Experience with OEM Toyo Tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FL_TRD Sport, Jun 20, 2021.
  1. Jun 20, 2021 at 5:19 AM
    FL_TRD Sport
    FL_TRD Sport [OP] Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    I'm sure the same as many of you, my TRD Sport came with the Toyo Open Country A30 tires. I've only put 600 miles on my truck since I got it last month and so far the tires seem ok. Relatively quiet and decent dry and wet traction during the limited in-town driving I've done. I don't plan on doing any off roading except the occasional unpaved dirt road, so I have no need for a more aggressive tread pattern or larger size for extra ground clearance. In reading reviews on the tires one comment I've seen is that their life is relatively short. With so few miles I haven't really tested them out, so I was wondering what people's experiences have been with them? Unless there is some real glaring concern my plan is to ride them until they need to be replaced from normal wear, as quick or long as that might be.
  2. Jun 20, 2021 at 6:12 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    I got 25K out of my Toyo A30 . They are nothing special and do everything ok .
  3. Jun 20, 2021 at 6:39 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    The mileage you got is consistent with the reviews I've been reading. Kinda sucks, I'm used to 40-50k as long as they are rotated regularly and kept at recommended pressure.
  4. Jun 20, 2021 at 10:50 AM
    jersey jim
    jersey jim Well-Known Member
    Jim
    2018 Cement DCSB TRD Sport 4x4 6MT
    As far as how they work, so far I have no complaints, but yeah, I have 18k on mine, and 25k sounds about right for the life of them, I'm sure they'll be shot by then, maybe sooner.
    na8rboy likes this.
  5. Jun 20, 2021 at 11:32 AM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    I've got 33,000 on mine. Rotated every 5000. I expect 40+ but may swap before winter just because I want bigger. Good tire but I noticed vibration if I don't rotate them often
    FL_TRD Sport[OP] and MIDTNTACO like this.
  6. Jun 20, 2021 at 12:15 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Mine have almost 29,000, still legal but won't make it another season, my truck doesn't go out in the winter.
    Satisfied with the tires, they are quiet, haven't needed to be balanced and are nice riding.
    Probably going with a Firestone Destination LE3 next time so I can get white letters. :)
  7. Jun 20, 2021 at 1:04 PM
    Taco1701
    Taco1701 Well-Known Member
    William
    GA
    2020 DCSB TRD Sport 4x4 Cement
    Had them on my 2016 Sport and my 2020 Sport. At 25k miles on my 2016 they needed to be replaced. They made it to 30k when I traded the truck. They were okay on dry pavement, but that was about it. They were terrible on wet roads and not much better in the dirt. My 2020 had them as well and I was looking at replacements before I even picked up the truck. Took me a bit to decide what tires to go with, but replaced them at 4500 miles with some Nitto Terra Grappler G2s.
    MIDTNTACO likes this.
