Explain the deck plate mod please
Discussion in '1st Gen. Tacomas (1995-2004)' started by MCRANEY, Mar 2, 2009.
  1. Mar 2, 2009 at 6:59 AM
    MCRANEY
    MCRANEY [OP] WARTHOG
    CRESTVIEW FL
    03 Tacoma 4WD SR5 TRD
    3" Lift 285/75 16R Tires Aries Stainless Steel Grille Guard, KC Lights
    Can someone please explain how to accomplish the deck plate mod
    Thanks
  2. Mar 2, 2009 at 7:03 AM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    take a deck plate you get from a marine store. Cut a 3" round hole in your airbox, then screw the deck plate ring onto the airbox. Take the deckplate itself, then screw that into the ring.
    heres an example of a deck plate[​IMG]
  3. Mar 2, 2009 at 7:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Fixed it. :D
  4. Mar 2, 2009 at 7:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  5. Mar 2, 2009 at 7:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Toyota Tacoma 3.4 V6 Deckplate Mod
    Written by: alexandro nieto (SD TACO) Edited By Matt Skrabanek (Matt)
    The purpose of this modification is to allow an increase in air flow at a fraction of the cost of an aftermarket intake.This mod may be done to any Toyota Tacoma V6 or I4. The I4 air box may only be able to use a small sized deckplate due to the size of the air box. This mod allows for a less restrictive flow of air, meaning an increase in throttle response, an estimated 6-9 horsepower, and in some cases a reported increase in fuel economy. This has been said to be just as effective as buying a K&N, Airaid, or Injen intake for your vehicle. It is also to be said that it adds a noticable deeper tone to the intake as well as keep a cooler charge of air coming into the intake as compared to a typical "open" element intake system. On average, this will run you around 15-20 dollars depending upon price of items needed. For best results, the stock paper element should be replaced with an aftermarket air filter such as a K&N cotton with steel mesh replacement filter, or Amsoil foam filter. If you're thinking about purchasing an aftermarket intake, wouldn't you rather gamble 20 dollars? Or rather 200 plus and find out the results are similar?
    What is a deckplate you ask? It is simply a small access hole used on boats that is consisted of a small outer ring, plugable with a screw-in type plate wich is usually sealed internally with a rubber o-ring. This item can be found at just about any boating marine parts shop, or home depot. I aquired mine from the local Wast Parts Marine shop. This allows for you to remove the plate for use in street or dry off-road conditions in which the air box may draw in extra air. The deckplate also allows you to close the hole in times where you may need to cross streams, or in heavy water conditions, where as an open element intake would have no protection, therefore possibly allowing water to penetrate the filter and thus enter the motor possibly causing damage. This modification will give you an alternative to a much safer, cost efficient, and effective manner to pull more power out of your motor.​
    Tools needed:
    - metric sockets and ratchet set
    - philips screwdrivers
    - drill with various bits
    - dremmel, to cut through roughly 1/4 inch thick plastic
    - sharpie marking pen
    - short file
    - optional suitable cold beverage
    Materials and items needed:
    - 3-5 inch deckplate (3" is as big as you can fit on a 4-cyl)
    - 3/4 inch long pan head screws
    - matching nuts, (nylocks prefered) and washers
    - 1 bottle of black RTV "sensor safe" silicone
    Optional parts
    - K&N replacement air filter part# 33-2054
    - Amsoil replacement air filter part# TS-115
    - Duct tape and or electrical tape (this will be used to cap off the
    intake silencers)
    (part#'s may vary upon year and engine model)
    Estimated Involved time is around 1 hour.
    (time may vary upon skill and comprehension)
    DISCLAIMER:
    THIS ARTICLE IS INTENDED FOR INFORMATIONAL PURPOSES. ANY AND ALL MODIFICATIONS DONE TO YOUR VEHICLE ARE YOUR RESPONSIBILITY. ANY PHYSICAL, BODILY OR WARRANTY DAMAGE
    IS NOT THE RESPONSIBILITY OF TRDOFFROAD.COM THE AUTHOR OF THIS ARTICLE. IF CONCERNED IF THIS MODIFICATION COULD VOID YOUR WARRANTY PLEASE CHECK WITH YOUR LOCAL DEALERSHIP.
    Instructions:
    After you have all your tools and items on hand, its time to get to work. First off, you'll need to remove the air box from the truck. There are 3 12mm bolts you must first remove. Next, comes the intake hose clamps next to the tube wich leads from the air box. Take the vacuum hose leading from the right hand side of the air box off. A pair of needle nose pliers will do it. Next, take the MAF (Mass Air Flow) sensor plug out by pressing the retaining clip, and harness. Once done, remove air box from the truck.
    Next up, you will need to mark the area where the deckplate itself will go. Take the deckplate and center it on the front portion of the air box. Next, take a sharpie and trace out the hole size on the box itself as to have a template to cut the hole. Once done, make a pilot hole to start your cut.​
    Once the hole is cut, test fit the deckplate to make sure the hole is large enough to allow it to fit. If the edges obstruct the fit of the deckplate, use a file to grind down the edges further till it allows a good fit. Remember that it doesent have to be perfect, the deckplate will cover up any edge inperfections.​
    Next up, you will need to drill out the holes to run the screws through. Use the deckplate in place to use it as a template to drill the holes. Once drilled it is suggested, but not required to use a small bead of sensor safe black RTV silicone on the edge of the deckplate to secure a good seal. In my opinion this step is not necessary due to how well the deckplate sealed, in wich water would only seep through if the truck was entirely submersed in water (in which case you'll have much bigger issues then just that). After that step is made you may bolt in the deckplate against the surface of the air box and secure it down. Make sure you clean any and all debris from inside the air box from the cutting done earlier.​
    Here's what it should look like finished, with the deckplate removed. ​
    Optional instructions:
    If you wish to get a nice noticably louder rumble from your intake, you may remove your silencers to enchance the sound effect. There are 2 seperate silencers on the intake wich tame the intake air noise coming into the intake. One will be located in the lower section of the intake tube.
    The second silencer will be located in the front face of the intake tube wich is clearely visible.​
    Disconnect the hose clamps wich retain these silencers to the intake. Once removed, take some tape and layer it across the hole on the silencers. make sure to secure the tape in a manner in wich it compleately covers the hole. Once capped off, reinstall the silencers in the opposite manner in wich you removed them. Secure the hose clamps back on snugly.​
    Now that the deckplate is in place and your silencers are capped off, you are ready to reinstall your modified air box into the truck. Place the air box back into position. Attach all hoses and vacuum lines back in place.​
    Deckplate Open
    If you opted to buy an aftermarket filter for this project, or if the filter is due for change and simply bought a replacement filter, go ahead and replace the filter at this time. Once the air filter is in place you may choose to close the deckplate with the lid, and turn the truck on. Listen to your truck as you rev up to around 2000 to 3500 RPM's. Nice, but needs a slightly better tone don't it? Now remove the deckplate lid. Rev up once again...... if all was done right, you should now be listening to a nicer more agressive intake tone to your truck. Go for a spin around the block and you will notice how now under a load, the intake will start to give a nice rumbley sound.
    Congratulations!!! You have now completed the deckplate mod and are on your way to that satisfied feeling of doing something effective without breaking the bank in the process.​
    Deckplate Closed
  6. Mar 2, 2009 at 7:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    To add to this write up, My 2.7 fit a 4" deck plate very nicely. AND, it worked VERY well.
  7. Mar 2, 2009 at 7:21 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I also do not recomend removeing the intake silencer, as this part of the intake tract is tuned to the incomming air puleses. I removed mine and when I did, I lost a little h.p.. Still had a couple more h.p. over stock with the deck plate, but the best gain was with the deck plate and the silencers intacked.
  8. Mar 2, 2009 at 7:37 AM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    i just might do this mod too!
  9. Mar 2, 2009 at 9:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You should. I got better gains from it than I did with any cold air intake I tested. :)
  10. Mar 2, 2009 at 9:52 AM
    jasonh
    jasonh tossed salad anyone?
    Dallas, TX.
    2007 Pre Runner SR5
    Billy 5100's
    i just went and looked at my truck to see where this would go and i am comfused lol. the 4.0 v6 does not have much of a box.
  11. Mar 2, 2009 at 9:55 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    this mod is designed for 95-04 tacomas
  12. Mar 2, 2009 at 10:00 AM
    jasonh
    Dallas, TX.
    2007 Pre Runner SR5
    Billy 5100's
    well shit that sucks lol. thanks
  13. Mar 2, 2009 at 12:17 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I have a problem with the deck plate mod.
    I did the elbow mod instead, but i have a problem with both.
    I have heard that our trucks have a still air box.
    hard to explain but from what an old man said, they aren't meant to have air pushed in.
    Is this true by any means?
  14. Mar 2, 2009 at 12:20 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    and just to clarify can this be done to 2nd gens?
  15. Mar 2, 2009 at 12:21 PM
    JimBeam
    JB
    2015 Tundra
    no
  16. Mar 2, 2009 at 12:22 PM
    DanGer
    thanks the quotes you used left me a bit confused when I first read them
  17. Mar 2, 2009 at 12:35 PM
    dud122
    dud122 rabble rabble rabble
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Warn winch, Tactical rear bumper with tire swing/jerry cans/hi lift, Revenge Fab. sliders, Tundra brakes, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Lights, CB, Switches, skids, LED's... OH MY!
    how many horsepower does the deckplate add... like 5???
    if you cap off the silencers then it drops it to 2 or 3??
    is the decision you have to make whether the deeper sound is worth 2 or 3 horses?
  18. Mar 2, 2009 at 3:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The deck plate gave me just over 5...almost 6 on my 2,7. The 3.4 will have a little better gain. Yep. When I removed the silencers, it dropped to about a 2 to 3 hp gain.
  19. Mar 2, 2009 at 4:03 PM
    dud122
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    depending on how good it sounds with the silencers taped off it may be worth it... are there any other negative side effects to this other than a small drop in hp?
  20. Mar 2, 2009 at 4:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I wouldnt use Duct tape to do it.
