exploded diagram of front diff?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nrvale0, Jan 11, 2019.
  1. Jan 11, 2019 at 9:13 AM
    nrvale0
    nrvale0 [OP] Member
    Nathan
    '14 Taco 4L manual
    Anyone know where I might find a exploded diagram of the front diff? Shop says I have a bad needle valve which has put some very small flakes of metal in the diff oil and are asking $800 to fix. This is at 85k so I would expect a little bit of wear.
    I'm 1) trying to understand if the needle valve is for venting or locking the diff and get a sense of whether or not this is problem I should wrench myself.
    thx
  2. Jan 11, 2019 at 9:15 AM
    JonathanH
    JonathanH Well-Known Member
    Jonathan
    Southern Maryland
    11' DCLB
    Like this?
    Shamal, Kevlarster and Marc70 like this.
  3. Jan 11, 2019 at 9:24 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Needle valve or needle bearing? There is a needle bearing where the drivers side cv axle goes into the diff. Wiggle the cv where it entere the diff. Mine has almost 1/4" of play. I'll be replacing that with the ECGS bushing.
    It looks like it's 41331G in the pic above.
    Good luck
  4. Jan 12, 2019 at 3:14 PM
    nrvale0
    nrvale0 [OP] Member
    Nathan
    '14 Taco 4L manual
    Hey, thanks for that. Useful for getting at least an idea.
    JonathanH[QUOTED] likes this.
  5. Jan 12, 2019 at 3:16 PM
    nrvale0
    nrvale0 [OP] Member
    Nathan
    '14 Taco 4L manual
    Indeed. It's a needle bearing and not a needle valve. Just had a lot going on that day and misheard what the tech said. Interesting that you have that much play. I'll have to check mine to compare. I'm about to do back-to-back x-country drives so I'm feeling inclined to just go ahead and clean things up up front.
  6. Jan 12, 2019 at 5:45 PM
    Larzzzz
    Larry
    MA
    I didn't measure it, but it was way more than i expected and the passenger side doesn't move.
  7. Jan 12, 2019 at 6:17 PM
    mrlee
    mrlee I like crunchy Tacos!!
    2013 TRD Sport (Yeah, it's gotta skewp, Haterz gonna hate)
    Bed rug, ARE bed top, Weathertechs. Little goodies here and there!
    I first read this as exloded Diaphram, I'm like wtf is going on in here? Someone had a bad day, then opened it up to my disappointment.
  8. Jan 12, 2019 at 6:45 PM
    OKTACO
    OKTACO Well-Known Member
    Ty
    2005 SR5 Taco
    Sounds pretty steep for a dealer, looks like they are probably tacking 120+ for a drain and fill on the front diff not sure what else they may be adding
  9. Jan 13, 2019 at 12:13 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    It's fairly common to have that much play in the driver's side axle, at least from what I've read here on TW. Mine has since I bought it with 18,000 miles. I don't wheel and only use 4WD occasionally, but at 140,000 miles now and no issues so far.
  10. Aug 17, 2022 at 1:26 PM
    Kevlarster
    Kevlarster Member
    Kevin Shanahan
    2015 Taco 4WD 4L
    None
    I am at this point also with Gen 2 @125k miles. Mine is the passenger side which can't be replaced with an ECGS bushing. I simply can't get the of the CV shaft out from the diff ext tube(highlighted) part 41320. I am now removing part 41320 from the diff. to see if I can just replace that whole axle assembly.
  11. Dec 30, 2022 at 8:36 AM
    Halibut
    Halibut Well-Known Member
    Alaska
    18 OR SB MT
    Hey did you ever finish this job? Far as I know, the ecgs bushing CAN be used on the passenger side as well. Thought I read that they themselves posted that somewhere.
  12. Dec 30, 2022 at 8:37 AM
    Halibut
    Alaska
    18 OR SB MT
    Johnathan, where did you grab this pic? I'm regearing and it looks like I messed up a thrust washer or something that is not in the install kit from nitro gear. Should've been more careful...
  13. Dec 30, 2022 at 8:54 AM
    JonathanH
    Jonathan
    Southern Maryland
    11' DCLB
    It's a screenshot from our electronic parts catalog that I use at the dealer I work for.
  14. Dec 30, 2022 at 9:49 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    the ADD tube bearing is completely different design than the driver side. There are no needles.
    TnShooter likes this.
  15. Jan 3, 2023 at 5:32 PM
    Halibut
    Alaska
    18 OR SB MT
    Totally, and this may have been a fever dream, but someone on here installed it on their passenger side and I believe ecgs said that's fine but won't help
    6 gearT444E[QUOTED] likes this.
  16. Jan 3, 2023 at 5:34 PM
    Halibut
    Alaska
    18 OR SB MT
  17. Jan 4, 2023 at 9:30 PM
    TTLT
    TTLT Active Member
    2021 TRD OR
    Does anyone know which side of the cross member part 41653C on the rear mounting point sits? Is it above or below?
    My mount sucked through the hole and diff rolled forward
    when i took it apart part 41653C had been installed above the crossmember
    this could be correct but it doesn't make sense to me as the hole in cross member is practically the same size as head on part 41655
    Thanks
