Factory Sub Wire Harness diagram
Discussion in 'Audio & Video' started by 05Taco4x4, Jul 18, 2011.
  1. Jul 18, 2011 at 1:18 PM
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Solved !
    Can anyone point me in the right direction on how to find the diagram for the wire harness to the access cab center sub woofer. I purchased one from a member and do not have the wire harness. I need to figure out how to wire this into the radio. It has 8 pins and I can't figure out why this needs 8 pins. Also, if someone could provide a part # for the harness that would be awesome.
    thanks
    EDIT: FIGURED IT OUT, THANKS fbconvert !!!
    Words color coded to original wire colors... pin 6 is a dummy
    For Reference, the back of my 2005 NON JBL radio:
  2. Jul 20, 2011 at 10:25 AM
    fbconvert
    fbconvert Well-Known Member
    Brian
    Seacoast, NH
    2005 Tacoma Double Cab TRD Sport
    can you be more specific on what wiring diagram you need or what you are trying to do exactly? What year of tacoma do you have, does it have the JBL audio system?
    My double cab with JBL audio came with a factory subwoofer but I thought the JBL audio was only available with double cabs :notsure:.
    Anyways almost all wiring diagrams can be found at . but you won't find the diagrams for any tacoma newer than 2008 (when they put new Head units in and added the aux input, etc). If your truck is 2009 or newer let me know and I can get you the audio wiring diagram, just clarify if its JBL or not.
  3. Jul 20, 2011 at 11:14 AM
    05Taco4x4
    2TR-FE Enthusiast
    thanks, i have a reg cab i am putting a sub from an access cab in, the sub piced above... a wire diagram would be awesome... the wire that plugs in the sub, and runs to the radio... NON JBL... thanks
  4. Jul 20, 2011 at 5:09 PM
    05Taco4x4
    2TR-FE Enthusiast
    btw, it's a 2005 reg cab... i'm in the process of adding options that came with access/double cabs that my truck doesn't have
    Kuntrykid likes this.
  5. Jul 20, 2011 at 5:21 PM
    05Taco4x4
    2TR-FE Enthusiast
    Audio System for Built–in Type Amplifier
    Audio System for Separate Type Amplifier
    neither one shows the sub woofer i have, just the jbl one :(
    it would be nice if someone with this sub was handy with a voltmeter
  6. Jul 20, 2011 at 5:31 PM
    05Taco4x4
    2TR-FE Enthusiast
    that's very helpful info, thanks
    so all i need now is a wiring diagram for a 09+
  7. Jul 20, 2011 at 5:33 PM
    05Taco4x4
    2TR-FE Enthusiast
    yes, i'll take you up on this fine sir
    NON JBL, but both would be awesome, just to compare and have
    thanks
  8. Jul 20, 2011 at 8:51 PM
    fbconvert
    Brian
    Seacoast, NH
    Thanks for confirming that for me.
    Let me see if I can get the diagrams. I am thinking that if your truck did not come with the subwoofer, chances are you will need an amp for it as well. but like you said I think you will need both diagrams to compare their differences. It will be enough to get you started at least.
  9. Jul 20, 2011 at 9:26 PM
    fbconvert
    Brian
    Seacoast, NH
    Just curious is the flux capacitor the actual name of the sub or is just a nick name. Did the flux capacitor require a separte amp to power it? I had the impression that the only separate amp system were jbl which I now know only came in double cabs. If it doesn't use a separate amp I can't image it is really all that good. Especially since the JBL sub is really nothing to boast about.
  10. Jul 20, 2011 at 9:29 PM
    ninja90177
    ninja90177 Well-Known Member
    Kenney
    Las Vegas
    '09 AC 4x4 Off-Road
    Icon 2.5 C/Os, Wheeler's AAL, OME N182, 265/75-16 KM2s, Murdered Emblems
    Actually, it was in the X-Runner. I almost bought one a while back. The pin-out is the same.
    The wiring diagram for the sub in the manual @ is indeed correct.
    Check out xr-underground.com for some more info.
  11. Jul 20, 2011 at 9:32 PM
    ninja90177
    Kenney
    Las Vegas
    '09 AC 4x4 Off-Road
    The flux capacitor. Well, without the external amp (as the manual puts it.)
    We experimented ripping it out of my friends truck, so I didn't destroy mine when I pulled it.
  12. Jul 20, 2011 at 9:37 PM
    fbconvert
    Brian
    Seacoast, NH
    Yeah I just looked at both the diagrams for 2009 and the only one showing a sub is the separate amp (JBL) system. I am not really sure how it works but with out an amp i can't imaging it to be that impressive.
  13. Jul 20, 2011 at 9:42 PM
    05Taco4x4
    2TR-FE Enthusiast
    Here it is, i'll update the first post
    [words are color coded to factory wire color]
  14. Jul 20, 2011 at 9:54 PM
    fbconvert
    Brian
    Seacoast, NH
    I see so it just pulls power from the deleted left and right rear door speakers.
  15. Jul 22, 2011 at 1:20 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    It is a powered (weak) sub. I wonder how it would sound off a SQ small amp. Easy enough to make a harness to attach to an amp.
  16. Jul 22, 2011 at 1:39 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Hey OP ... are these diagrams you can upload for us? Or are they just the pics as posted (which BTW are awesome!).
    So how is this thing hooked up anyway...
    • Is it just hooked to the L/R rear speakers (along iwith the ceiling mount exciters)?
    • Does it have it's own built in amp?
    • Anyone add an inline amp to this sub?
    • For that matter, anyone try to replace the cone in this thing?
  17. Jul 22, 2011 at 9:00 PM
    05Taco4x4
    2TR-FE Enthusiast
    no diagrams to share, sorry
    amp is in the sub assembly, pulls juice from rear speaker pins in radio
  18. Mar 28, 2012 at 11:10 AM
    Tokeisch
    Tokeisch Active Member
    fLORIDA
    09 tACOMA pRERUNNER
    I have a 2009 Taco Prerunner (access cab) and would like an audio schematic. For this type/model. I am doing a full audio mod and it would be greatly appreciated. Also, hiw do I upgrade the ceiling speakers and how do you access them and what is a good acceptable replacement?
  19. May 12, 2012 at 2:21 PM
    jeancmo
    jeancmo Member
    2012 black TRD
    This thread has been VERY HELPFUL!!! we want to put this subwoofer/amp in our 2012 access cab Tacoma and your wiring of the plug is exactly what we needed. BUT do have some other questions. All wiring is to the radio- is that correct? What about the sound? We're not looking for a lot, just some added bass. Thanks!!
  20. May 16, 2012 at 12:51 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    were you able to get a part number for the other side of that harness? how did you hook it up?
