesertTaco
    I'm not sure about factory, but I'll bet you could order a replacement window with a "smoked" tint or whatever they call it these days. You could add tint on top if needed. Check with safelight or another auto glass company.
  4. Nov 23, 2021 at 3:26 PM
    Backinblack03
    Brian
    VT
    ABS sucks.
    Applied tinting is no longer a state inspection issue here, but you can still be ticketed as a secondary infraction if pulled over for a different reason. However, if the tint is in the glass, and not an applied film, it's not an issue.
