fabrication and 97/99 plow truck on a hot-dip galvanized frame
Discussion in '1st Gen. Tacomas (1995-2004)' started by ColinD, Mar 29, 2023.
  1. Mar 30, 2023 at 4:11 PM
    #41
    ColinD
    ColinD [OP] Well-Known Member
    Minnesota
    97 Tacoma SR5 V6
    I've been in a lifelong battle against corrosion and I didn't even think about galvanizing as a possibility until a friend of mine mentioned his plan to have his Land Rover frame done. Big time light bulb moment.
  2. Mar 30, 2023 at 9:27 PM
    #42
    Nicklovin
    Nicklovin Mall Crawlin Through Life
    Nick
    Huntington Beach, CA
    00 The Tunda - 0̶4̶ P̶r̶e̶r̶u̶n̶n̶e̶r̶ - 0̶1̶ O̶v̶e̶r̶l̶a̶n̶d̶e̶r̶ - 07 FJ Mall Crawler Xtrme
    Tacoless
    There’s just so much awesome in this thread :D
    A TDI flatbed SASed Tacoma would be sweet
    Huh didn’t know those F650s had a Cummins engine in it. Is that a common thing?
  3. Mar 30, 2023 at 11:15 PM
    #43
    ColinD
    Minnesota
    97 Tacoma SR5 V6
    Yup. You could spec the F650/750 a million different ways to meet your needs as a fleet buyer. They had the typical range of medium duty truck drivetrain options - Cat C7/3126, Cummins ISB, Powerstroke (7.3, 6.0, or 6.7 depending on the year,) 6.8 gas V10, various Allison and manual trans options, single and 2-speed rear ends, either air or hydraulic brakes, etc. It's basically an International 4300/4400 with a Super Duty cab.
    Medium- and heavy-duty trucks are very modular and tend to use a lot of the same components from Bendix, Dana, Wabco, etc. Beneath the skin, there's not much difference between a Paccar (Kenworth/Peterbilt,) an International, and a Freightliner. Even some Hino, Volvo, larger Isuzu etc. They're all built on a 34 inch wide ladder frame with solid axles front and rear, like they've been building trucks for 100 years. It would probably be relatively simple to swap a DT466, Detroit 50-series, or other truck engine if you had access to a donor truck in a salvage yard (and a mag-base drill.)
    If I were going to build another one, I'd get an Allison MD3060 and a Cummins C8.3 or ISL9. The 6.7 is fine, but it's not a ton of power for a truck this size. A 9-10 liter wet sleeve engine would get the same fuel economy and last longer between overhauls, while holding more speed uphill. Commercial truck engines are typically derated so you can stick an idiot employee in them and have him hammer up the rocky mountains all day long at full GVWR with the pedal on the floor and never burn it down, and do that for 350k miles with only routine maintence. Usually a 7 liter engine will be rated around 250hp and a 9 liter is 300-350hp. Pickups are spec'd a lot hotter IMO because the manufacturers know that most people only use them to haul their family to Texas Roadhouse and pull a bass boat every third weekend.
  4. Mar 31, 2023 at 11:53 AM
    #44
    cynicalrider
    cynicalrider #NFG
    Jersey
    Laxtoy and ColinD[OP] like this.
  5. Mar 31, 2023 at 11:58 AM
    #45
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Damn thats wild. Sub'd to read the full thread next week :D
    ColinD[QUOTED][OP] likes this.
  6. Mar 31, 2023 at 12:25 PM
    #46
    ColinD
    Minnesota
    97 Tacoma SR5 V6
    I'm just gonna post all my junk right here. If nobody outside the 1st gen subforum sees it, I don't really care. :D
    More galvanized stuff... I spec'd this Supreme 'Kold King XL' body for a Freightliner M2 in 2016, they built a really trashy ICC bumper out of C channel, and then put dense rubber bumpers on the open stainless extrusions on either side of the door opening. Of course, with the flush-mounted ICC bumper, all the force of bumping docks was concentrated into the door frame and the whole ass end got smooshed. I got on my CAD program and drew up some 3/16 stainless patch panels to repair the damaged door frame, burned them out on the plasma table and bent them on the press brake, then cut out the damaged material and TIG welded the patches onto the body. I made a new ICC bumper out of thick-walled 4x4 tubing, and built flanges to transmit the force directly into the truck's frame rails. I welded a 2" receiver tube and chain bracket to the bottom so I can flat-tow my VW on a tow bar when I drop the truck off for dealer service (got sick of waiting for a ride after all these years, I'll do it my damned self.) I put expanded mesh on the bottom steps for traction. I thought the mesh would be likely to tear someone's shin to the bone if he slipped and caught the edge, so I used grip tape on the top section. I welded some little pieces of flat bar to the top in order to protect the grip tape from being scraped off by a dock leveling plate upon retraction. Still gets messed up by forklift forks at some of our street-level delivery stops, unfortunately.
    I built a second identical ICC bumper for our Kenworth T270, after I spec'd a new Johnson refrigerated body for it this last year.
    IMG_2020.jpg IMG_1997.jpg IMG_1991.jpg IMG_2013.jpg IMG_2141.jpg IMG_2353.jpg IMG_2368.jpg IMG_2370.jpg IMG_2793.jpg IMG_2792.jpg IMG_2390.jpg
    Nicklovin likes this.
