Fabricator Recommendations San Diego/SoCal
Discussion in 'Southern California' started by Babish_SD, Feb 19, 2020.
  1. Feb 19, 2020 at 10:10 PM
    Babish_SD
    Babish_SD [OP] Well-Known Member
    Brian
    2016 Quicksand Tacoma TRD Sport
    Looking for recommendations in SoCal, more specifically San Diego, for fabricators to re-weld the mounting points on my Pelfreybilt Aluminum front bumper. The welds to begin with were a POS, but recently I was in an accident which has increased the crack length.
    I've heard through the grapevine Aluminum gets weaker when it gets re-done (sorry no idea the terminology here). Is this true and true enough to not want to do?
  2. Feb 20, 2020 at 8:24 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    I don't actually. I know @Shmellmopwho just dusted off his spool gun.
    @Speed Freek might be closer but I don't know if he does aluminum.
  3. Feb 23, 2020 at 3:21 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
  4. Feb 23, 2020 at 3:49 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    aluminum is difficult to work with. TIG welding would be the way to go. Past my skill set.
    whatstcp and BalutTaco like this.
  5. Feb 23, 2020 at 3:57 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    My dad boat had an aluminum boat with a leak. A aluminum boat maker recommended to slap another aluminium plate on top to stop the leak. I don't know if this comment will help out LOL.
    edit: if you torch the aluminum it makes the alloy in the metal weaker.
  6. Feb 26, 2020 at 11:11 AM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    this. I wouldn’t weld it with a spool gun. You also may want to preheat the part a little so it doesn’t form any cracks during the cool down
  7. Feb 26, 2020 at 11:23 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Thanks for the ref. Yes I have a 350amp TIG machine so aluminum is not a problem.
    I would not recommend spool gun welding this as its more of a spray arc process. Much better to just use a large Tungsten, pre-heat and get a good 2 or 3 pass weld in it after beveling out the crack to create a pocket for the material.
    Drainbung and GHOST SHIP[QUOTED] like this.
  8. Feb 26, 2020 at 11:43 AM
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    I had some welding done years ago. It’s going to be expensive, because there aren’t a lot of people set up to tig weld. I just found some random guy in the yellow pages (yes, it was that long ago lol)
  9. Feb 26, 2020 at 12:50 PM
    glorifiedwelder
    jason
    Santa Clarita, ca
    I also wouldn’t let just any yahoo weld it either. Personally if it was me I would remove it and take it to a high end welding shop. I see guys all the time that are mediocre mig welders thinking because they have a tig welder glueing some aluminum together won’t be any issue. Aluminum welds will be far more likely to crack over time than steel. It’s also not that hard to melt aluminum rod on top of the base metal and make it look decent without getting any real penetration.
    just for refernce I don’t do a ton of aluminum welding on my side work but I do weld 3/4” thick aluminum plates at work that are used as high voltage conductors in the bulk power grid.
    whatstcp likes this.
  10. Feb 27, 2020 at 9:38 AM
    Speed Freek
    Thats why I drill a hole at start/end of the crack and bevel out the material that is cracked, pre-heat and do multiple pass over it. I do quite a bit of TIG aluminum. But as you said if you dont kill the crack it will always start again and get worse every time.
    Drainbung and whatstcp like this.
  11. Dec 8, 2020 at 8:06 PM
    VYPER
    VYPER Well-Known Member
    Alex
    2010 Silver Tacoma TRD
    Could you possibly weld on some sliders for me? Im in West Covina, i can head out to you
