Exhaust Gasket Part Number Needed!
Discussion in '1st Gen. Tacomas (1995-2004)' started by tychoseven, Oct 12, 2016.
  1. Oct 12, 2016 at 9:46 AM
    tychoseven
    tychoseven [OP] Well-Known Member
    Klickitat County, WA
    1999 Tacoma SR5 4x4, 2.7L 5spd
    I'm trying to fix an exhaust leak where the exhaust manifold meets the downpipe (P/N 17410-0C040, I have the CA model). I've ordered the two donut gaskets (90917-06061) but after taking off the downpipe I see there's a second, flat gasket which is not referenced anywhere in the Toyota parts list, nor have I seen anybody mention it in threads here on TW.
    Do I need this second gasket or will the exhaust seal without it? It's damaged as you can see in the photo below and I can't find a replacement..
  2. Oct 12, 2016 at 9:53 AM
    ajm
    ajm Well-Known Member
    Anthony
    AZ
    1996 4x4
    That thing has sort of a home made look to it. I replaced my exhaust manifold a few years ago, and I THINK it only used the regular exhaust gaskets where it connects to the downpipe, but I can't remember for sure.
  3. Oct 12, 2016 at 11:55 AM
    tychoseven
    It does look homemade, now that you mention it. I called a couple of auto parts shops in the area and they can only find the donut gaskets.
    Maybe the previous owner put that in as "insurance"?
  4. Oct 12, 2016 at 12:04 PM
    ajm
    Anthony
    AZ
    1996 4x4
    Maybe. Probably was contributing to the leak, if anything. You can see the different color on the side of the downpipe that matches where that gasket in question is broken.
  5. Oct 12, 2016 at 12:05 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
  6. Oct 12, 2016 at 12:10 PM
    RUKIDNME32
    RUKIDNME32 New Member
    Tim
    98 Tacoma Extra cab V6
    You should need just those 2 gaskets. That one piece gasket is a mad out of gasket material....Just the 2 round ones should be all you need.
  7. Oct 12, 2016 at 6:42 PM
    tychoseven