  7. Mar 31, 2023 at 12:34 PM
    #47
    ColinD
    Minnesota
    97 Tacoma SR5 V6
    Bonus: VW on the aforementioned tow bar, and a little night flight with my girl to get dinner at Holman's Table in St. Paul.
    "Cleared into the Minneapolis-St. Paul bravo; maintain VFR at or below 3,500. Traffic five miles to your seven o'clock is an Airbus heavy." :bananadance:
    Final approach to KSTP runway 14 is cool... takes you right next to downtown St. Paul and south over the river.
  8. Mar 31, 2023 at 1:09 PM
    #48
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    Looks like WY-28 between Farson and South Pass.
  9. Mar 31, 2023 at 1:13 PM
    #49
    Gyrkin
    Wyoming
    Did you know that 80% of all Fords made in the last 20 years are still on the road......the other 20% actually made it all the way home. :rofl:
  10. Mar 31, 2023 at 1:14 PM
    #50
    ColinD
    Minnesota
    97 Tacoma SR5 V6
    That's probably what it is. I'm usually able to stay on the interstates until Gillette or Casper, and then I have to take some hilly 2-lane diagonally to the southwest of the state. Been a couple years, I don't recall the exact route. Beautiful country.
    i actually took a trip out there after the Tacoma trip, I found a deal on a 16x54 American Pacemaker in Ogden, UT, and dragged it home. Took the GS again, rode to West Wendover NV, did some wheelies on the salt flats, etc.
    A45093A9-6A65-47C2-B8F1-53808CB9E46C.jpg 9DB4A793-7CEB-4EE3-9D5F-0A10CC96D7C8.jpg BCDD23B8-7A92-4E53-84B9-BDF762E73522.jpg 3EA0C829-0FF2-4EB6-97F1-2FFADFBA972D.jpg
  11. Mar 31, 2023 at 1:27 PM
    #51
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers and a skewp
    :101010::101010:
    Any more pics of the vw:anonymous:
  12. Mar 31, 2023 at 1:30 PM
    #52
    perterra
    perterra Well-Known Member
    Tejas
    Good thread, I like it
    ColinD[OP] likes this.
  13. Mar 31, 2023 at 1:37 PM
    #53
    ColinD
    Minnesota
    97 Tacoma SR5 V6
    You know I come heavy with the pics :rofl:
    Pike's Peak... my tune was pretty upset about the density altitude up there.6DFA03F3-B72C-4124-8D5C-FD18C2AB4D3C.jpg C7827856-0122-4193-9F5F-0119D508A610.jpg C9D5FA75-D6C0-43E6-8A29-20765A79EE91.jpg
    Many, many moons ago, before building square tubing rockers. Stock engine back then.
    That one time I got a little rowdy and blew a hole through a stock piston. Rebuilt the bottom end with ceramic coated BRM pistons with improved oil cooling under the crowns and more beef. Painted the new block GM 'Ladies and Magenta-man' basecoat/clearcoat because it's a girly Beetle.
  14. Mar 31, 2023 at 5:45 PM
    #54
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Damn, galvanizing that could not have been cheap
    You’re like a mad scientist, pretty frikkin baddass
    cruxofthebisquit and ColinD[OP] like this.
  15. Mar 31, 2023 at 6:05 PM
    #55
    ColinD
    Minnesota
    97 Tacoma SR5 V6
    It's incredibly cheap, like 45¢/lb. The labor to disassemble and reassemble a truck would be the expensive part.
    All the flatbed parts for the F650 cost about $740. The Tacoma parts didn't even meet the minimum weight where they begin to bill by the pound, so they charged me the base fee of $309 out the door. I even threw in a few extra items, like a big steel column and frame for our business' road sign:
  16. Apr 1, 2023 at 7:00 AM
    #56
    ColinD
    Minnesota
    97 Tacoma SR5 V6
    17B2C45D-6E18-4680-85D2-C20D2EAC2D8F.jpg 0832D41C-CD9B-4E73-8FC5-571BBED28046.jpg
    April 1st. 53' trailer full of organic portabella is inbound in 1 hour... what a stupid place to live.
    Squirt and AllTacosFloat like this.
  17. Apr 1, 2023 at 9:08 AM
    #57
    ColinD
    Minnesota
    97 Tacoma SR5 V6
    Wheeeewwwwwwww
    Gotta wrap this up quick, I have a Cessna 172 booked at 2pm, gonna chug down to Iowa with a safety pilot and log some simulated IMC time under the foggles. :rolleyes:
    Squirt likes this.
  18. Apr 1, 2023 at 8:15 PM
    #58
    Icecoast
    Icecoast Active Member
    How do you feel about beans in chili?
    Squirt likes this.
  19. Apr 1, 2023 at 10:40 PM
    #59
    ColinD
    Minnesota
    97 Tacoma SR5 V6
    Chili without beans is hot dog sauce.
    essjay likes this.
  20. Apr 1, 2023 at 10:52 PM
    #60
    ColinD
    Minnesota
    97 Tacoma SR5 V6
    Nose wheel tire on the Cessna became flat somewhere over southwest Minnesota. Landed at KSUX (lol) and it was shimmying like crazy when I slowed down, almost understeered into the grass when I took the taxiway. Told the tower what was up and they said "say intentions" so I told them I was gonna ride a wheelie to the FBO. Did that, got an A&P mechanic to come out and replace the tube, stole a granola bar and a crew car from the FBO and took a tour of scenic Sioux City, Iowa, and then flew home. :bikewhoops:
