Factory Nerf Bars... Chrome to Black...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jclofton, Jan 1, 2012.
  1. Jan 1, 2012 at 4:21 PM
    jclofton
    jclofton [OP] Active Member
    Conyers
    2011 TRD SPORT
    The new TRD Sport came with the factory chrome nerf bars, not my favorite but they were on it... i have to say these are some of the cheapest I've run across... in any case, I decided to go with black. At some point I'd like to add/build a functional set (like many here)... until then... this is a really inexpensive change...
  2. Jan 1, 2012 at 6:39 PM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    Looks good man, I'm not a fan of chrome either.
  3. Jan 1, 2012 at 6:44 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Thanks for posting that.... I've been wanting to do that to mine....
    Did you sand and prime them?
  4. Jan 1, 2012 at 8:21 PM
    jclofton
    Conyers
    2011 TRD SPORT
    Thanks- Happy with the way they turned out for the $$
  5. Jan 1, 2012 at 8:27 PM
    jclofton
    Conyers
    2011 TRD SPORT
    I used fine wire brush on a drill to rough up, cleaned good with acetone and 4-coats of bed liner paint (no primer needed). It's a textured finish... I thought about just having them Line-X but I think the coat will be too think for the end caps to go back on.
    As a side note, if you want add more structure a piece of flat iron running the length will bolt right up under the bottom and not be noticeable...
  6. Jan 1, 2012 at 8:37 PM
    Bloodhound
    Bloodhound Banned from the Pics Thread
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    Did yours have the plastic inserts in them? And if so, how did you get them off, did they just pop off when you pry a bit?
    Edit: I'm planning on doing my rear bumper and tube steps black this spring/summer...too cold to shoot right now.
  7. Jan 1, 2012 at 8:39 PM
    jclofton
    Conyers
    2011 TRD SPORT
    The have the plastic inserts, once you pull them off there are "nuts" on the bottom that screw off, be careful and take your time on/off... 7/16 and 1/2" and you're ready to go...
  8. Jan 1, 2012 at 8:45 PM
    Bloodhound
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Drats, just looked at your pictures again....closer...mine are tube steps...I'll figure something out I guess to get them off, otherwise I'm gonna paint over them and say eff it.
  9. Jan 2, 2012 at 8:42 AM
    ImpulseRed008
    Susan
    SC
    just mask around the step pads
