Experience with Air Armor M240 Air Compressor?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Smithw3, Mar 1, 2016.
  1. Mar 1, 2016 at 5:38 AM
    Smithw3
    Smithw3 [OP] Member
    Will
    Charleston, SC
    07' DCSB 4X4 TRD Off-Road
    Looking to get a small air compressor for the truck and came across this one and wanted to know if anyone had bought or used one. I really liked that it came in the ammo can- thinking I could just strap it in a corner of the bed. Not really looking to permanently mount anything on the truck. I know this topic is a beyond a beaten dead horse but I appreciate any help.
    http://www.amazon.com/gp/product/B0...finements=p_72:1248861011&s=automotive&sr=1-5
    pat's taco likes this.
  2. Mar 1, 2016 at 6:14 AM
    patbegley
    patbegley Well-Known Member
    The Kootenays
    '22 DCLB
    Little pricey.
    Have a look at viair, under 1/3rd the cost and high quality.
    Smithw3[OP] likes this.
  3. Mar 22, 2017 at 12:24 PM
    SpecialOpsTools
    SpecialOpsTools New Member
    Earl
    Hello there Smithw3. Just wanted to let you know we have a bracket custom made for the Air Armor M240 which can be mounted to your vehicle. The M240 locks into place in the bracket and can be easily removed if needed. Great way to keep it in place in case of a rollover and for general security.
    The bracket can be seen here and is manufactured by a US company called SWAG: http://www.specialopstools.com/swag-mounting-bracket-for-air-armor-m240/
    Hope this helps and please let us know if you ever have any trouble with our product! We pride ourselves on customer service and will do our best to make it right.
  4. Dec 22, 2017 at 3:34 AM
    mbmack1
    mbmack1 That F'n guy
    matt
    az
    SAVAGE silver '06
    I just found this thing online. Did you buy it? If so, what's your opinion so far?
  5. Dec 22, 2017 at 4:27 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
  6. Dec 22, 2017 at 4:42 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    If their claims are right, that it can air up a 35" tire from 0-35psi in 5 minutes, that is impressive and makes it worth the money. But I would also have concerns about it being cooled properly.
  7. Dec 23, 2017 at 6:04 AM
    mbmack1
    matt
    az
    SAVAGE silver '06
    I like it because it's fast and because I can throw it in my tool box and not worry about it being broken by Jack stands, pry bars, tools bags, ect... being tossed around on it while I'm wheeling. And I'm not really worried about it overheating. It can't get very hot in 5 minutes of use, which is all it should take to get my 33's from 20psi to 35psi.
  8. Dec 23, 2017 at 6:09 AM
    badger
    badger Well-Known Member
    07 SR5
    All of these little compressors get HOT fast. It's not the motor that heats up as much as the heat generated by compressing gas. Having it in a can is probably not an issue if the can is open during operation.
  9. Dec 23, 2017 at 6:25 AM
    mbmack1
    matt
    az
    SAVAGE silver '06
    That's my thoughts. Just leave it open for a few minutes after use before packing it up. What's hot to the touch is different than what's hot for the machine. They're designed to handle the heat generated by compressing air. I'm not saying that it can't get overheated, just that simply because it's hot to touch doesn't mean it's too hot.
  10. Oct 15, 2018 at 6:33 PM
    stanford135i
    stanford135i Member
    so has anything put this air armor thru the pace? too hot? recommend? i need something sturdy for my tacoma and forget about it. thanks
