Fabtech, ProComp 6" lift or more. Pictures
Discussion in 'Suspension' started by toku58, Jul 2, 2009.
  1. Dec 1, 2018 at 7:46 PM
    MCDavis
    MCDavis Taco life is over. Full time 4wd for the win.
    RIC, VA
    2017 TRD Sport 4wd (SOLD) - Currently in a 2016 GX460
    Thanks
    I’m up 4 turns on the drivers side and 3 turns on the passenger side. No ill effects.
  2. Dec 2, 2018 at 4:25 PM
    Watdt
    Watdt Active Member
    So are you still sitting at 6”?
  3. Dec 2, 2018 at 4:32 PM
    MCDavis
    RIC, VA
    No. I’m up about .5-.75”
  4. Dec 3, 2018 at 6:46 AM
    Watdt
    Watdt Active Member
    Any problems running stock upper control arms
  5. Dec 3, 2018 at 10:10 AM
    MCDavis
    RIC, VA
    "problems" is hard to define.
    For what I use my truck for, no, I have no perceived issues. My alignment guys got me about 3* of caster on stock uppers. Would I like more? yes, but it tracks pretty well for what it is.
    Trd sport tacoma likes this.
  6. Dec 4, 2018 at 8:35 PM
    Tuby07
    Tuby07 Active Member
    Central California
    2007 TACOMA DCLB SPORT
    Question for you guys. I have a 2007 dclb trd sport 4x4 with SnugTop cap. Mostly used for/getting to hunting and camping grounds, no extreme crawling, so I avg about 3-4000 miles a year. Currently on fabtech basic 6” spacer lift, aftermarket bumper, warn vr10000s winch, and sliders. Tires- 295/75/17 stt pros. Front is sitting about 25” from center of hub to fender. The following parts will be installed and removing the spacer and trd spring/shock.
    1. Wheelers t1 springs (620lbs)
    2. Front- RCD extended 5100 Bilstein, rear- bilstein 5125 (using fabtech rear setup)
    3. SPC UCAs
    4. Wheelers 1/2” spacer (for full 6” lift, not sure if needed)
    Anyone have similar setup? After install and alignment, what should my alignment specs be? Hope some of you guys don’t mind sharing your alignment printout/specs. Thanks in advance!
  7. Jan 14, 2019 at 7:59 AM
    NEFLmudder
    NEFLmudder Well-Known Member
    Jacksonville
    2013 DCSB TRD
    6" Zone lift kit, 20" Tracker Level 8 (20x9 0 offset) with Firestone Destination AT 275/65/20, Debadged, double din touchscreen pioneer dvd, 10" kicker cxr in a taco tunes box and a 600.1 kicker amp. Custom made surf racks utilizing the track system.
    i am running the zone 6" mall crawler drop bracket kit (aka strut spacers and blocks). I don't hard core wheel and it has been great for 5 years now. I also upgraded the UCA to JBAoffroad's. I got to say the alignment issue I was having a problem with alignment and seems to ride a little better. My truck is almost paid off and will be upgrading the leaf pack to a custom one from Alcan and this Forum is full of great reviews from them and wanting to upgrade to remove the strut spacers. I just don't want to spend the $1400+ on Fox, Icon, King coil overs. Has anyone found any other options. I know rough country just came out with 6" lift shocks to eliminate the spacer but not a fan of rough country.
  8. Jan 14, 2019 at 10:44 AM
    5678ta
    5678ta Well-Known Member
    Hogan
    Henderson, NV
    '18 ECLB Colorado ZR2
    Bilstein F4-BE5-E122-T0
    With stock springs will net ~4.5" lift. Find a 1-2" lift spring and you should be gold.
    BORNWILDGUY and smw62891 like this.
  9. Jan 14, 2019 at 12:39 PM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    ^ What 5678ta said. I ran the same shocks up front which is a good option to the more expensive coilovers.
  10. Jan 14, 2019 at 3:04 PM
    NEFLmudder
    Jacksonville
    2013 DCSB TRD
    How was the ride? Noticeable improvement over the spacer?
  11. Jan 14, 2019 at 3:09 PM
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    Button on the right!
  12. Jan 14, 2019 at 3:16 PM
    Jmad1997
    Jmad1997 Well-Known Member
    2005 TRD sport long bed 6" fab tech lift
    I’ll have a set of the Bilstein for sale soon with 620lb coils as I just got my Kings in. And I will include a .5” spacer to help level out. They only have about 250 miles on them.
    uh_salt_rifle likes this.
  13. Jan 14, 2019 at 3:53 PM
    Neutral
    Neutral Well-Known Member
    Guy
    Alabama
    14 DCSB SR5 4x4
    RCD 4.5", rims & tires (17s with 33s), Pelfreybilt Hybrid Bumper, Rigid lights, Superwinch Tigershark, Wet Okole's, 4.56 gears.
    This! I upgraded to Fox 2.5s up front around September 2018 then in November I also upgraded the rears to Fox 2.0s along with Alcan 4" lift springs. Worth every penny. I wish I would've done it when I first chose my RCD lift. The Bilstiens from my RCD lift were fairly good. I added 620lbs spring later, but if you plan on adding armour, just bite the bullet and buy Fox. I purchased all my Fox suspension through AccuTune. They were even revalved them for me.
    MCDavis likes this.
  14. Jan 14, 2019 at 6:15 PM
    BORNWILDGUY
    Rich
    Florida
    The ride was good with the bilstiens. I never had heavy bumpers installed so for my usage was very happy. I ran the stock coils on mine with a 1/2 spacer on both sides along with the 1/4 on the driver side to compensate for the taco lean.
    To be honest what made my truck ride better was going with a different sway bar bracket in the front. I personally don't think the swaybar lowering brackets in the db kits bring the swaybar down low enough . Only db kit I have seen which brings it down low enough is the Fabtech kit. Here is the link to where you can see what I used. Some people even take theirs off which is up to you.
    https://www.tacomaworld.com/threads/new-swaybar-drop-bracket-option.266579/
  15. Jan 29, 2019 at 3:41 PM
    DavisluvsTacos
    DavisluvsTacos GONE FULL-RETARD!
    Beyond the sun
  16. Jan 30, 2019 at 5:26 AM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    ChadsPride likes this.
  17. Jan 30, 2019 at 5:40 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Thanks, I like this truck a lot!
  18. Jan 30, 2019 at 11:52 AM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    :headbang::headbang::headbang::headbang:
    ChadsPride[QUOTED] likes this.
  19. Feb 3, 2019 at 11:57 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    My old girl is still going....8 years and 180,000 miles.
    And shes grown up over the years.
  20. Feb 6, 2019 at 4:37 PM
    Overkill07
    Overkill07 Tacoitis
    Warren
    Texas
    14 TRD O/R DC MGM
    A few audio upgrades, tinted windows, remote start because it f'n hot in Texas! 6in Fabtech DB lift, 17x9 Fuel Trophy wheels, 315/70/17 Duratracs,BAMF 80in sliders w/kickout, Prinsu cab rack w/30in Heretic light bar, custom bedside decals, custom hi-lift jack brackets, US Offroad front bumper w/winch, bed rack with RTT, CB, Short wave base station, Ultra gauge, color matched grille surround, an ungodly amount of recover gear, ARB fridge, hood struts, RotoPax, traction pads.
    How do you like those coilovers? I just picked up the same set and have yet to install them.
