Exhaust dump before axle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by eschmunk, Sep 4, 2024.
  1. Sep 4, 2024 at 7:04 AM
    eschmunk
    eschmunk [OP] Well-Known Member
    Stuttgart, Germany
    09 Prerunner TRD Off-Road
    GrillCrafter Upper and Lower, Lamin-X Fog Light Covers, Di-Noc Carbon Valence Cover, WeatherTech Digital Fit Liners, Rubbermaid "ActionPacker" containers for bed storage.
    Anyone seen this before? Looking for options to get rid of the drone. Around town it’s great but highway is annoying. Thinking of going stock as there are plenty of marketplace but concerned about 285/70/r17 spare. Still need to bend tabs back to see if it will
    Go a bit higher.
  2. Sep 4, 2024 at 7:12 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yup. But not like that. Kind of killing the additional clearance. I've had mine done twice. Once on the stock exhaust and once on a Pro. The Pro sounds delicious all the time, even long trips.
    Just a note that I can hear the exhaust most all the time, but it is not obtrusive. I have heard drone-y exhausts on Tacos.
    Stock mod:
    Pro mod:
    Jaragon likes this.
  3. Sep 4, 2024 at 7:33 AM
    eschmunk
    Stuttgart, Germany
    clearance is good. Tucked between frame and leaf spring mount. Least of my problems. :)
    tonered[QUOTED] likes this.
  4. Sep 4, 2024 at 7:50 AM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    Is the exit just relocated on that muffler? Is that even possible? Is there a hole on the other side that is plugged?
    I’ve shortened mine at the axle but it still points south when I head north.
  5. Sep 4, 2024 at 8:28 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Dumping exhaust under the truck is a bad idea. Pointing it back toward the cab is terrifying! :eek::eek::eek:
    musicisevil and BoomerGVNG like this.
  6. Sep 4, 2024 at 8:39 AM
    BoomerGVNG
    BoomerGVNG GET OFF MY LAWN
    2022 TRD SPORT DCSB
    We love CO seeping into the cab at stop lights, what do you mean?
  7. Sep 4, 2024 at 10:22 AM
    Sungod
    St Augustine
    If only it was a 2 stroke. No better cologne.
  8. Sep 4, 2024 at 10:24 AM
    baboltin
    baboltin New to the 3rd gen world!
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Stock with a camper shell for now.
    Did you paint your muffler and exhaust pipe ? And if so with a rattle can high heat ?
  9. Sep 4, 2024 at 10:50 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yeah. This one was passed around and needed some clean up. It was my first try with VHT paint. It went on easy and has done well. Still looks great. Since it needs heat to cure, I did not get the top and could hit that sometime down the road since the side that you handle when installing is now painted.
    baboltin[QUOTED] likes this.
  10. Sep 4, 2024 at 10:59 AM
    eschmunk
    Stuttgart, Germany
    No plug, entry and exit on the same side. It will be changed sooner than later.
  11. Sep 4, 2024 at 2:58 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    is that a flowmaster muffler?
    if so the drone might not ever go away
  12. Sep 4, 2024 at 5:41 PM
    eschmunk
    Stuttgart, Germany
    not sure. Nothing stamped on either side.
  13. Sep 4, 2024 at 5:55 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Why? Axle dump is OEM on 4th gen Trailhunter. No regs against it on a truck, since the exhaust tip is under the bed and not under the cab.
  14. Sep 4, 2024 at 6:29 PM
    RIX TUX
    from all the posters on TW i only remember hearing one aftermarket exhaust that didn't drone......but i cant remember which one
  15. Sep 4, 2024 at 7:00 PM
    BurntToast
    BurntToast Well-Known Member
    San Antonio, TX
    2017 MGM Tacoma TRD Off-Road
    Front-Icon 2.5 Extended Length Coilovers Rear-Icon 2.0 (Ext for 1.5"-3" lifts) with RXT Leaf Pack Method 701 Matte Black 17"x9" -12 offset Kenda Klever R/T KR601 33x10.5 17"
    That looks like the Stromung Tucker exhaust http://www.stromungexhaust.com/16-1...trans-24-wheel-drive-crew-cab-short-bed1.html. i have it on my truck. It should say Stromung on the exhaust tip. It is droney for me in the roughly 2100-2400 rpm range. It has a nice sound but the drone can get on ya. Since updating my tune from KDMAX to Yotawerx 2.1 ive noticed a big improvement on the drone. The KDMAX liked to hold longer before shifting and when just cruising would keep it in the drone rpm range. I would either give the pedal a quick punch to get it to shift or let off. But ive noticed with the new Yotawex BH 2.1 it seems to stay just below 2000 rpm if im cruising even less with no loss in power. Overall the tune while improving shift points seems to keep me out of that drone RPM range more often. It has been more enjoyable to drive. Plus the new stereo and sub helps too. I do like the sound of the exhaust when at idle and WOT outside the drone zone. I've looked at possible resonators or helmholtz resonators but for the moment with the updated tune i can live with it. R4T also made some similar exhaust but their version dumps out the back. But an earlier version may have been similar to the Stromung. I suspect R4T may be a rebranded Stromung. Edited to add I did think about getting it altered to dump to the back or even get a similar resonator installed like on the Magnaflow overland but wasn't sure they would sell me just the resonator.
  16. Sep 4, 2024 at 7:30 PM
    eschmunk
    Stuttgart, Germany
    Looks like the one. Will see if it labeled. Thanks.
  17. Sep 5, 2024 at 5:39 AM
    Sungod
    St Augustine
    You do realize that there are cab vents between the cab and the bed?
    I don't know the rules in all states, but clearly it is the law in Va - 19VAC30-70-300. Muffler, exhaust system and trailer venting. (virginia.gov)
    Willy Lump Lump likes this.
  18. Sep 5, 2024 at 6:51 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Also if it helps, this is pretty much what it sounds like:
    Rear slider open with a Softopper that does amp up sounds from the bed area.
  19. Sep 5, 2024 at 7:05 AM
    Willy Lump Lump
    21’ dcsbmt
    This and that
    It says behind the rear axle, and it’s cool if you have a Nissan because they are just known pos and the exhaust system can be shit.
  20. Sep 5, 2024 at 7:14 AM
    Spadi_5
    Spadi_5 Well-Known Member
    Wisconsin
    2019 DCSB TRD OR
