Extended length abs wire?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jeff1795, Aug 13, 2017.
  1. Aug 13, 2017 at 6:02 PM
    Jeff1795
    Jeff1795 [OP] Well-Known Member
    Panama City FL
    LT 2017 TRD Sport 4x4 Access Cab 6-Speed
    Anyone know of a company that makes extended length abs wires for the front? Or what other people with big lifts or long travel are doing. I have limiting straps and on a lift it's perfect and not too tight. But today I went a little too crazy and well...
    By the way for those of you who haven't had this happen yet it doesn't let you engage 4wd. So what ever you just went through that broke it in the first place you have to go back through in 2wd!
    mikestaco17, tomwil and mcharfauros like this.
  2. Aug 13, 2017 at 6:33 PM
    su.b.rat
    su.b.rat broken truck
  3. Aug 13, 2017 at 6:36 PM
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    Splice and extend 3 inches :notsure:
    Joe23 likes this.
  4. Aug 13, 2017 at 6:40 PM
    Bishop84
    Bishop84 Well-Known Member
    I usually unbolt the top brackets and pull it down further by bending them, now you can simply splice and extend.
    tcjacado likes this.
  5. Aug 13, 2017 at 6:41 PM
    90yota
    88 T4R / 15 F350
    Stock....ish
    I'd buy a spare cable so that way you splice the spare and keep the same guage wire and color scheme
    TacoEspecial and mikestaco17 like this.
  6. Aug 13, 2017 at 6:55 PM
    Jeff1795
    Panama City FL
    @St.Germain they sell them?
    @90yota thats what I was thinking too but the wires are in molded rubber and I need a lot more than 3 inches. I'm worried about all the slack catching on something. I'm curious to see pics of how other people do it. And what problems they incounter with it snagging on things.
    @Bishop84 i have 2 clips undone and the last bolt/bracket on the spindle is taken off.
    90yota likes this.
  7. Aug 13, 2017 at 8:07 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    I would:
    cut ends clean
    solder extension ~5"
    waterproof heatshrink
    Covered in tech flex style loom.
    Done
  8. Aug 13, 2017 at 8:15 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    I had enough slack by just adjusting it in the clips that held it. I've got drop brackets as well, so I have even bigger droop. You sure you didn't snag it on a branch or something.
    I'd prefer not to cut and splice ABS stuff. I'm sure you can find the slack you need.
    mikestaco17 likes this.
  9. Aug 13, 2017 at 8:17 PM
    90yota
    88 T4R / 15 F350
    Stock....ish
    he's running an LT kit not sure the length though
    Diablo169[QUOTED] likes this.
  10. Aug 13, 2017 at 8:25 PM
    erok81
    erok81 Well-Known Member
    Imposter
    Maybe reroute them?
    I have a +3.5 on mine. They aren't even close to tight at full droop. :notsure:
    Paul631, Diablo169 and 90yota like this.
  11. Aug 13, 2017 at 9:26 PM
    MESO
    State of Jefferson
    He caught it on a curb guys. It didn't snap from hyper extension.
    Lt. Dangle likes this.
  12. Aug 13, 2017 at 9:45 PM
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    I've had cut abs sensors re soldered only to have them trigger a MIL later down the road. I'm no expert but I'm guessing the pulse readings they provide are sensitive to interference and need good shielding which splicing may not provide.
    inksin, hiPSI and Omar RVA like this.
  13. Aug 13, 2017 at 9:46 PM
    erok81
    Imposter
    If that's the case just extend them with bailing wire. :hattip:
    TrapComa likes this.
  14. Aug 13, 2017 at 9:49 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Correct, the sensor wiring is pretty well shielded. They're not exactly easy to extend
  15. Aug 14, 2017 at 3:18 AM
    Jeff1795
    Panama City FL
    @Scooby24 thats exactly what I was worried about.
    @erok81 how did you re route them with your kit?
  16. Aug 14, 2017 at 5:06 AM
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    This. Multiple people have tried to "fix" the abs wire and splicing tends not to work.
    OP - best bet is to reroute.
    OA
  17. Aug 14, 2017 at 6:19 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  18. Aug 14, 2017 at 8:22 AM
    erok81
    Imposter
    This is the best pic I have. I cleaned it up a bit before I was done but you can see the routing at least.
  19. Aug 14, 2017 at 8:52 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Pretty sure those wires have a specific resistance and drop value and any new wire would have to have the same. Adding a "splice" would change that and could cause problems. Think about what signal those wires carry. It's not an extension cord or a speaker wire.
    Omar RVA likes this.
  20. Aug 14, 2017 at 3:14 PM
    Jeff1795
    Panama City FL
    Yes I splicing is just something that I don't see being an option. I understand how the sensor works and don't want to mess with a $2400 skid control ecm (what the sensors are hooked directly into) yes no fuse just straight to the skid control ecm... I have wiring schematics as reference if anyone wants to see. And as far as a reroute goes I thought they were... I took clips out to get a tad more length out of them. I guess not enough. But upon further examination of the wire it doesn't seem like I hit anything.
    @erok81 you haven't had any issues? Have you beat on it hard or jumped it yet?
    hiPSI likes this.
