Factory Hitch and wiring harness install
Discussion in 'Towing' started by oldtimertoyota, May 27, 2011.
  1. May 27, 2011 at 7:28 PM
    oldtimertoyota
    oldtimertoyota [OP] Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    I'm just wanting to get an idea of what I am getting myself into installing the factory hitch and wiring harness. I have an 09, 4 door, SB, 4X4 base model Tacoma, the hitch looks easy but looking at the instructions for the wiring harness it looks like the install could be kind of a pain. The dealership quoted me 1.5 hrs just to install the wiring harness which means that would be about $160 which seems a bit much. Anyone install a factory harness and is it worth spending the $160 not to mess with it, or is it like most instruction manuals which make things looks more complex then they actually are.
  2. May 27, 2011 at 7:47 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
  3. May 28, 2011 at 6:01 AM
    oldtimertoyota
    New Mexico
    I had seen that but that looks like the install for the aftermaket wiring harness which I believe hooks up differently.
  4. May 31, 2011 at 5:46 AM
    RLDTACO
    RLDTACO Well-Known Member
    Bob
    Houston Tx.
    2010 DCLB PreRunner SR5
    Debadged,Tailgate theft mod,Extra D-rings,OEM bed mat,TRD exhaust, 5100 Billys@ 4 corners set@ 0 with Eibach springs, rear TSB springs.N-Fab tube Steps. TRD FJ SE wheels and Michelin LTX A/T 2's
    It took me approx. four hours to install the OEM wire harness. If you read the instuctions and take your time should be no problem. I installed the hitch first then the wire harness. There is alot of info in the towing section of TW, may find some help there also. Hope this helps.
  5. May 31, 2011 at 9:53 AM
    RLDTACO
    Bob
    Houston Tx.
    Five minutes! :eek: I need you to come and work on my truck.:D
  6. Jun 2, 2011 at 6:22 PM
    oldtimertoyota
    New Mexico
    Hey thanks for responding, I just got the factory hitch and harness today, I can see after looking at the directions this being a fairly lengthy process and I am picky so I will take my time. The installation manual looks like it is pretty detailed so that should help. I too will start with the hitch and then mess with the wiring harness after that. I'll post when I complete things and tell you how it went for me.
  7. Jun 3, 2011 at 6:04 AM
    RLDTACO
    Bob
    Houston Tx.
    Sounds like you have it under control. I'm picky about my truck also, so I searched for info on the web and took my time and really had no problems. The most difficult thing was reaching up under dash area to make the connections. Not sure what your towing but run the wires for a brake control at same time. (If you need it) Bob
  8. Jun 12, 2011 at 7:49 AM
    g7evans
    g7evans Active Member
    Garrett
    VA
    2014 DC SB
    I am getting ready to purchase the same hitch and wiring connection. what type of connection does the OEM wiring harness come with? 4 5 or 7 prong?
  9. Jun 12, 2011 at 8:04 AM
    TerryS
    TerryS Well-Known Member
    Terry
    Cape Cod, Mass.
    '24 Celestial Silver DCLB SR5
    OEM cast aluminum running boards & tonneau cover.
    As far as I can tell, the Toyota harness only comes with a 4 prong plug.
    OP: Installation wasn't hard (and I'm not a so young anymore), but I took my time. 4 hours sounds about right. The worst part was the wire connections under the dash, but only because it's so tight.
  10. Jun 12, 2011 at 8:08 AM
    g7evans
    Garrett
    VA
    2014 DC SB
    i am only towing a a 16ft alum boat and my trailer does not have breaks on it. all i need is to connect the trailer lights. will i still have to run wires up under the dash if i dont need the breaking connections?
  11. Jun 12, 2011 at 8:28 AM
    TerryS
    Terry
    Cape Cod, Mass.
    No, IMHO, you don't really need the Toyota wiring harness. It makes a separate dedicated & fused circuit for trailer lights, but I don't think it 's absolutely necessary for your little boat trailer. You can get the plug-in variety of trailer wiring at your local auto parts store, RV store, tractor supply, or even online. 15 minute installation, tops, but it powers directly from the tail lights & directionals. Here's a link to a video that shows how it's installed on an older Tacoma.
    http://www.youtube.com/watch?v=EgajKpMgZpE
  12. Jun 12, 2011 at 8:35 AM
    g7evans
    Garrett
    VA
    2014 DC SB
    sweet. thank you very much. i am assuming you just saved me alot of headache
  13. Jun 12, 2011 at 12:58 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I bought one of those etrailer light harnesses. Its a 4 plug but since you dont have trailer brakes thats fine. Installed in less than 30 minutes including tucking in all the wiring. Super easy
  14. Jun 12, 2011 at 8:45 PM
    oldtimertoyota
    New Mexico
    I have not had time to install the harness yet as I am in the process of moving, though I was actually hoping to have it done for the move. Thanks for the info, under the dash is never fun!
  15. Sep 17, 2012 at 6:44 PM
    oldtimertoyota
    New Mexico
    Figured I'd update this thread. Just completed installing the OEM wiring harness, it did take me around 4 hrs. I took my time. Under the dash and figuring the correct route to the hitch were a little tricky but definately not beyond most of us with basic mechanical skills, This thread is over a year old, I think I'm ready to haul a trailer now:D
  16. Sep 23, 2012 at 2:13 PM
    howard1945
    howard1945 New Member
    Howard
    Texas
    2012 TRD Sport Prerunner
    I have a 2012 Tacoma with towing package. I can't find the wiring harness. I have a package of wiring but I think this is for brake on trailer. Is there a light connection for trailer install and tucked away somewhere?
  17. Sep 23, 2012 at 9:28 PM
    oldtimertoyota
    New Mexico
    If you bought it with the tow package you should definately have a flat 4 connector, if the 2012 model is the same as the others I've seen it should sit a little left of the center of the hitch and be attatched to the hitch, it is a little hard to see and actually looks small.
  18. Sep 24, 2012 at 5:41 AM
    shemp
    shemp Well-Known Member
    The hard part dealing with the factory wiring harness is just routing the wire itself from the cab to the bumper. As I recall, the rest of the process was quite literally just snapping in a few modules, relays, and fuses.
  19. Sep 24, 2012 at 8:09 AM
    howard1945
    Howard
    Texas
    Thanks I found out I have to have an adapter to go in the large round plug to the left of hitch
  20. Nov 20, 2012 at 7:35 PM
    othater
    othater Well-Known Member
    SoCal-Walnut
    06 Prerunner SR5 TRD Sport
    Which OEM tow wiring harness did you buy?
    The one with the 4 pin connector?
    Who did you buy from and cost?
    Thanks
