Factory e locker, how good/bad is it?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sep1911, Nov 7, 2020.
  1. Nov 7, 2020 at 4:16 PM
    Sep1911
    Sep1911 [OP] Well-Known Member
    2016 Taco
    I’d like to get lockers for my truck and I’m trying to figure out the route I’m going to take and iron out the details. For the front I’m thinking the Eaton e locker, for the rear the only aftermarket option is the ARB. Despite having onboard air, I see too many things going wrong with an air locker, though there is a small chance I may have to go this route. So my question for you guys with the factory e locker is, is it terrible? I know engagement can be iffy based on some digging around I’ve done, but overall is it fairly reliable? Are they strong or have they been known to break? They are cheaper than setting up a ARB rear end. You can get a built unit with whatever gear ratios for under $1k, whereas the ARB carrier itself is $1k and I’d have to add in the cost of accessories to hook it up my compressor, new hardware and time to set up the rear end.
    Despite the iffy engagements I keep reading about the advantage I see is that you don’t have to worry about internal or external air leaks and the system is much simpler, so there’s far fewer things that can go wrong which in my opinion outweighs the annoyance of having to roll back and forth trying to get it to engage. What are your thoughts?
  2. Nov 7, 2020 at 4:28 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    What size axle do you have now? The Eaton is compatible with some 3rd gen variants.
    But if you have an Off-Road or Pro, the only advantage an aftermarket locker would have is bypassing the 4WD ECU for engagement. The factory e-locker in the 3rd gen is a similar style to the Eaton version.
    G8R_Taco likes this.
  3. Nov 7, 2020 at 4:52 PM
    Sep1911
    2016 Taco
    I have the 8.75” rear end. Granted I would be wiring the OEM locker myself and I’d run it off a switch.
  4. Nov 7, 2020 at 4:57 PM
    hoarder23
    Shay
    NJ
    Scratches
    You'd have to dig around here for a wiring diagram. Low Range Offroad made a version for the older style e-locker from 2nd Gens and FJs but I haven't seen anything for a 3rd Gen.
  5. Nov 7, 2020 at 4:58 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    How did you end up with the 8.75" rear end without an E-locker?
  6. Nov 7, 2020 at 4:59 PM
    hoarder23
    Shay
    NJ
    Scratches
    Rowing his truck
    suaveflooder and TireFire like this.
  7. Nov 7, 2020 at 5:01 PM
    hoarder23
    Shay
    NJ
    Scratches
    This thread and the links @BigWhiteTRD posted will help you
    3JOH22A likes this.
  8. Nov 7, 2020 at 5:01 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    The Harrop elocker and factory 3rd gen locker are very dissimilar in their actuation methods. The factory elocker directly plunges the locking cam into the side gear to lock the side gear to the carrier. The issue with the factory locker is you need crisp alignment and no bind to get it locked and unlocked. The Harrop elocker uses an electromagnet to generate torque drag on a ramp mechanism that plunges pins into the clutch mechanism. The Harrop therefore experiences a lot of deadband or lash as the wheel direction changes because this ramp mechanism unwinds and rewinds during direction change.
    The Harrop costs about $1200 and an ARB is $1000 plus air source.
    The ARB definitely can have leaking issues but 95% of the time it's install error or install shortcuts. The ARB engagement is instant and powerful. Elockers lack that powerful engagement.
    If you ask me, the ARB is much simpler and robust in mechanical design than the Harrop.
    You can't go wrong. Pick your poison and don't look back.
    whatstcp, TireFire and G8R_Taco like this.
  9. Nov 7, 2020 at 5:14 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    I went the the ARB up front with no problems. ECGS supplied 4:88 built differentials and ARB dual compressor (I sent them back the cores). MORE off road makes a nice bracket for the compressor with the tank underneath. MESO custom switch panels are up for sale at the moment if you want one for the switches. A local shop installed the diffs, and my brother and I installed the compressor and tank. I have the e locker in the rear. It's a solid setup. No problems here except for overfilling the front differential (my fault).
    I don't have experience with the Eaton, but I've heard they momentarily disengage when going in reverse . @ShimStack and @hoarder23 pretty much covered it. GL with whatever you decide to do. ECGS was super helpful over the phone when I ordered.
  10. Nov 7, 2020 at 5:56 PM
    Sep1911
    2016 Taco
    Manual trucks get open 8.75. TRD OR and Pro get the 8.75 with the e locker. Everything else gets the 8” rear end
    3JOH22A[QUOTED] likes this.
  11. Nov 7, 2020 at 6:02 PM
    barnes828
    barnes828 Well-Known Member
    Nathan
    Vancouver, Wa
    21’ DCLB OR WHITE
    My dad has ARB air lockers front and rear on his 2000 Cherokee sport. Only issue he had was this last year (about 5 years after having them installed) he had some air leaking and it was a simple fix. They lock up and unlock quickly. I’d say go for it
  12. Nov 7, 2020 at 6:07 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Easiest would be putting in a whole rear axle from a TRD off-road and then just wire up the elocker however you want
    VeeSix and whatstcp like this.
  13. Nov 7, 2020 at 6:49 PM
    Sep1911
    2016 Taco
    I’m running 4.88s so I’d have to tear it down either way.
  14. Nov 7, 2020 at 8:35 PM
    JEFFRPM
    JEFFRPM Well-Known Member
    Jeff
    2018 inferno Double cab long bed 4x4
    17 x 8.5 KMC wheels, yokohama 285-70-17 geolander, 3" lift, 800 watts of alpine, leer shell, front & rear cloud cameras,
    Anybody know how I can lock my factory rear diff anytime I want? AND not throw any stupid azz codes?
    Another question what gear ratio does a 2018 Double cab, long bed, auto trans, TRD Off road come with? I'm guessing somewhere in the 3.73 to 4.11 range......how far off am I?
  15. Nov 7, 2020 at 9:12 PM
    ferntr33
    ferntr33 Well-Known Member
    AT 3.9 MT 4.3 IIRC. Post #7 has the info on anytime locker.
    As for oem locker, I don’t think anyone really breaks them. Also I have learned to engage it before you need it. Not after. If you have an ARB you can engage it later.
