Exhaust Manifold Crack Symptoms
Discussion in '1st Gen. Tacomas (1995-2004)' started by netsomnia, Jun 18, 2014.
  1. Jun 18, 2014 at 4:09 PM
    netsomnia
    netsomnia [OP] Well-Known Member
    Central/Eastern Missouri
    1998 2WD Tacoma 5 lug
    What are the symptoms? I have a rough idle and appears to me louder and rougher overall compared to my older 1990 22RE that I owned. Is the symptom a 'tick, tick, tick' or can idle and exhaust noise appear too? I have a loud humming noise coming from under the floor when I downshift or let off the gas. I was guessing this was a heat shield for the catalytic converter or muffler but now I am wondering if this all related to the well known cracked exhaust manifold issue?
  2. Jun 18, 2014 at 9:40 PM
    TimPall13
    TimPall13 Well-Known Member
    Tim
    Sandy Oregon
    3link SAS 02 SR5 Limited V6
    Lift: TrailGear 3link SAS with Fox 2.0 Coil overs in front. Custom Alcan Leafs with relocated Fox 2.0 shocks in rear. Sitting at 6in of lift. Armor: Relentless Fab Front bumper with home made hoops and Warn VR Evo 10s winch. Relentless Fab Rear bumper with swingout gate. Gears/Grip: 4.88 gears with ARB Air lockers front and rear. 35x12.5 Mickey Thimpson Baja Boss MTs on 17in Trail Ready Beadlock wheels. Lighting: 6000k 55w HID head lights in Retrofit Prejectors, KC Slim Light LEDs behind a Grillcraft grill and on CBI windshield mounts, And LED rock Lights. Performance: 6" deckplate mod, URD Crank Pulley, K&N air filter, ISR mod, and a AirRaid throttle body spacer, magnaflow muffler. Audio: Alpine speakers and sub running on a Alpine 5ch amp. All ran with Stinger wire kit, and a Alpine touch screen reciever. Extras: 15% Window Tint, Spray in bed liner, LineX coated factoey fender flares, Custom Roof rack/Track system, SoftTopper Canopy, Viair Dual 444c Onboard air with dual 2.5Gal tanks.
    When mine cracked on my old 4runner you could hear air at idle. Kinda a puffing sound from under the hood. Mine was cracked bad though so it would depend on how bad. I think mine did throw off the rpms on idle too.
    Tim
  3. Jun 19, 2014 at 1:46 PM
    netsomnia
    Thank you. I looked pretty hard with my reading glasses and a flashlight today - no cracks. I will check out the catalytic converter and exhaust pipe areas next for the source of the noises.
  4. Jun 19, 2014 at 2:26 PM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    Exhaust leaks on the 2.7 are quite frequently due to missing donut gaskets between the y-pipe and manifold. They often get sucked into the cat.
  5. Jun 19, 2014 at 4:32 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    It's really noticeable from another vehicle while driving or if you drive next to a barrier. I can always here someone else's cracked manifold as they drive by. Like two pieces of metal clapping.
  6. Jun 19, 2014 at 8:32 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    I can say it is cracked based solely on the year of your truck.
  7. Jun 20, 2014 at 5:54 AM
    polack
    polack Well-Known Member
    2.7 here. When mine went it was the gasket between the manifold and the first catalytic converter pipe. in the cab it sounded like a butterfly flapping it's wings next to your ear. was noticeably louder when it was cold. but as the truck ran it would quiet down. Also i could not see the leak at all as it was really small. i finally found it when i pulled the entire manifold and pipe out as a whole unit. you could see the black leak out if the gap between the two.
  8. Jul 1, 2014 at 7:52 PM
    TimPall13
    Tim
    Sandy Oregon
    I agree! When i relpaced my manifold i noticed the donut gasket was dust! Still had a nice crack though. If no crack then prob a gasket.
    Tim
  9. Jul 10, 2014 at 12:31 PM
    netsomnia
    Mine ended up being a leak at the catalytic converter. It appeared to be broke due to rust versus a gasket. Although I am not opposed to DIY projects, I wanted mine welded back together. The welder at the shop, cut off the flanges where the gaskets would normally be, and replaced with two short pipes on each side of the catalytic converter. Now I am receiving a check engine light and 'catalyst system' code. I plan to buy a bluetooth OBDII transmitter and software for my Android so I can continue to troubleshoot as I replace parts.
    The parts that I have read working are magnaflow aftermarket cat with denso O2's. I am debating whether to try O2's first. Any suggestions on the parts to start out? Do I need the California NOX ratings for everything to clear the CEL? What OBDII adapter works best on the Tacoma? It would be cool to have an RPM and TEMP reading to monitor while I tune my new used Tacoma with only 95K on the odometer.
  10. Jul 10, 2014 at 1:10 PM
    Indy
    Indy Master of all I survey.
    I got my bt obd on ebay for about $5, torque in the play store is free.
    I have a failing O2 sensor in my mustang, I get to use torque every other day to kill the check engine light. Some day I'll get off my butt and put a jack under the car. Probably not today though :laugh:
  11. Jul 14, 2014 at 1:45 PM
    netsomnia
    I bought the OBDlink - I am inquiring about O2 sensor output graphs from my scanner in another thread because this one is more about cracked manifolds, which I am watching out for and preparing for on my 2RZ.
  12. Oct 28, 2014 at 7:57 AM
    96coma
    96coma Active Member
    Josh
    New Hampshire
    96 5sp tacoma 4x4
    to much to post lol
    will a cracked manifold cause burnt exhaust valves? if so, how bad does it need to be cracked to do so, and how long could you drive with the manifold being cracked before it burns the valves?
  13. Oct 28, 2014 at 5:41 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    valves burn from not being adjusted properly and the cylinder gases burn the sealing edges.
    a cracked exhaust manifold might cause other issues but burned valves is not one of them.
    now how in the world can you make a matter of fact statement like that? every truck is different and there is no set expiration date when manifolds are assured to crack. but I do get your point that odds are good something this old "may" stand a good chance of having a cracked manifold.
  14. Oct 29, 2014 at 8:01 AM
    96coma
    Josh
    New Hampshire
    96 5sp tacoma 4x4
    to much to post lol
    thanks for the info, what other issues could it cause if not taken care of in a timely manner? besides bad gas mileage of course
