Factory deck on subs
Discussion in 'Audio & Video' started by StancedToy, Feb 20, 2017.
  1. Feb 20, 2017 at 7:13 PM
    StancedToy
    StancedToy [OP] Member
    Kyle
    2013 Gunmetal Tacoma Pre
    I'm getting a ASG package single 12"kicker sub box sealed with a BOSS AUDIO R1100M amp and BOSS AUDIO KIT2 8 Gauge amplifier installation. I'm planning to run these on my Tacoma 2013 factory deck and was wondering if I needed a converter for them. If so what converter would I need for this set up ?
  2. Feb 20, 2017 at 7:48 PM
    19o4Taco
    19o4Taco Well-Known Member
    Hi I literally just setup a system this weekend and I am waiting on my custom box. You can use a cheaper loc which was my initial route because I had a cheaper loc from my old car I ended up buying a Audio Control lc7i. You can also get lc2 if you just wanna amp subs. Lc6 will get the job with 2 amps. There is also an lc8. Honestly on a budget build I would say go for a cheaper loc but after getting the loc7 seeing what it can do and the tuning options with bass roll off and I say invest a little more and go with at least an lc6. Just my 2 cents.
  3. Feb 21, 2017 at 4:56 AM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    That amp accepts high level inputs so you don't need one. You're scraping the bottom of the barrel with that amp choice though (boss). Good luck.
    jv_74 and 19o4Taco like this.
  4. Feb 21, 2017 at 12:33 PM
    StancedToy
    Kyle
    Would a Rockville RXA-T1 car amplifier 1500W 2 channel Bridgeable be good with a Comp 12" kicker ?
  5. Feb 21, 2017 at 2:00 PM
    rob feature
    rob feature Tacos!
    Colorado
    Rockville isn't much better. If any. Like boss, they tend to be overrated and noisy. And if you're truly looking for a kilowatt and above, 8 ga ain't gonna cut it either. NVX makes some decent budget amps as does Zapco (studio)...among many others.
  6. Feb 21, 2017 at 3:15 PM
    StancedToy
    Kyle
    Could u give me couple well named amps that prouduce good bass and sound for a good & resonable price
  7. Feb 21, 2017 at 4:19 PM
    Rangerat
    Rangerat Member
    Louisiana
    2017 SR5 DCSB 4x2 Barcelona Red
    Pioneer GM D8601 can be had very cheap on Amazon. Need 4ga power and ground.
  8. Feb 21, 2017 at 4:37 PM
    rob feature
    rob feature Tacos!
    Colorado
  9. Feb 22, 2017 at 10:28 AM
    jv_74
    jv_74 Well-Known Member
    Jesse
    Filthadelphia
    2015 DCSB Silver Sky Metallic
    No need for a converter if the amp accepts high-level inputs, but I'm just here to echo the fact that Boss generally makes garbage.
  10. Mar 1, 2017 at 8:28 PM
    SocalTaco15
    SocalTaco15 Well-Known Member
    Glen
    Socal, Orange County
    I'll catch crap for this, but I'm running this amp (because I found one for less than $20 new online) with the jbl sub added to my stock entune. It takes high level inputs, so no loc needed. Catch the rear speaker wires under the front door plastics and run them to the rear. I still have to clean up the final homeruns, but it sounds better than stock!
