Extra wire on positive battery terminal
Discussion in 'New Members' started by Takoma23, Sep 20, 2020.
  1. Sep 20, 2020 at 9:13 AM
    Takoma23
    Takoma23 [OP] New Member
    Guys I need some help identifying this wire thats on the positive side of battery post. Its a smaller gauge and looks like its for a aftermarket device definitely not oem. I'm not sure if it's for an alarm addon or an amp wire? The battery lost its charge on the truck because I haven't driven it for more than a month. When I got back home I was able to jump the battery and it ran fine. I'm thinking it can contribute to some sort of parasitic drain for the battery? The wire leads right off the battery to a small dnf amp box its says 300A on it. The wire seems to be going towards the driver side looking at it from the hood. I've attached some pictures to this thread. My truck is a Tacoma 08 V6 4WD TRD 4.0L Double cab. Any advice would help! Thanks
  2. Sep 20, 2020 at 9:15 AM
    Shellshock
    Iowa
    Keep following the wire. Probably goes through the firewall with the main harness then to whatever it’s running
  3. Sep 20, 2020 at 9:16 AM
    Micatom33
    Micatom33 Under the Truck with Beer!
    Santa Cruz,CA
    2008 BSP DCSB
    Welcome to TW :cheers:
    Now try and track that wire down from the inside and see where it goes.
  4. Sep 20, 2020 at 9:17 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
  5. Sep 20, 2020 at 9:18 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard new member
    Starter wire?
  6. Sep 20, 2020 at 9:20 AM
    su.b.rat
    su.b.rat broken truck
    that box is a fuse holder commonly used in stereo installs. if you track it down and don't find a connection then just remove it. if it doesn't connect to anything past the fuse box there was no parasitic drain and it's just your old battery.
  7. Sep 20, 2020 at 9:20 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Dumbass PO has a wire that’s fused well beyond its current rating lmao, if that’s a 300A fuse.
    Unbolt it from the terminal before you do anything else. That’s a potential fire hazard.
    then trace and remove.
    Bigdaddy4760 likes this.
  8. Sep 20, 2020 at 10:48 AM
    Bigdaddy4760
    Maner
    Poolville Texas
  9. Sep 20, 2020 at 2:05 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    Takoma23[OP] likes this.
